CoreXYUVWA - 3rd gantry homing SOLVED
One other thought. Do I need to even bother with stall detection? I don't need precise positional accuracy - just to prevent hard crashes in the event that this gantry gets knocked out of position when the power is off. So I'm thinking that if I just set physical stops at the axes minima, stet motor currents really low, then do a long slow move so that the gantry will always hit the stops no matter where it started from, and simply let the motor stall and stayed stalled for as long as it takes to complete the move. Would that harm the motor or driver?
I'd do this first with only those motors mapped to XY, then do the "normal" XYUV homing as I do now then assign all 3 motors to XY. Then put all the motor currents back up.
@dc42 said in CoreXYUVWA:
I'm not sure you need new kinematics or even additional axes. How about this:
- Home the existing axes as normal, with just the original XY motors assigned to X and Y
- To home the new motors, temporarily assign them to the XY axes instead of the other motors (M584), switch to using motor stall detection for X and Y (M574), and home them (you will need to have the new motors connected to the internal drivers to use stall detection - perhaps the UV motors can use the CONN_LCD connector)
- Then assign both the original and the new motors to X and Y.
What I don't see here is how to get around the limitation stated in documentation of
M584
On the Duet WiFi and Duet Ethernet, if you configure multiple drivers for an axis, either all of them must be TMC2660 drivers on the Duet or a Duet expansion board, or none of them must be. This is to facilitate dynamic microstepping and other features of the TMC2660.
Because at print time the X and Y axis would have to be combined of three motors each (real X/Y axis, U/V for extruders plus W/A for counter-weight). Plus Z and 5 extruders this would use all 12 available steppers but at least two of them would not be on Duet or DueX5 but on
CONN_LCD
. What am I missing? -
The problem with mixing TMC2660 and other drivers on the same axis is that any M350, M906, M913 or M915 you send for that axis would be rejected. Also, external drivers need extended step pulse timing, which isn't ideal if you want high speeds and/or high microstepping.
The best bet may be to use the 2 external drivers for extruders. Or talk to us nicely about beta testing the next generation Duet a few months from now
If these external drivers are TMC2660-BOB (breakout boards), would that work? I think they would have to be integrated via SPI but then this should work better than arbitrary other drivers, shouldn't it?
@deckingman Time to polish up your flirting.
CoreXYUV with 5 extruders and a mixing hot end is sitting here ready and waiting. By that time it will have this additional gantry too. (And possibly the other thing that I have mentioned). In a reciprocal arrangement, if you talk to me nicely, I might even convert it from 3 lead screws with a single Z motor, to 3 independently driven screws. Oh, and why not 5 filament monitors as well.
I have a plan.
For now, and to get this up and running I'll just drop back to the 3 colour Diamond and wait for the Gen 3 duet to go back to 5 (or more) colour. Then I can use 2 of the existing E motors to drive this additional gantry. If I'm desperate to use the 5 colour, I can always swap the 2 sets of stepper wires and change the configuration back to what it s now.
Also, although not particularly related to this thread, I'm redesigning the top section so that the filament spools will sit on the sides, rather than the top. So this extra gantry can sit more or less where the top of the printer is now without having to extend the height significantly. This also shifts the weight of the spools (up to about 6Kgs depending on how full they are) down by about 300mm, so lowering the centre of gravity, which will help with stability.
@deckingman said in CoreXYUVWA:
I don't think so. The moving mass should be as low as possible (ie close to the ground, which can be seen as the pivot of your 'shaking' machine), but static mass should be as far as your can from this pivot. This way, you increase the moment of inertia, and it becomes more difficult to move (shake) the machine
This is how tightrope walkers don't fall: they use a large stick, to increase their moment of inertia. Same, it is easier to keep a stick standing on your finger if it has a mass on its top. You can make the test with a simple M8x300mm threaded rod. With and without nuts at the top. You'll easily see the difference.
This post is deleted! -
@fma Moving the centre of gravity downwards inherently helps with stability, making the machine less top heavy and reducing it's tendency to "sway". I'm also moving the mass away from the centre line towards the sides. And I'm reducing the overall height of the machine. As well as aiding stability, moving some of the mass lower down will also reduce any flexing of the upper part of the frame, compared to having more mass at the top.
Don't forget that once it starts to "sway" the entire machine becomes a moving mass and is no longer static. So moving some of that mass lower to the floor will reduce it's tendency to sway.
What you describe with the nuts on a threaded rod and tightrope walkers applies when the contact point (tightrope or finger) moves. In this case, the floor doesn't move, so maybe a better analogy would be a low centre of gravity car vs a high sided SUV. Which one do you think can go faster round corners before it rolls over?
