New firmware 2.0RC5 available
Nice, thanks @dc42 !
Hi! I've been testing RC5 since the release date and everything works fine. I was previously on 1.21. I found no bug or anything strange to repport.
@3doeste said in New firmware 2.0RC5 available:
Thanks for the feedback!
I don't know if anyone else have this issue, but with the 1.21.1 web interface, I seem to have a hard time controlling the fan speed in the "Machine Control" tab. If I pull on the slider, it would move over, but when I let go it would bounce back to the previous value. I repeat the same process on IE and Firefox and had the same issues. Sometimes if I double click slowly it would stay, but its a bit annoying.
When I move the fans, speed factor or extrusion factor in the "Print Status" tab, I have no problem moving the sliders. The slider in the fan control on the "Print Status" jumps slightly, but nowhere near as often as the "Machine Control" slider.
I don't think its related to RC5, but it seems like a problem with the recent updates.
Firmware Electronics: Duet WiFi 1.0 or 1.01
Firmware Version: 2.0(RTOS)RC5 (2018-05-22b1)
WiFi Server Version: 1.21
Web Interface Version: 1.21.1 -
@shadowx
I have the same problems in Safari.
It looks like for me this annoying bug got worse in the recent updates. -
@dc42 With your advice, uploading the gcode files works without any problems.
The connection problems with DWC are still present.
The funny, on the Tablet (also with chrome and Windows10) comes for a long time no mistake.
On desktop PC this comes more often.I do not understand that.
It seems that the update suspends the web interface but the connection remains.
With combination DWC 1.21.1 and RRF 1.21, the dropouts are not present.
There are problems with this firmware (upgraded from 1.21, so I don't know if it is 2.0 specific or not).
Uploading a file, creating a directory (through DWC or FTP) is not shown in web UI. I've dumped the traffic between the browser and the Duet and indeed the file list does not show the added entries. If using FTP, they are there. If using M32 directly to print they are there.
Old files on the SD card are shown in DWC, but anything new since 2.0RC5 upgrade is not shown.
@sigxcpu said in New firmware 2.0RC5 available:
Example:
Create a folder in
gcodes/Raducu
namedccc
:T 2018/05/24 22:21:48.056786 192.168.27.125:54849 -> 192.168.27.7:80 [AP] #74 GET /rr_mkdir?dir=0%3A%2Fgcodes%2FRaducu%2Fccc HTTP/1.1. Host: 192.168.27.7. Accept-Encoding: gzip, deflate. Connection: keep-alive. Accept: application/json, text/javascript, */*; q=0.01. User-Agent: Mozilla/5.0 (Macintosh; Intel Mac OS X 10_12_0) AppleWebKit/602.2.14 (KHTML, like Gecko) Version/10.0.1 Safari/602.2.14. Referer: http://192.168.27.7/. Accept-Language: en-us. X-Requested-With: XMLHttpRequest. . T 2018/05/24 22:21:48.143654 192.168.27.7:80 -> 192.168.27.125:54849 [AP] #78 HTTP/1.1 200 OK Cache-Control: no-cache, no-store, must-revalidate Pragma: no-cache Expires: 0 Access-Control-Allow-Origin: * Content-Type: application/json Content-Length: 9 Connection: close {"err":0}
Reload shows no
ccc
entry.T 2018/05/24 22:21:48.151622 192.168.27.125:54850 -> 192.168.27.7:80 [AP] #87 GET /rr_filelist?dir=0%3A%2Fgcodes%2FRaducu HTTP/1.1. Host: 192.168.27.7. Accept-Encoding: gzip, deflate. Connection: keep-alive. Accept: application/json, text/javascript, */*; q=0.01. User-Agent: Mozilla/5.0 (Macintosh; Intel Mac OS X 10_12_0) AppleWebKit/602.2.14 (KHTML, like Gecko) Version/10.0.1 Safari/602.2.14. Referer: http://192.168.27.7/. Accept-Language: en-us. X-Requested-With: XMLHttpRequest. . T 2018/05/24 22:21:48.168250 192.168.27.7:80 -> 192.168.27.125:54850 [A] #88 HTTP/1.1 200 OK Cache-Control: no-cache, no-store, must-revalidate Pragma: no-cache Expires: 0 Access-Control-Allow-Origin: * Content-Type: application/json Content-Length: 1992 Connection: close {"dir":"0:/gcodes/Raducu","files":[{"type":"f","name":"loubie_aria_dragon_PLA.gcode","size":6043030,"date":"2017-04-03T19:10:15"},{"type":"f","name":"spaceShuttle1_PLA.gcode","size":1735511,"date":"2017-04-03T22:55:18"},{"type":"f","name":"2part_-_A_head_ABS.gcode","size":4456480,"date":"2017-04-23T22:04:29"},{"type":"f","name":"nema17_support_PLA.gcode","size":1277492,"date":"2017-04-07T13:03:07"},{"type":"f","name":"belt_support_PLA.gcode","size":911789,"date":"2017-04-07T15:22:11"},{"type":"f","name":"plate_and_pillars_PLA 220 (Sacele).gcode","size":2990130,"date":"2017-04-08T00:29:20"},{"type":"f","name":"robot_pillar_PLA 220 (Sacele).gcode","size":1621129,"date":"2017-04-08T14:13:06"},{"type":"f","name":"2part_-_B_body_ABS.gcode","size":6222247,"date":"2017-04-23T23:01:19"},{"type":"f","name":"Variable_Speed_Gears_-_Main_Gear-1_ABS.gcode","size":9204723,"date":"2017-05-01T10:16:23"},{"type":"f","name":"metal_detector_coil_PLA.gcode","size":1589034,"date":"2017-05-06T20:54:17"},{"type":"d","name":"Spinner","size":0,"date":"2017-05-22T02:26:25"},{"type":"f","name":"Hull_Mk6_ABS.gcode","size":3329265,"date":"2017-05-31T15:23:21"},{"type":"f","name":"Finger_Pad_V2_Twisted_Pins_ABS.gcode","size":958387,"date":"2017-05-15T22:36:15"},{"type":"d" T 2018/05/24 22:21:48.271859 192.168.27.7:80 -> 192.168.27.125:54850 [AP] #90 ,"name":"Microscop","size":0,"date":"2017-05-19T01:31:00"},{"type":"f","name":"SphericalIrisBox_PLA.gcode","size":11446362,"date":"2017-05-20T21:24:09"},{"type":"f","name":"Jumping_Turtle_PLA.gcode","size":7794056,"date":"2017-08-10T23:55:16"},{"type":"f","name":"Jumping_Turtle_PLA_0.3.gcode","size":4326095,"date":"2017-08-10T23:59:10"},{"type":"f","name":"Spikey_Top_PLA.gcode","size":2177682,"date":"2017-08-22T20:17:24"},{"type":"f","name":"Rocket_Launcher_PLA.gcode","size":5816173,"date":"2017-08-28T17:56:01"},{"type":"f","name":"Rocket_Launcher_10mm.gcode","size":3424444,"date":"2017-08-29T14:46:10"},{"type":"f","name":"2LiterThreads_1fourth_npt_FINS_righted_PET-G.gcode","size":2229123,"date":"2017-08-30T19:36:09"}]}
Please see this response https://forum.duet3d.com/topic/5394/new-firmware-2-0rc5-available/30.
Thank you for the answer.
I've scanned this thread, but missed that.
Is this a permanent issue or we can expect it to be fixed in the future? I don't know the internals, but I assume that the serialization buffer is small. If it is that, can't you simply generate the JSON on the fly (i.e. streaming)?
Another option is to shrink the JSON. On a machine to machine transfer there is no need to repeat
type
,name
,size
,date
all the time. They can be abbreviated tot n s d
, for example.LE: now that this started me, I dug in the source code.
I see that the big M122 reply is sent at this size:
Content-Length: 2539
My example reply is:
My example with shorted field names is
1739
bytes in size, around 250 bytes smaller.So there are ~550 bytes that could've taken more files to be displayed.
Also the modified times can be encoded as UNIX timestamps instead of formatted, which will reduce that even further, from 21 bytes to 9 bytes per entry.
We can have a parameter in rr_filelist sent by DWC to request short format and implement a list with all the above mentioned optimizations, so things are backward compatible.
I can take a stab at this, without the buffer size part (M122 is big, filelist is small) because I don't know why you've chosen it to be that way.
This will be for a 2.1 release maybe. -
I agree that the protocol is too verbose (I didn't design it) and we are discussing how to fix the issue. Unfortunately it won't be fixed in time for the 2.0 release because the master files are needed tomorrow for SD card duplication.
How do you think this should be integrated?
- create a new command like
rr_compactfilelist?dir=xxx
- add a parameter to existing
rr_filelist
likerr_filelist?dir=xxx&compact=true
I ran into an issue I have never seen before in the 1 series of firmware. I almost always run prints via Octoprint over the usb serial connection. About 3.5 hours into a print the connection died.
I am running firmware 2.0(RTOS)RC5 (2018-05-22b1).
