G30- Height correction question
Hmm, that doesn't look right. Can you try a large H parameter, perhaps 1mm if that won't damage your printer, and test again?
Which firmware version are you using?
@dc42 said in G30- Height correction question:
It really seems not to pay any attention to the H-factor at all... I now tried different settings with H from 0 up to 5 and i always got ~ the same result...
This is the code I used (in a macro as well as in bed.g):
[CODE]
G1 Z10 ; lift Z=10 to prevent crashing the probing pointG1 X15.50 Y228.60 F15000 ; go to defined probing point independent of floating bed
G30 X15.50 Y228.60 ; define this point as Z=0G30 P0 X-9.957 Y239.998 H0 Z-99999 ; probe point P0
G30 P1 X332.043 Y239.998 H0 Z-99999 S2 ; go to defined probing point 2 and do: S2 - Adjusting; S-1 ReportG1 X45.457 Y8.602 F15000 ; go to probing point on floating bed
G30 X45.457 Y8.602 ; define this point as Z=0
[/CODE] -
What type of Z probe are you using?
It is an original Bl-Touch. Homez / homeall works great also with the defined Offset...
So is this a firmware fault or is there something wrong I made? Tried to level the 0.241 mm by aluminium foil, but this didn't work that fine...
greetings kuhni -
I just checked the code and also re-tested the manual bed levelling adjustment wizard, which uses the same code as the leadscrew adjustment. It's working for me, using firmware 2.02RC3.
I am now also on 2.02 RC3.
It works for me as well, but still the H factor isn't calculated. I already wrote it in your release post of the 2.02RC3 (if you want to, we could also discuss it there?)2 examples:
G30 P0 X20 Y20 H0 Z-99999 ; probe point P0 G30 P1 X20 Y20 H0 Z-99999 S-1 ; go to defined probing point 2 and do: S2 - Adjusting; S-1 Report
Results: G32 bed probe heights: -0.005 -0.008, mean -0.006, deviation from mean 0.001
Here are both H-factors 0 for both points. This should result in no difference.
Now the 2nd test:
G30 P0 X20 Y20 H0 Z-99999 ; probe point P0 G30 P1 X20 Y20 H1 Z-99999 S-1 ; go to defined probing point 2 and do: S2 - Adjusting; S-1 Report
Results: G32 bed probe heights: -0.003 0.002, mean -0.000, deviation from mean 0.002
Here is P1 with H1 instead of H0. So the report should be at least at a difference of ~1 mm. But The results are still almost the same?
Is there maybe an interference with the G31 command as there is a Z- Trigger Z height defined? -
What I meant was that the H corrections work for me. This is my usual bed.g file:
M561 ; clear any bed transform G0 X20 Y0 Z28 F10000 G30 P0 X-80 Y-100 Z-99999 G30 P1 X80 Y-80 Z-99999 G30 P2 X0 Y75 Z-99999 G30 P3 X-80 Y200 Z-99999 G30 P4 X80 Y200 S3 Z-99999 G0 X0 Y50 Z28
Running this gives me:
G32 Manual corrections required: 0.00 turn up (0.00mm) 0.03 turn up (-0.03mm) 0.05 turn up (-0.05mm)
If I change bed.g to this:
; bed.g M561 ; clear any bed transform G0 X20 Y0 Z28 F10000 G30 P0 X-80 Y-100 Z-99999 G30 P1 X80 Y-80 Z-99999 G30 P2 X0 Y75 Z-99999 G30 P3 X-80 Y200 Z-99999 H1 G30 P4 X80 Y200 S3 Z-99999 H1 G0 X0 Y50 Z28
then it gives me:
G32 Manual corrections required: 0.00 turn up (0.00mm) 0.63 turn up (-0.63mm) 1.22 turn up (-1.22mm)
So the H values are definitely having an effect.
I think that there may be a problem because I am using 2 independent leadscrews...?The important values of my config.g are:
; Leadscrew setting M584 X0 Y1 Z4:2 E3 ; Define drive mapping- Z= driver number 2 and 4. M671 X-77:297 Y20:20 S3 ; Set position of the leadscrews ; BLtouchZ-Probe M307 H3 A-1 C-1 D-1 ; Disable the 3th heater on PWM channel for BLTouch M558 P9 H5 F180 T15000 ; Set Z probe type/mode 9. H=Dive Height. F=Speed the bed moves G31 P25 X+26.9 Y5.935 Z1.065 ; Set Z probe trigger value, offset and trigger height
Now did the same test again:
M561 G30 P0 X20 Y20 Z-99999 G30 P1 X200 Y20 S-1 Z-99999
and
M561 G30 P0 X20 Y20 Z-99999 G30 P1 X200 Y20 H20 Z-99999 S-1
Results were:
G32 bed probe heights: 0.147 0.155, mean 0.151, deviation from mean 0.004 G32 bed probe heights: 0.137 0.145, mean 0.141, deviation from mean 0.004
So it seems, that as soon as you define independent leadscrews, the H-factor isn't taken into account any more?
greetings kuhni
something else, I just found out:
I can do a trick:M561 ; clear any bed transformation G31 P25 Z0 ; set trigger height to 0 G30 P0 X20 Y20 Z-99999 ; probe 1. point G31 P25 Z10 ; set trigger height to 10 G30 P1 X200 Y20 S-1 Z-99999 ; probe 2. point and tell result G31 P25 X+26.9 Y5.935 Z1.065 ; correct trigger height to standart
Results:
1. Both Z = 0: G32 bed probe heights: 1.205 1.227, mean 1.216, deviation from mean 0.011 2. 1. Z = 0; 2. Z = 10: G32 bed probe heights: 1.205 -8.767, mean -3.781, deviation from mean 4.986
So this seems to work...?
I think I have spotted the problem. It looks to me that H parameters on G30 commands may not work if your system uses a deployprobe.g or retractprobe.g file. If I confirm this, I will fix it in the 2.02 release.
