Water cooling flow sensor with Duet
@zerspaner_gerd said in Water cooling flow sensor with Duet:
Unfortunately, I find nothing about the RPM monitoring, Can you share a link so I can read.I've added some text about RPM monitoring to the page on connecting and configuring fans.
Thank you very much @dc42, that helps a lot.
The Flow Sensor has only 3 cables (GND, VIN, signal), do I need any invert PWM of fan?
And how can I read out the PIN
PB6
so that a trigger is triggered at PWM 0?I could not find a PIN number here either.
https://duet3d.dozuki.com/Wiki/Using_servos_and_controlling_unused_IO_pinsI understand that correctly, to leave the permanently connected I need a signal diode.
You don't need to configure a pin number, because pin PB6 is pre-configured for a fan RPM sensor. If the flow sensor uses greater than 3.3V power, use a diode between its output and PB6.
And how can I imagine monitoring?Would be at a loss how I should implement that.
I have to create a reaction somewhere.
Hello @dc42 ,
How can I work with the RPM signal.
It will now be displayed in DWC.
Now I need a way somehow trigger a Macro. -
Currently the firmware does not have any facility for taking an action based on the RPM reading.
It should be easy to build one, using an integrator (simple capacitor?) and a trigger, sending the signal on an unused endstop, which can in turn activate a macro...
@dc42,
Okay then I know that.
Thanks@fma said in Water cooling flow sensor with Duet:
That sounds good but I have no idea how to build something like that.
In fact, a board based on a 555 is even better:
https://www.qwant.com/?q=555 missing pulse detector
David, is it possible to connect the output of the 555 to the endstop input, if the 555 is powered with 3.3V (using a TLC555)?
Yes, that should work.
Thanks! I'm going to make a prototype...
