Incorrect layer times [DWC]
I noticed a strange error in the reported layer times on the DWC. Every other layer has near 0 second time, while I can assure it was not the case in reality hehe. A screenshot of the DWC has been included as well as a M122 diagonostics dump.
- Firmware Version: 1.21 (2018-03-21)
- WiFi Server Version: 1.21
- Web Interface Version: 1.21
M122 === Diagnostics === Used output buffers: 1 of 32 (16 max) === Platform === RepRapFirmware for Duet 2 WiFi/Ethernet version 1.21 running on Duet WiFi 1.0 or 1.01 Board ID: 08D6M-91AST-L23S4-7JTD0-3S86K-1NX1K Static ram used: 16152 Dynamic ram used: 100768 Recycled dynamic ram: 1864 Stack ram used: 3576 current, 7824 maximum Never used ram: 4464 Last reset 06:53:49 ago, cause: software Last software reset at 2018-06-11 12:41, reason: User, spinning module GCodes, available RAM 4432 bytes (slot 0) Software reset code 0x0003 HFSR 0x00000000, CFSR 0x00000000, ICSR 0x0441f000, BFAR 0xe000ed38, SP 0xffffffff Error status: 0 Free file entries: 9 SD card 0 detected, interface speed: 20.0MBytes/sec SD card longest block write time: 488.9ms MCU temperature: min 38.8, current 41.8, max 42.4 Supply voltage: min 11.7, current 12.1, max 12.3, under voltage events: 0, over voltage events: 0 Driver 0: ok, SG min/max 0/584 Driver 1: ok, SG min/max 0/540 Driver 2: ok, SG min/max 0/521 Driver 3: ok, SG min/max 0/1023 Driver 4: standstill, SG min/max not available Date/time: 2018-06-11 19:35:07 Slowest main loop (seconds): 0.491045; fastest: 0.000046 === Move === MaxReps: 5, StepErrors: 0, LaErrors: 0, FreeDm: 221, MinFreeDm 120, MaxWait: 4280672028ms, Underruns: 0, 0 Scheduled moves: 132015, completed moves: 132010 Bed compensation in use: none Bed probe heights: 0.213 -0.108 -0.133 0.127 0.166 === Heat === Bed heaters = 0 -1 -1 -1, chamberHeaters = -1 -1 Heater 0 is on, I-accum = 0.0 Heater 1 is on, I-accum = 0.8 === GCodes === Segments left: 1 Stack records: 3 allocated, 0 in use Movement lock held by null http is ready with "M122 " in state(s) 0 telnet is idle in state(s) 0 file is doing "G1 X-76.788 Y73.317 E0.00403" in state(s) 0 serial is idle in state(s) 0 aux is idle in state(s) 0 daemon is idle in state(s) 0 queue is idle in state(s) 0 autopause is idle in state(s) 0 Code queue is empty. === Network === Responder states: HTTP(0) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0) Telnet(0) HTTP sessions: 1 of 8 - WiFi - Network state is running WiFi module is connected to access point Failed messages: pending 0, notready 0, noresp 0 WiFi firmware version 1.21 WiFi MAC address a0:20:a6:16:ec:ed WiFi Vcc 3.36, reset reason Turned on by main processor WiFi flash size 4194304, free heap 15016 WiFi IP address 192.168.178.147 WiFi signal strength -78dBm, reconnections 0, sleep mode modem Socket states: 0 0 0 0 0 0 0 0 === Expansion ===
Is the layer count correct?
Sadly I did not check whether the count was correct. I can for sure say I was not double, so probably it was correct.
@dc42 The same issue is comming up as I am printing right now. I will let you know whether the final layer count is correct. Although KISSlicer doesn't seem to output the number of layers
If there is anything else you need in terms of diagnostics, now would be the time to say it. -
The print finished and the final layer count on the blue progress bar was 115/114. I believe the correct layer count should be 164 however. I'll attach the gcode file so you can verify/experiment.
gcode -
@nxt-1 You say you are using KISSlicer and there is one part in the source code of RepRapFirmware regarding print monitor that explicitly mentions KISSlicer and issues with layer height IIRC. Do you have
M404
(https://duet3d.dozuki.com/Wiki/Gcode?revisionid=HEAD#Section_M404_Filament_width_and_nozzle_diameter) in yourconfig.g
? The values of this command are used in that case to correctly calculate print progress. -
@wilriker said in Incorrect layer times [DWC]:
M404
? The values of this command are used in that case to correctly calculate print progress.I've never head of issues with KISSlicer, I'd love to hear what @dc42 has to say about this. I currently do not have a M404 in my config.g, I'll add that for future prints.
M404 is not normally needed.
The graph shows that about 2 out of every 3 layers took about 35sec and 1 in 3 took zero time until near the end. Is the GCode file using variable layer height?
@nxt-1 said in Incorrect layer times [DWC]:
Just looked it up again and it was not about layer height but older KISSlicer versions do not add info about filament length but only volume and the value of
M404 Nnnn
is used to calculate that back into a length. Sorry, my fault. Did not remember correctly. -
@dc42 said in Incorrect layer times [DWC]:
Yes, adaptive layer height is used.
I still have problems with estimated Print time ans layer time...sometimes all work as intended and on other prints he not count the layertimes and all is messed up..all with the same profile from S3D..very annoying
I think that explains it. The layer count mechanism in the firmware assumes that all layers except the first are the same height.
@barracuda72 said in Incorrect layer times [DWC]:
The layer time is usually the least accurate estimate. The estimate based on filament usage is usually the best.
yes..but theres no layertime at all..first layertime was 37sec...and now my print is at the 2nd layer till 1h 12m so its count only 2 layers.
And that problem i have from time to time..
