Extra layers on print
I have duet wifi and i use simplyfi3d to slice stl file.
When i print i get on duet web interface printed layer count like 48 from 46 or 102 from 101 so duet over print layers.
When i set top or bottom or external solid layers in S3D to 3 i have more overprint layers.
So i cant control dimension of printed elements :/.I cant find if s3d not work or my settings of duet.
Regards Kamil
Are you actually getting more printed layers, or is the count in the display just wrong?
Can you post a gcode file that shows this?
I print box wit 25x25x25mm when i set top and bottom solid layers to 3 i have printed extra 6 layers and dimension of my box extend on Z axis about 6x0.2mm (layer high 0.2mm).
Work the same when i add more outside solid layers - holes are thiner.
I will check my qcode after slicing and wrote if s3d work or duet add extra layers. -
@kivlow do you get the same with a different slicer?
