Stop Thermal Transfer from Bed to Frame
Here is an image of the setup that I used for the garolite
https://1drv.ms/u/s!ArsUUgUVyLkdhq02CHFbp6Ctv00auw -
As you guys know, I only got my grade 10 but my thinking thoughts are saying that if the heat transfers to the frame then could it be possible for the frame to experience thermal expansion on some level or another and then obviously it could be for to say that the frame might flex or mess with the calibration?
@ricky_grade10 exactly. and hopefully by using one of the methods others have described above I'll be able to stop it as much as possible.
@richardmckenna yes indeed and just to further my suggestion I used a 25mmm hole drill to cut some discs out of 10mm thick PTFE Sheet works like a dream.
Doug
@dougal1957 Thanks Doug. I found some 10mm and 20mm thick PTFE offcuts as well as some stainless steel spacers on ebay. So I'll give them a go when they arrive.
I was just going to cut blocks out of the PTFE but I do like the idea of them being round.
@richardmckenna I had a holes in the tool box which is why I used it drilled the hole in the middle (it is a little big but it allows some wiggle room to move the disc so it doesn't overhang the extrusions)
and cut the round at the same time easy lol -
you can find ceramic spacers at mouser
https://www.mouser.de/Electromechanical/Hardware/Standoffs-Spacers/_/N-aictf?P=1z0z0py -
@richardmckenna Assuming a temperature delta of 40 degrees and a length of extrusion 500mm in length you aren't even looking at 1mm of expansion. As far as accuracy of the frame goes that is going to matter. However, if you keep the bed bolted down and the frame does not expand with the bed you can end up with issues like the bed buckling. Unless you are noticeable seeing defects in your print because of it just let it be.
@richardmckenna Still can't remember the name of the stuff I used but do a google search for under "floor heating insulation" or some such. I did find a picture though
So it's two layers of thermal insulation, then the 10mm thick aluminium plate, then 6mm of glass on top. Counter sunk bolts go through the aluminium and insulation and screw into T nuts in the frame. Thermal transfer to the frame only happens through the bolts (which are stainless steel) so it's negligible.
Nice and simple. It may not be any good to you though, depending on your bed levelling arrangement. I have 3 screws and a single belt and simply slacken the grub screws holding the pulleys onto the screws, adjust each screw and tighten the grub screws up. I've only had to do that about 3 times - each one after disassembling the machine to move it.
Just a thought, but I wonder if rubber vibration insulators (basically a piece of hard rubber with 2 bolts moulded in top and bottom) would work? There are small ones holding a plastic cover to the top of the engine in my car. They can take lots of heat and are moulded so they should be exactly the same size. Something like this:
https://www.ebay.co.uk/itm/Aeromotive-Fuel-Pump-Vibration-Dampener-Mounting-Kit-11601/362096382511?epid=1168728755&hash=item544ea0522f:g:zkIAAOSwWaRZsnyp:rk:3:pf:0
but cheaper! -
PEEK Spacers ... https://www.mcmaster.com/90144a130
Could also use wood or melamine spacers.
I use printed TPU spacers, no problem with heat whatsoever...
