24v Heatbed with 12v everything else
@t3p3tony If I don't have it on hand I'll just do it the previous way. Aliexpress takes at least 2 weeks to ship to me and I have everything else ready to go.
Edit: Sorry I completely misunderstood what you were saying. I googled around and couldn't find much either.
@vaei said in 24v Heatbed with 12v everything else:
yeah basically i think its fine to use this as you plan, switching 24V as long as you get no where near the 24A maximum. but that is based on a guess... no data sheet available.
@t3p3tony Hm so what would I do about the incredibly slow heating?
@vaei Insulation?
@phaedrux I don't get what you're asking
Put a thermal insulation to the underside of your bed.
@vaei Something like this
http://www.instructables.com/id/Insulate-Your-3D-Printers-Heated-Bed/
If you are using PID rather than bang bang mode, then tuning the heater might help to speed things up - depends on what the default PID values are. Another thing that can help is re-positioning the bed thermistor - especially if you have a thickish heat spreader. Often bed heaters have a thermistor built in but what happens is that it senses the temperature close to the heater element which rises quickly, so the heater shuts off early.
Best to confirm that it is the bed that is the issue. As @Phaedrux has suggested earlier you can temporarily connect the bed directly to the power supply and time how long it takes to heat up.
The bed I bought didn't have a thermistor, so I bought a separate one and I think the issue could also be the values being entered incorrectly. I'll have to measure the coefficients. But.. right now I have no time whatsoever (and sorry for the delayed response), I'll have to get back in a week or so.
