Creality CR-10 upgrade
A heater fault will also pause the print.
If you look in the GCode Console page of DWC, there should be a message giving the reason for the pause.
Having another issue.
When i log in to DWC from android phone, there is no button to upload gcode files. Tried multiple browsers (opera, chrome). -
@agniusm said in Creality CR-10 upgrade:
When i log in to DWC from android phone, there is no button to upload gcode files. Tried multiple browsers (opera, chrome).That is correct but it is not really a bug - in fact there is just not enough space to display all the upload buttons in the same way as on on desktop PCs. I've never heard of anyone trying to upload G-code files on a cell phone so I haven't considered to add it back yet. How do you get the G-code file on your smartphone?
Well, was one of the reasons i bought wifi. My printer is off site doing 60h prints 24/7 and sometimes i need to update gcode files with improvements and that button is vital.
What do you mean how do i get it on the phone? That question would probably be relevant back in 2006 Here:
Via usb
Via flash drive and usb converter
Via micro sd
Via lan network sharing
Via remote desktop (team viewer)Now its a pain. I have to shutdown, pull out sdcard, pu it into my phone etc.
Another note is that it does not appear not only on mobile version of dwc but full one as well on smartphone. Weird -
DC42, is there a way to set duet port othe than 80? I see it was possible with older releases. Having no option on mobile device to upload gcode files i got couple router and ubiquiti is using 80 for web interface so i need something else on duet for port forwarfing
I would also strongly request adding upload option from modile devices.
See the description of the M586 command in the GCodes wiki page.
Please make that request in the DWC Wishlist section.
So my upgraded printer is working 24/7 great. Had a fan failure but that was to be expected with cheap chinese stuff. Got a small issue i was putting off for some time. i have mesh compensation in place and it works great but i have my front off the bed not completely working with this.
Here is 2 same run parts, one from the middle of the bed(rest are same good) and one from the front (on the right). The nozzle is a tad off when printing on the front of the bed:I was wandering where i should look for the issue? I know my grid is set wrong as it misses some points(skips them). Would that cause an issue?
Otherwise i am very happy with Duet hardware and the way i can edit my configs on the fly, i can really appreciate that now since i am working on Marlin firmware for my budget cluster.
P.S. perhaps the tool to calculate mesh grid appeared for square build plates? That would be handy. or is there any plans on automatic calculation of the mesh? Say you enter how many grid points on x and y and it sets spacing? Would be even better. i think Marlin does that
I know my grid is set wrong as it misses some points(skips them). Would that cause an issue?Any probe points that cannot be reached by the probe (taking into account the machine limits set by M208 and the Z probe offsets set by the G31 X and Y parameters) will be skipped.
Good idea, I'll add it to the work list.
David, we were brainstorming a method for e3d toolchange and how we can automate tool offsets for different tools. Perhaps you have a solution but i got an idea i would like to test as it is relevant to me too.
I want to mount precision piezo disc on my frame where my extruder can reach and probe it to set the height of the nozzle then use inductive probe for mesh mapping. This way, each time i swap the nozzle, i dont have to readjust z offset as even quarter turn of the nozzle throws calibration away.
How can i implement this in duet settings? -
Have you looked at https://duet3d.dozuki.com/Wiki/Gcode?revisionid=HEAD#Section_M585_Probe_Tool ?
Actually just yesterday was going through gcode wiki and saw this one. I will investigate.
How can i implement this in duet settings?Are you using E3D hotends? The nozzle should tighten against the heat break so provided the nozzles are all the same length from end to tip, they should all tighten to the same distance.
@tjb1 Yes. Using e3d. Even if so printing different materials can have impact(thermal expansion) PLA vs PC can be 100C difference. This idea came thinking about e3d toolchanger. I was not specifically wanting to do this on my machine, but I had precision piezo kit and thought I will test the idea. Actually it will be handy if it works the way I think. Sometimes I need to change a fan and it is mounted with induction probe. Even if I do not touch induction probe out of the clamp it still needs recalibration.
@dc42 I want to place my probe slightly below my bed so it is out of the way. So my macro should look something like this:G28 ; home
G10 P0 Z0 ; clear Z offset
T0 ; select a tool
G1 X430 Y0 Z10 F3000 ; move above probe
M585 Z F400 E2(cant remember which is asignet to z stop(2?) and which to z probe) ; drive into probe
M500 ; save new offset
G1 Z20 ; lift the tool not to drive into bed edge
G28
M98 Pmeshbed.g
One thing I'm not sure about how to add extra distance if my probe is say 10mm below my bed. -
You could use G1 to move the nozzle to be above the switch at Z=5. Then send G92 Z15 to pretend it is at Z=15. Use the M585 command to probe the switch. Then do G1 Z15 followed by G92 Z5 to remove the 10mm Z offset.
@dc42 thanks. A work around then
How should i set my probe in M585 E if i connect my probe to Z probe 4 pin connector near paneldue connector? My stop endstops are all pupulated. -
How should i set my probe in M585 E if i connect my probe to Z probe 4 pin connector near paneldue connector? My stop endstops are all pupulated.I suggest you use one of the endstop inputs on the CONN_LCD connector.
@dc42 Good note. Had no clue there were extra inputs. So i can take +3.3V, gnd and say stop 11(ENC_A) and in M585 E11? This is for precision piezo
Do i need to define precision piezo in config.g? At the moment i have my induction probe:
M558 P4 I0 F300 X0 Y0 Z1 T7000 ;
should i need to add:
M558 P1 I0 R0.4 F300 X0 Y0 Z0 ; Set precision piezo probe
