Paneldue button location incorrect
Paneldue 5" buttons are offset too low on display. Always have to press above the button by about 4-5mm, makes it difficult to control from the Paneldue. This problem is from the start on this unit which I purchased about Nov 2018.
Run the
Calibrate touch
routine from theSetup
tab on your PanelDue. -
@resam Thank you. Now I will go have my eyes checked. Dont know how I missed that.
Even with calibrate my big fingers sometimes push the wrong buttons on the touch screen. I have used a touch stylus at times to make it easier.
@bret4 said in Paneldue button location incorrect:
Try using the tip of your fingernail.
