Z Probe trouble (Solved)
Here they are As requested:
Config G
; generated by RepRapFirmware Configuration Tool v2 on Sun Nov 18 2018 18:17:16 GMT-0800 (Pacific Standard Time); General preferences
M83 ; ...but relative extruder moves; Network
M550 P"BIG HELGA" ; Set machine name
M552 S1 ; Enable network
M587 S"TELUS1901-2.4G" P"g54y3tkwdb" ; Configure access point. You can delete this line once connected
M586 P0 S1 ; Enable HTTP
M586 P1 S0 ; Disable FTP
M569 P1 S0 ; Drive 1 goes backwards
M92 X80.00 Y80.00 Z400.00 E127.32 ; Set steps per mm
M566 X600.00 Y600.00 Z12.00 E120.00 ; Set maximum instantaneous speed changes (mm/min)
M203 X18000.00 Y18000.00 Z240.00 E1500.00 ; Set maximum speeds (mm/min)
M201 X3000.00 Y3000.00 Z100.00 E10000.00 ; Set accelerations (mm/s^2)
M906 X950.00 Y950.00 Z1050.00 E950.00 I30 ; Set motor currents (mA) and motor idle factor in per cent
M208 X650 Y350 Z344 S0 ; Set axis maxima; Endstops
M574 X1 Y2 S1 ; Set active high endstops; Z-Probe
M574 Z2 S2 ; Set endstops controlled by probe
M558 P2 H5 F360 T6000 ; Set Z probe type to modulated and the dive height + speeds
G31 P500 X12 Y23 Z1 ; Set Z probe trigger value, offset and trigger height
M557 X15:635 Y15:335 S20 ; Define mesh grid; Heaters
M307 H0 B0 S1.00 ; Disable bang-bang mode for the bed heater and set PWM limit
M305 P0 T100000 B4138 R4700 ; Set thermistor + ADC parameters for heater 0
M305 P1 X200 ; Configure thermocouple for heater 1
M143 H1 S300 ; Set temperature limit for heater 1 to 300C; Fans
M106 P0 S0 I0 F500 H-1 ; Set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned off
M106 P1 S1 I0 F500 H1 T45 ; Set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned on; Tools
M563 P0 S"#1 Primary" D0 H1 ; Define tool 0
G10 P0 R0 S0 ; Set initial tool 0 active and standby temperatures to 0C; Automatic saving after power loss is not enabled
HomeZ G:
; homez.g
; called to home the Z axis
; generated by RepRapFirmware Configuration Tool v2 on Sun Nov 18 2018 18:17:17 GMT-0800 (Pacific Standard Time)
G91 ; relative positioning
G90 ; absolute positioning
G1 X3 Y-8 F6000 ; go to first probe point
G30 ; home Z by probing the bed; Uncomment the following lines to lift Z after probing
;G91 ; relative positioning
;G1 S2 Z5 F100 ; lift Z relative to current position
;G90 ; absolute positioningHomeall G
; homeall.g
; called to home all axes
G1 S1 X-655 Y355 F1800 ; move quickly to X and Y axis endstops and stop there (first pass)
G1 X5 Y-5 F6000 ; go back a few mm
G1 S1 X-655 Y355 F900 ; move slowly to X and Y axis endstops once more (second pass)
G1 X3 Y-8 F6000 ; go to first bed probe point and home Z
;G90 ; absolute positioning -
The output of the Pinda should be connected to Z_Probe_In. The reading should be zero when the probe is not triggered, and a high value (normally 1000) when it is triggered. If you find that it is reversed, add or remove parameter i1 to the M558 command. See https://duet3d.dozuki.com/Wiki/Test_and_calibrate_the_Z_probe.
Just so I'm starting out right I have configured in the REPRAP configuration for "Simple modulated IR Probe".
The M558 command did not have I1 in it so I added it at it looks like this "M558 P2 H5 I0 F360 T6000" When I put the "I1" the Z-Probe reading shows "1000 (948)" so I switched it to "I0" as shown above in the M558 Code, then it reads "0 (948).
The Z-probe is connected to the "Z_Probe-Mod" and the light on the Pinda probe is lit up. When I put a metal object to it the light goes out but the value displayed does not change.With the wiring hooked to the "Z_Probe_In" the light does not illuminate on the Pinda Probe. The Z Probe reading shows "0 (885)" with the "M558 P2 H5 I0 F360 T6000". When the "I0 is changed to "I1" the z-probe reads "1000 (885)"
In all the configurations I have tried I cannot get the values of the Z-Probe to change when trying to trigger the probe with a metal object.
@pc-6 said in Z Probe trouble:
As dc42 says it should be connected to Z probe In.
Also its not a modulated IR probe but an inductive probe:
I have now connected to the "Z_Probe_in" (Light on the probe is off) and changed the M558 P5 H5 I1 F360 T6000 and still cannot get Probe to trigger. Z Probe reading always at 0
@pc-6 Do you have a v1.04 board then? If not, then that link that @T3P3Tony posted up indicates that for a capacitive sensor like that, you need a diode.
I'm more watching this, as I am looking at different possibilities for a Z probe on my MakerBot clone printer. I have a piezo Z probe on my leadscrew printer, which works pretty much as expected, but I have a capacitive sensor that I'm thinking of using. In my case, I have a v1.03 board, so I'd definitely need the diode.
Pictures of your connection and probe may help people diagnose it.
You say that the probe does not light up. There should be a minimum of 3 wires going to the probe. It ought to have +Vcc, Ground, and a signal wire. +Vcc should be connected to an approprieate voltage source, as dictated by your probe's documentation. It seems that the Pinda probe should operate on 5V, so it is not appropriate to run this from the +Vcc on the Z probe connector, as this is 3.3V. You should be able to grab +5V from the PanelDue connector next to the Z probe input. You can use the ground and IN pins from the Z Probe connector though.
I do have the 1.04 board. The light will illuminate if I plug the signal into the Z_PROBE_MOD but this is not the correct location, when it is in the Z_PROBE_IN is when it does not light up. I am pulling 5V power from the V Fan Jumper because I have a PanelDuo attached.
A picture of it is not very realistic as it is installed in a case with a huge mass of wires making it exceedingly difficult to photograph ( I tried and I can discern much from the photo) and the Probe is from a Prusa MK2s, (Not much to look at) -
Are you certain that you don't have the connections to the Ground and Out wires swapped? What colours are those wires?
@pc-6 googlein this a bit I found:
http://opinionbypen.com/demystifying-the-prusa-pinda/
Does this match your probe?
http://opinionbypen.com/wp-content/uploads/2017/07/PINDA-A.jpg -
Well thank you all for your help. With dc42 suggestion and Link to wiring diagram from T3P3Tony I have it fixed. I had the black and blue crossed. (So much for making black the standard ground or negative).
All is working as it should.Cheers everyone.
Leif -
This post is deleted!