Here was the error on the Octoprint terminal:
Unexpected error while reading serial port, please consult octoprint.log for details: SerialException: 'device reports readiness to read but returned no data (device disconnected or multiple access on port?)' @ comm.py:_readline:2417
In the DWC console it had this:
g-code buffer 'serial' length overflow
I ran an M122 in the DWC console interface:
M122 === Diagnostics === RepRapFirmware for Duet 2 WiFi/Ethernet version 2.0(RTOS)RC5 running on Duet WiFi 1.0 or 1.01 + DueX5 Board ID: 08DAM-999TL-MQ4S8-6J9D8-3SJ6N-15B3W Used output buffers: 1 of 20 (10 max) === RTOS === Static ram: 28452 Dynamic ram: 96644 of which 16 recycled Exception stack ram used: 380 Never used ram: 5580 Task NETWORK ready, free stack 420 Task DHTSENSOR blocked, free stack 36 Task HEAT blocked, free stack 1256 Task MAIN running, free stack 3620 === Platform === Last reset 00:04:46 ago, cause: software Last software reset at 2018-05-24 21:58, reason: Assertion failed, spinning module Platform, available RAM 5284 bytes (slot 1) Software reset code 0x0090 HFSR 0x00000000, CFSR 0x00000000, ICSR 0x0041f80e, BFAR 0xe000ed38, SP 0x2001ffb4 Stack: 2001e6a0 2001e6d4 00445509 00000000 00000000 00000001 20006c68 20006bf4 00444885 2001e6ec 20006bf4 00000000 00f00000 e000ef34 c0000018 00000003 004449c7 00444738 61000000 b082b430 b33b9d04 b2c96804 41b4f041 3480f444 Error status: 0 Free file entries: 10 SD card 0 detected, interface speed: 12.0MBytes/sec SD card longest block write time: 0.0ms MCU temperature: min 46.6, current 46.7, max 49.5 Supply voltage: min 24.0, current 24.2, max 24.4, under voltage events: 0, over voltage events: 0 Driver 0: standstill, SG min/max not available Driver 1: standstill, SG min/max not available Driver 2: standstill, SG min/max not available Driver 3: standstill, SG min/max not available Driver 4: standstill, SG min/max not available Driver 5: standstill, SG min/max not available Driver 6: standstill, SG min/max not available Driver 7: standstill, SG min/max not available Driver 8: standstill, SG min/max not available Driver 9: standstill, SG min/max not available Expansion motor(s) stall indication: yes Date/time: 2018-05-24 22:03:05 Slowest main loop (seconds): 0.372014; fastest: 0.000069 === Move === Hiccups: 0, StepErrors: 0, LaErrors: 0, FreeDm: 240, MinFreeDm 240, MaxWait: 0ms, Underruns: 0, 0 Scheduled moves: 0, completed moves: 0 Bed compensation in use: none Bed probe heights: 0.000 0.000 0.000 0.000 0.000 === Heat === Bed heaters = 0 -1 -1 -1, chamberHeaters = -1 -1 Heater 3 is on, I-accum = 0.0 === GCodes === Segments left: 0 Stack records: 1 allocated, 0 in use Movement lock held by null http is idle in state(s) 0 telnet is idle in state(s) 0 file is idle in state(s) 0 serial is idle in state(s) 0 aux is idle in state(s) 0 daemon is idle in state(s) 0 queue is idle in state(s) 0 autopause is idle in state(s) 0 Code queue is empty. === Network === Responder states: HTTP(4) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0) Telnet(0) HTTP sessions: 1 of 8 - WiFi - Network state is running WiFi module is connected to access point Failed messages: pending 0, notready 0, noresp 0 WiFi firmware version 1.21 WiFi MAC address 5c:cf:7f:2c:27:2d WiFi Vcc 3.38, reset reason Turned on by main processor WiFi flash size 4194304, free heap 15000 WiFi IP address 192.168.2.143 WiFi signal strength -65dBm, reconnections 0, sleep mode modem Socket states: 0 5 0 0 0 0 0 0 === Expansion === DueX I2C errors 0
I know I am weird to still use Octoprint with a Duet Wifi, but I like the various plugins and record keeping that it provides over the DWC interface. Thanks!
Running FW: 2.0(RTOS)RC5 (2018-05-22b1), DWC: 1.21.1
Tested on small print and no issue occured.
