Dave's so proud
i did but thats what board is reporting
@sjason1377 said in Dave's so proud:
So that tells you that the firmware did not get updated.
Double check you are trying to upload the 2.01 version and try again.
RepRapFirmware for Duet 2 WiFi/Ethernet
Firmware Electronics: Duet Ethernet 1.02 or later
Firmware Version: 2.01(RTOS) (2018-07-26b2)
Web Interface Version: 1.21.2-dc42ok guess what probe doesn't work still
M574 X1 Y1 S1 ; Set active low endstops
M574 Z0
M558 P9 X0 Y0 Z1 H5 F100 T2000 ; Set Z probe type to switch, the axes for which it is used and the dive height + speeds
G31 P600 X0 Y12 Z.96; Set Z probe trigger value, offset and trigger height
M557 X52:300 Y60:335 S40 ; Define mesh grid -
This post is deleted! -
Web Interface Version: 1.21.2-dc42 -
M574 Z0
M557 X52:300 Y60:335 S40 ; Define mesh gridcorrect version and correct wording in config.g probe is unresponsive. a year of flawless performance under build 1.19.1 and now nothing.
M574 Z0
The current docs for M558 report that the X, Y and Z parameters are obsolete.
Perhaps that is causing some sort of problem?
I would never had upgraded except for those false heater faults he said was a bug from the old version. Now he's got no support for this problem because he won't admit there is one. That my issue. It take many failures from many user before he responds. History proves I was not at fault before. I'm not now either.
I'm not proud I'm not saying I have any answers. I know my spelling sucks. But I'm no liar. We depend on him to help with these issue. But where does that leave us when he won't help.
Do you expect David to drop everything in his real life to help one of the rudest users ever to come on these boards?
You need to learn to be patient, and/or how to resolve issues yourself.
Ooops... just read the whole thread from the top.
BYE.
You want support from the community, you need a whole different attitude.
M574 Z0
Do you have a Z endstop in addition to the Z probe?
In the M574 Z0 there is no S parameter - which indicates an active high endstop - is that correct?
yes that's correct. I went back to p7 and it works now
@deckingman eat my load!
Did you try the latest version after removing the obsolete parameters from M558?
And you do have a Z endstop in addtion to the Z probe?
@sjason1377 Thanks for this chat message
"hey decking eat my nut load bitch"
Like I said, I'd like to help you but only a qualified psychiatrist could do that.
Following an email where I asked sjason1377 to stop abusing/attacking people on the forum he continued with this behaviour so I have banned him.
