2.02RC6 issue: Issues with folders name that have accentuation
This happened after RC6 update. No other issues so far. That, below, should read "Aviões"
That would be because I switched the file system to use UTF8-encoded file names instead of code page 850. Two questions:
If you upload a new file with accented characters in the name through DWC, is the filename displayed correctly in DWC?
If the answer to #1 is yes: if you then put the SD card in a PC, which of the 2 filenames does the PC display correctly? I doubt that it will be both.
