Problem tevo little monster stepper motors adjust
Hello
I have a Problem with my Delta Printer.
(M92 X80 Y80 Z80 E798 Set steps per mm)It always hits the underlying layer when printing.
I had set everything after a video on Youtube:
https://www.youtube.com/watch?v=BgkJVgFnPaESo scratch with the nozzle and then everything falls off the pressure bed.
I measured a height difference of about 0,33 mm.
Means I simply measured with the calliper at different heights.
Under Extrusion is because I tried to solve the problem.
Are you saying that the bed is to low at one end and to high at the other?
Or is there anything else that can lead to the problem?
So I mean besides the belt and the stepper motors and the print quality?
So more settings except the Z height? -
check your steps per/mm for the extruder, as it seems to high for a 1.8deg motor with titan extruder
@roth said in Problem tevo little monster stepper motors adjust:
Looking at the perimeters, I think it is over-extruded, not under-extruded.