About the height of the machine, only the distance from the floor to the moving mass matters. If the moving mass is still at the same height, total height does not matter.
And moving rolls lower will make them easier to energize, so what you gain on one side is lost on the other.
This is not a trivial problem!
Good luck
PS: your car example is different, and the maths are much easier (this is more or less a static problem).
@fma The car example is just fine. Take two vehicles of the same mass, with the same friction and apply the same force. The one with the high centre of gravity will roll more and topple more easily than the one with the low centre of gravity. But I'm not going to argue. If you think that raising the centre of gravity makes a more stable structure than lowering it, that's fine by me. You believe whatever you want. I'll do what I normally do and ignore the people who say it won't work and build it anyway. It's been a pretty good strategy so far.
I don't say that the car with the lower center of gravity is better in this case (of course it is not!), but this is not the same problem with your printer. In the printer case, this is a mode excitation problem; in the car example, this is a static problem.
What you really need to do, is ensure your rolls don't move (except turning). If they do, you will have troubles, whatever the position you put them.
Another (and I hope) better example: a door. Is it easier to push it close to the lids, or close to the handle? Changing the position where you push it is the same as moving the mass away from the point where you push.
The only issue of all this is resonances: you need to stay away from them, whatever you do.
And putting a mass at the rotation center (bottom of the printer) don't help at all regarding the rotation!
It work in both directions. I'm just trying to point some common problems with excitation and mass positions, that's all. I also have a tall printer, and I already experimented this. And tightrope walkers too.
In fact, I think you agree with me, because intuitively, you plan to put your dynamic system (third gantry) on the top, not on the bottom
And his system is great: it has been used for years on buildings, in japan, to stabilize them during earthquakes. And the mass is on the roof, not in the basement! They have to measure the earthquake vibration, as they don't know it. In your case, you know the vibration: it is the movements of the lower gantries. Moving this mass in the exact opposite direction as you plan to do is enough, and the gain will be very important.
About resonances. For a given total mass, the resonance will only depend on the relative position of the moving mass and the static mass (center of gravity) regarding the rotation center. Again, this is a simple level arm problem (door): the closer to the rotation point the static mass is, the higher the resonance frequency is. The further to the rotation point the static mass is, the lower the resonance frequency is.
you can look how japanese skyscrapers pretect against earthquakes, this may give additional ideas. For example Abeno Harukas:
- strong supporting pillars (we already discussed concrete sockets...)
- knots in the structure reduce vibrations
- hydraulic shock absorbers in the lower floors
- corrugates steel plates in the middle
- pendulum dampers hanging from the top
@fma haha we had the same idea with japanese skyscrapers!!!
But I would add the masses at the bottom...
Because this minimizes risk that the hole building is falling. Japanese building are protected against the earthquake, but not against falling of the building as a whole.There is a difference between the skyscraper and Ian's printer: whether it is fixed at the bottom. (The size is simlar )
Another silly idea, more for David: what about dynamically analysing the vibration of the structure, and reduce accelerations/speeds, as you do for reducing ringing?
It maybe be complicated, and CPU consuming: maybe just a calibration tool, to find the limits for the config file? Not that silly, after all... Such tools exists on industrial brushless motors drivers, to automatically find the correct PID: they move back and forth, from slow speed to high speed. I guess they use encoders and back EMF. Here, we need an external sensor.
Saying that, Ian, I think you should completely remove the spools from the printer: as their weigh change, it will be more difficult to stay away from resonance, as its frequency will vary
...the resonance will only depend on the relative position of the moving mass and the static mass (center of gravity) regarding the rotation center. Again, this is a simple level arm problem (door)
There are two points away from the rotation center: up or low of it, so both of you are right.
The resonance frequency is a good point: a CNC constructor said that mixing steel and aluminium has the advantage that the resonance frequencies are different and the combination of the two materials lower total vibration. Adding connections between the extrusions with a different material may be a good method to lower vibrations also.
@joergs5 said in CoreXYUVWA:
Because this minimizes risk that the hole building is falling. Japanese building are protected against the earthquake, but not against falling of the building as a whole.Yes, if the system fails, them it is worth. But this system does exist, I saw some many years ago. They may have drop it...
I took as principle that the printer does not move on the floor. It is easy to do, using EPDM discs or so. But it is maybe better to let it move on the floor? If it can't, the frame will twist, leading to geometrical issues. If it can roll on the floor, it may not twist as much? Problem: it may cross the room!
No! The rotation center is on the floor, as the feet don't move... The rotation center is not the center of gravity!
@fma Thanks, I understand. I thought you mean the moving mass (hotend level) as rotation center.
