Resurrect.g problems
Sorry I should have stated I am using firmware v2.01
Thanks thats what I have been trying to follow but when I try to home Z using g30 its showing z position as -15.01 when z probe is triggered is this correct?
regards
Arthur
@flyingscot said in Resurrect.g problems:
regards
Arthur
That sounds odd. What exactly are you doing in resurrect-prologue.g to home Z? I presume you are positioning the head clear of the print for homing.
I maybe have it wrong I though I had to home machine manually to stop head crashing into job.
so I homed x & y with buttons and moved head to a clear position and ran g30 from console.arthur
Oh thats the other problem I only have resurrect.g no resurrect-prologue.g Do I have to re-name it?
@flyingscot No these are two separate files.
resurrect.g
is created for every paused print anew whereasresurrect-prologue.g
will be a generic set of instructions being equal to all resurrected prints. Typically these contain at least the homing process with a partial build on the build plate and then also contain an arbitrary amount of additional commands that you might need to do whenever you have to restart a failed print.For reference mine looks like
G28 XY ; Home X and Y regularly G0 Y230 ; Move Y to the front maximum G28 Z ; Home Z now where the head has least chance to hit something
ok nearly there I think I now have a resurrect-prologue.g file as below.
the clear area for z probe is X205, Y 2. so X & X home ok then the head moves to X205, Y2 but then tries to home Z in the middle of the bed where the job is.
I read that z coordinates cant be used with g28 z so how do you stop it heading to its normal home z position?resurrect-prologue.g
G28 XY ;Home X & Y regularly
G0 Y2 ;Move y to front of bed
G0 X205 ;Move X to clear area
G28 Z ;Home Z where head has least chance of hitting anything -
@flyingscot
G28 Z
will simply run/sys/homez.g
. So you might have to modify this?! I don't have a Z probe just a simple microswitch endstop so to home Z my axis just lowers until the switch is hit independent of the heads position. So I cannot tell you exactly what is the best in this case. -
@wilriker said in Resurrect.g problems:
@flyingscot
G28 Z
. So you might have to modify this?!Just copy the contents of homez.g into the resurrect-prologue file in place of the G28 Z command, removing or adjusting any commands that position the head in XY before executing the G30 or G1 S1 Z command that does the actual homing.
@dc42 said in Resurrect.g problems:
Just copy the contents of homez.g into the resurrect-prologue file in place of the G28 Z command, removing or adjust any commands that position the head in XY before executing the G30 or G1 S1 Z command that does the actual homing.
That makes a lot more sense than my idea.
Too hot -> brain-melt -> going home now (or into the fridge?). -
Success, thanks for all your help Guys
