Config Limits
Hi all,
Is there a lower limit on the jerk values that can be set using M566 command?
I have this line in config.g
M566 X1000 Y1000 Z12 E6:6But when I send M566 from DWC or Paneldue it returns like this.
M566
Maximum jerk rates: X: 1000.0, Y: 1000.0, Z: 60.0, E: 60.0:60.0I cannot set E axis jerk below 60.
Firmware Electronics: Duet WiFi 1.02 or later + DueX2
Firmware Version: 1.21 (2018-03-21)
WiFi Server Version: 1.21
Web Interface Version: 1.21-RC4Thanks in advance.
The minimum jerk speed supported in current firmware is 0.1mm/sec.
@dc42 Thank you.
But why does it return only 60? even though in config it is 6? -
Perhaps because you are not using current firmware?
@dc42 Ok,
Was it different in the previous ones? -
Ok I got it, i was just reading it. Sorry for the trouble.
