My E0 Driver just went pop
@dc42 whats the best way to remove old driver ?
Thanks Ben -
@benny said in My E0 Driver just went pop:
Two ways:
I use an electric hotplate and hot air SMD rework equipment. Put the board on the hotplate and heat it to 120C (I use a multimeter thermocouple attachment to monitor the temperature). Allow the board temperature to stabilise, then use the hot air tool with a large square nozzle to heat the driver chip, and a vacuum pickup tool to remove it.
You could use ChipQuik or similar low melting point solder. I suggest using a vacuum pickup tool again, they are very cheap on eBay.
If you are in the US then I think forum user W3DRK still offers Duet repair services.
@dc42 thank you for your reply hope you have had a good Christmas.
Do i need hot plate or will it work just as well with just hot air ? -
It will take longer with just hot air, because the PCB acts as a heatsink for the driver chips.
Hint: remove the plastic parts from nearby Molex connectors first to protect them from the heat, using long nosed pliers. This is easier to do if you heat them first with hot air at 150C.
there are some good videos on youtube
Louis Rossmann does many repair videos where he explains what he does while reparing macbooks
https://www.youtube.com/watch?v=mr1UVPsExiE -
Changed driver having problems with B phase, alert pops up says B phase may be disconnected but motor works.
Any Clues what I've done wrong ? -
One of the best ways I found removing a large QFP chip with thick ground connections is to little rally cut the pins off the package then desolder the remaining pins. This needs to be done carefully as to avoid delaminating the copper from the PCB but this is another method.
Any Clues what I've done wrong ?Check that all the driver OB pins are soldered down. There are 8 of them.
The problem I'm having is bridging, through lack of experience, then using wick to remove bridge and probably the solder under pins. Trying to find the balance -
Some of the driver output pins are paired, so bridges between those pins are harmless. See the TMC2660 data sheet for details.
Yea the doubles are easy its the single small ones between them.
