Try to compile firmware: delay() not defined
I'm trying to compile RepRapFirmware. So far I could build CoreNG, FreeRTOS and RRFLibraries. When I now try to build RepRapFirmware I'm facing the problem that in the function delay() in MassStorage.cpp and the function micros() in FileStore.cpp are not defined. I was also not able to find the definition in the source...
Any suggestions?Best regards,
Marc
Try using the v2-dev branch of the RepRapFirmware project, and the main branch of CoreNG.
Thanks, for the support. This solved the above problem. However now I'm missing
#include "General/SafeStrtod.h"
#include "General/SafeVsnprintf.h"
#include "General/StringRef.h"referenced in the file RepRapFirmware.h
Add project RRFLibraries to your Eclipse workspace.
Thanks and sorry, that would have been an easy one to figure out myself. However now I'm stuck with numerous warnings of the form
C:\Eclipse\Firmware\RepRapFirmware\src/Platform.h:711:36: error: 'MaxTotalDrivers' was not declared in this scope
and the consecutive errors....
Which board are you trying to compile for?
Duet Wifi, but I tried to build all i.e.
make -j8 all
The Duet085, Alligator and RADDS configurations don't build. I haven't deleted them yet in case someone else wants to work on them. In particular, there are a few RADDS users interested in getting RRF 2.x running on it.
