Maestro halted after macro launched on DWC
The machine was printing from SD card, I launched a macro calling M122 to see if any hiccups are occuring, after this the DWC stopped responding (host unreachable) so I went to the Panel Due to see if the network module was still online but as soon as I touched the Macro tab button the machine stopped.
I will try to reproduce this error
=== Diagnostics === RepRapFirmware for Duet 2 Maestro version 2.02RC4(RTOS) running on Duet Maestro 1.0 Board ID: 08DAM-9F9DA-MWNS8-6J1DG-3SN6K-K406X Used output buffers: 1 of 20 (14 max) === RTOS === Static ram: 21428 Dynamic ram: 96812 of which 0 recycled Exception stack ram used: 212 Never used ram: 12620 Tasks: NETWORK(ready,456) HEAT(blocked,1300) MAIN(running,3672) IDLE(ready,200) Owned mutexes: === Platform === Last reset 00:00:21 ago, cause: software Last software reset at 2018-11-22 20:00, reason: Stuck in spin loop, spinning module GCodes, available RAM 12172 bytes (slot 0) Software reset code 0x4043 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0400f80f BFAR 0xe000ed38 SP 0x20000f1c Task 0x5754454e Stack: 00440d4f 00444830 21000200 00000004 00000000 00000004 00444a2d 200046dc 00440d4f 00000001 00000004 2001c354 00000004 2001c354 000069c4 00000004 00441075 00000004 00000000 00000000 00419f2f 00441015 00745fff Error status: 0 Free file entries: 9 SD card 0 detected, interface speed: 15.0MBytes/sec SD card longest block write time: 0.0ms, max retries 0 MCU temperature: min 39.3, current 39.5, max 39.9 Supply voltage: min 24.0, current 24.0, max 24.1, under voltage events: 0, over voltage events: 0, power good: yes Driver 0: standstill, read errors 0, write errors 1, ifcount 22, reads 857, timeouts 0 Driver 1: standstill, read errors 0, write errors 1, ifcount 22, reads 857, timeouts 0 Driver 2: standstill, read errors 0, write errors 1, ifcount 22, reads 857, timeouts 0 Driver 3: standstill, read errors 0, write errors 1, ifcount 180, reads 857, timeouts 0 Driver 4: standstill, read errors 0, write errors 1, ifcount 171, reads 857, timeouts 0 Driver 5: ok, read errors 0, write errors 0, ifcount 0, reads 0, timeouts 864 Driver 6: ok, read errors 0, write errors 0, ifcount 0, reads 0, timeouts 863 Date/time: 2018-11-22 20:01:12 Slowest loop: 4581228.50ms; fastest: 0.06ms I2C nak errors 0, send timeouts 0, receive timeouts 0, finishTimeouts 0 === Move === Hiccups: 0, StepErrors: 0, LaErrors: 0, FreeDm: 240, MinFreeDm: 240, MaxWait: 0ms, Underruns: 0, 0 Scheduled moves: 0, completed moves: 0 Bed compensation in use: none Bed probe heights: 0.000 0.000 0.000 0.000 0.000 === Heat === Bed heaters = 0, chamberHeaters = -1 -1 Heater 1 is on, I-accum = 0.0 === GCodes === Segments left: 0 Stack records: 1 allocated, 1 in use Movement lock held by null http is ready with "M122" in state(s) 0 0 telnet is idle in state(s) 0 file is idle in state(s) 0 serial is idle in state(s) 0 aux is idle in state(s) 0 daemon is idle in state(s) 0 queue is idle in state(s) 0 lcd is idle in state(s) 0 autopause is idle in state(s) 0 Code queue is empty. === Network === Slowest loop: 7.61ms; fastest: 0.03ms Responder states: HTTP(0) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0) Telnet(0) HTTP sessions: 1 of 8 Interface state 5, link 100Mbps full duplex === Filament sensors === Extruder 0 sensor: position 0.00, no data received, no calibration data
Were you able to reproduce it?
not the same way, but yesterday i paused the print to change filament and the DWC become unreachable again.
also the maestro freezed, I was unable to resume the print
