Can I store and read values from card
It's possible in a macro file to create and write data to a different macro file using the M559 command. Then you could execute the file from config.g. So you could use this method if you used only a few different settings of the RGB LEDs. When conditional GCode, variables and the object model are implemented, you will be able to do a lot more.
@dc42 said in Can I store and read values from card:
Can't wait for this option.
@dc42 that latter sounds awesome. Any chance that's in place prior to MRRF2019?
@core3d-tech said in Can I store and read values from card:
When is that?
@dc42 March 29th 2019 (Goshen Indiana) https://www.eventbrite.com/e/2019-midwest-reprap-festival-mrrf2019-tickets-51075814135
Yes, I expect it to be available before then.
@dc42 Any chance, rudimentary math available (like Build height = Build height - x)?
Yes.
@dc42 Excellent! People will ask why do you do this with your printer. It makes no sense and I'll say "because Duet lets me!!"
@core3d-tech In case you have missed the discussion about variables I kicked off a while ago.
dc42 posted a first draft of the intended implementation here , I haven't had proper time to comment on yet ;-(