Just one glitch on first print (macro with delta calibration, heat and cooldown) when reloading DWC in browser caused "Emergency STOP". But can't reproduce. -
Running 2.0rc5 and dwc121. 1, I have noticed odd behaviour of M122 included in slicer end script. At the end of the print, the M122 report does not appear. The gcode console accepts an M122, but no report. YAT connection accepts M122, and provides a report, but this does not relate to the print, so I guess the original M122 cleared. The DWC console accepts other commands when in the M122 blocked state, and M122 works fine after reset. The effect is seen with S3D and kislicer end scripts.
I just finished a print with a strange message:
Error: G1/G2/G3: intermediate position outside machine limits Finished printing file Upgrades/Spool_Holder.gcode, print time was 4h 9m
X is now reported as being -253.69
My end code is the following
G10 P0 R-273.15 S-273.15 ;extruder heater off M140 S-273.15 ;bed heater off G91 ;relative positioning G1 Z+4 X-20 Y+20 F9000 ;move nozzle away from object G0 S1 X-250 ;move X to the left, so the head is completely out of the way G90 ;absolute positioning G0 Y190 F5000 ;move bed to the front M84 ;steppers off
Could it be that the
G0 S1 X-250
in contrast to aG1 S1 X-250 F3600
that is used in myhomex.g
is the problem here? AFAIKG0
andG1
are aliases on a cartesian setup.This might not be directly related to RC5 but I never had this message before and I have not modified my end code since updating to RC5.
rr_filelist
The solutions we are looking at are:
DWC to revert to using rr_files instead of rr_filelist.
Extend rr_filelist to take a "skip the first N files" parameter, and in the response to return the value of N that should be used to get the next chunk of the file list, with N=0 meaning the list is complete.
Most likely we will implement #2.
@wilriker said in New firmware 2.0RC5 available:
G0 S1 X-250
andG1
What printer geometry do you have?
That message is new in RC5 but I don't think it should ever be reported except for G1 moves on SCARA printers and G2 or G3 moves on any type of printer. Maybe it was the G1 Z+4 X-20 Y+20 F9000 command that provoked it? What was the head position prior to executing that command?
A G0 S1 move should behave the same as a G0 S1 move, but I haven't actually tested it.
@dc42 said in New firmware 2.0RC5 available:
Cartesian
Last movement command in gcode file was
G1 F2250 X16.307 Y159.991 E0.02498
(only followed by aG10
before executing end code)
and Z was at 7.1 at this point.EDIT:
My limits are- X: -35..220
- Y: -7..216
- Z: 0..234
I had canceled a print and then started another using the "Upload and Print" button. As the machine started the print, the controller reset. I can repeat this reliably. This does not appear to be an issue if I manually select a file to print though.
Here are the diagnostics after:
RepRapFirmware for Duet 2 WiFi/Ethernet version 2.0(RTOS)RC5 running on Duet Ethernet 1.02 or later + DueX5
Board ID: 08DDM-9FAM2-LW4SD-6JTDL-3S86R-KJW3X
Used output buffers: 1 of 20 (16 max)
Static ram: 28452
Dynamic ram: 96508 of which 0 recycled
Exception stack ram used: 420
Never used ram: 5692
Task NETWORK ready, free stack 332
Task HEAT blocked, free stack 1200
Task MAIN running, free stack 3556
Last reset 00:04:22 ago, cause: software
Last software reset time unknown, reason: User, spinning module GCodes, available RAM 5764 bytes (slot 0)
Software reset code 0x0003 HFSR 0x00000000, CFSR 0x00000000, ICSR 0x0441f000, BFAR 0xe000ed38, SP 0xffffffff
Error status: 0
Free file entries: 8
SD card longest block write time: 0.6ms
MCU temperature: min 25.4, current 26.9, max 27.1
Supply voltage: min 24.0, current 24.2, max 24.5, under voltage events: 0, over voltage events: 0
Driver 0: ok, SG min/max 0/1023
Driver 1: ok, SG min/max 0/1023
Driver 2: standstill, SG min/max 0/642
Driver 3: ok, SG min/max 0/1023
Date/time: 2018-05-25 13:12:03
Slowest main loop (seconds): 0.082818; fastest: 0.000076
Hiccups: 0, StepErrors: 0, LaErrors: 0, FreeDm: 161, MinFreeDm 161, MaxWait: 4294887172ms, Underruns: 0, 0
Scheduled moves: 636, completed moves: 606
Heater 0 is on, I-accum = 0.0
Heater 1 is on, I-accum = 0.2
Segments left: 1
Stack records: 4 allocated, 0 in use
file is doing "G1 X250.665 Y48.861 E0.00098" in state(s) 0
=== Network ===
Interface state: 5
=== Filament sensors ===
Extruder 0 sensor: ok
=== Expansion ===
DueX I2C errors 0
