Panel Due extrusion feed rate.
Is there a way to change the speed (mms) that the panel due shows for default extrusion speeds? 5mms is as slow as it goes. On the computer it goes down to 1mms. I'd like to change the defaults to what I like.
You can only do that by changing the firmware. The current PanelDue firmware has a 2mm button, so you may wish to upgrade to it.
Ok, I'll check that out.
