Auto sleep didn't work
I had a M81 S1 in the end Script of s3d.
Tooked that out and added it in sleep.gThen, i started a Job and enabled Auto sleep.
After the print was finished and all temp controlled Fans were off, the printer Shut not down.
Am i missing something?
You have to keep your browserwindow open and running. So your PC needs to stay on, and the DWC window active (needs no focus though).
Oh, ok. That was the problem. Then i have to put the M81 back to the end Script of s3d.
Thanks!
@torro said in Auto sleep didn't work:
Thanks!
Or you can put it in stop.g, and make sure that is a M0 command at the end of your S3D end script. It's stop.g that gets run when a print finishes.
it makes no difference. i have to decide before the print starts, if i want a shutoff or not. isn´t there a possibility, that the duet/firmware/macro remembers the enabled auto-sleep, when i close the web interface?
If you set the hot end heatsink fan to run thermostatically, then if you start a print, wait until the fan is running and then send M81 S1, it should turn the printer off at the end of the print. I suggest you also enable logging, because a heater fault could also cause the print to be terminated.
Ok, i'll try
Yes it would be nice to have the webserver handle the "enable auto sleep" function instead of the DWC browser-window. If a print takes longer than I anticipated and I want to go to bed, I like to enable auto-sleep. It is not something I already decide while slicing For now, I'd rather have my PC running continuously instead of my printer.
@deltacon said in Auto sleep didn't work:
You can do that by sending M81 S1 after the print has started and a thermostatic hot end fan is running.
@dc42 said in Auto sleep didn't work:
Yes, the sad truth is that I have a v0.6 Duet and have no thermostatic hotend fan...
I have myself to blame, because I went for a 0.6 even after the WiFi came out -
I have myself to blame, because I went for a 0.6 even after the WiFi came outYou can pretend that you have a thermostatic fan, because the Duet 06 runs the same firmware as the 085 which has a second fan (fan 1). But you won't know for sure that your virtual thermostatic fan is running.
That is a brilliant idea. Maybe I will work that out some time when I have more time at hand.
