Cura 3.6 problems
@burtoogle said in Cura 3.6 problems:
Thanks for the clarification re the bug fix, @dc42.
Back to the OP's problem, it just looks to me that the line segments are too short (around 0.3mm typically).
Short line segments combined with low extruder steps/mm triggered the problem that was addressed in firmware 2.02. The work around in earlier firmwares was to increase microstepping.
This is not a duet problem. I tried to print it once and it failed. Then I imported the gcode in repetier hist and cura and saw this strange effect. So either it is a cura bug..... But people are using cura 3.6..i have used cura before... I think 3.2....so I guess I have a wrong setting...
Or is the gcode OK but k
Cannot repetier host and cura not visualizer relative extrusion files....... And the file is fine? It stopped print after the first infill layer... Which is where the code visualisation starts to look funkyFor now I think is I have something setup wrong or it is a cura bug and people don't set the relative extrusion option.....
I will try the Facebook group maybe they have an answer..... I'll just keep using slic3r
@dc42 well I updated cura from my previous version... Sliced the cylinder and this was the result... I inticked relative extrusion, which I had set in the previous version and it looks OK....
I will try to set up the printer profile from scratch and reset everything in Cura -
Hi @AlexLin , what steps/mm are you using with your extruder? Thanks.
@burtoogle I think something like 830 per mm for my titan extruder, but that is not something the slicer cares about.....I have printed fine with Cura slices before and I still print fine with Slic3r. This is not a RRF/Duet problem. It is either a bug in Cura (behaviour of relative extrusion) or I have Cura configured wrong.
The printer works fine, just not with files sliced by Cura 3.6 with 'relative extrusion'enabled. I see M83 in the g-code...but is doing something funky... -
@alexlin, that's understood. Well, I'll take another look at the gcode and see if I can spot what's going wrong.
I found the problem, the pause at height script is leaving the extruder in absolute mode.
The pause at height plugin appears to unconditionally add an M82 to the end of the script. That's a bug!
@burtoogle O sh*t I must have used that once a long time before and it survived the upgrade to 3.6. I will disable it and see whether that works and report it as a bug to Cura/plugin. Thank you very much for your efforts!Greatly appreciated!
I have created a Cura issue reporting this bug.
@burtoogle thanks!Service!
verified that that was the problem...this has worked before but seems to be broken in the plug-in
i have a custom delta printer with duet 2 wifi, i usually use slic3r, but when i started using cura on my ender 3, the top surface finish was better. so when i tried using cura with delta the extrusion was at a very very low rate, i have turned on " relative extrusion" on cura.
Should i make any other changes to the cura of duet settings?
@alexlin how to disable it?
@paul12 disable what?the plug-in...that was something very specific for me since I obviously had turned it on in th elast print in an earlier version. You should be good with th erelative extrusion turned on
