Firmware 2.0RC1 and 1.21.1RC1 released
Strange, I've just set up my Kossel the same way, running exactly the same firmware and DWC versions, and it is showing Tool Fan plus fans 0, 1 and 2.
Try sending M106 commands in DWC and see what effect it has on which fans are displayed. It may take a few seconds to update. The firmware needs to see an I, F or H parameter for a fan before it considers that fan has been configured.
I am still in setup phase of my printer using the Duet Wifi but the few prints I have done so far have either succeeded or failed to to PEBKAC not the firmware.
Aside from prints I have not encountered any other issues.
I've tried sending different M106 commands.I think I found the problem: If the config.g file is set up with 3 non thermostatic controlled fans then it only shows me the Tool Fan. Now if I send a M106 command in DWC to set a fan for non thermostatic controlled again, nothing happens. The fan is still not visible. I've tried that with all 3 positions several times.
BUT if I send a M106 command to activate the thermostatic control for example the P0 fan, DWC suddenly makes P1 and P2 visible an it seems like now everything works.
If I now set a fan thermostatic controlled in DWC using the 106 command then it isn't visible. If I disable thermostatic control then they are visible.So you have to set 1 fan for thermostatic controlled first and then everything works like it should.
But the Tool Fan is always there. No matter if it's thermostatic controlled or not.
Why does it even show me 4 fans? Tool fan = position 0 fan. -
I confirm that there seems to be a bug when all the fans are enabled in config.g as non-thermostatic fans.
The tool fan can be mapped to any of the other fans, and the mapping can change depending on the tool you select. That's why it is shown independently of the fan numbers.
My settings all have the Thermostatic control turned off.
Edit: It seems like you already confirmed that its a bug.I updated the firmware using the "upload file" function on the DWC, however, it still shows up as 1.21 after the "update". I uploaded with the older revision of DWC and also the RC1 version and it would not update the firmware. I don't know if others have the same issues with upgrading the firmware. I have the DuetWifi version 1.01 board and tried upgrade using the "Duet2CombinedFirmware.bin" file.
Is there a different process to upload the RC1 file?
@shadowx said in Firmware 2.0RC1 and 1.21.1RC1 released:
If you are already running main firmware 1.21 and DWC 1.21 or later, then you should just be able to upload the new Duet2CombinedFirmware.bin file through the Settings/General page of DWC. DWC should then offer to install it.
@bmmal said in Firmware 2.0RC1 and 1.21.1RC1 released:
DWC
Hello i have two Duet 3D WiFi and one after Install the new firmware the DWC have crash and reboot when i try to Connect to the board. Can you Help me.
I'm sorry to here you are unable to run the new firmware. Suggestions:
If you have a PanelDue connected, disconnect it and see if the Duet will start up.
Remove the SD card, then power up the Duet and see if you can connect via USB.
If either #1 or #2 lets you start the Duet, run M122 immediately and post the software reset data here.
ok i am going to do this and send to you the result of M112
this is the error when i try to Connect to the board with the DWC.
SyntaxError: JSON Parse error: Unexpected identifier "nan"
This is the result of M122 send on USB
< 20:00:39: ResponseBusy
< 20:00:39: Bad recv status size
< 20:00:39: WiFi: avail: 10
< 20:00:39: WiFi: used: 0
< 20:00:39: === Diagnostics ===< 20:00:39: RepRapFirmware for Duet 2 WiFi/Ethernet version 2.0(RTOS)RC1 running on Duet WiFi 1.02 or later
< 20:00:39: Board ID: 08DDM-9FAM2-LW4S4-6JKF0-3S86J-TLSBX
< 20:00:39: Used output buffers: 1 of 20 (11 max)
< 20:00:39: === RTOS ===
< 20:00:39: Static ram: 28484
< 20:00:39: Dynamic ram: 96036 of whiWiFi: max: 0
< 20:00:39: ch 0 recycled
< 20:00:39: Exception stack ram used: 408
< 20:00:39: Never used ram: 6144
< 20:00:39: Task NETWORK ready, free stack 340
< 20:00:39: Task HEAT blocked, free stack 1260
< 20:00:39: Task MAIN running, free stack 3800
< 20:00:39: === Platform ===
< 20:00:39: Last reset 20:29:50 ago, cause: power up
< 20:00:39: Last software reset at 2018-05-08 00:36, reason: User, spinning module GCodes, WiFi: err: 0
< 20:00:39: available RAM 3848 bytes (slot 2)
< 20:00:39: Software reset code 0x0003 HFSR 0x00000000, CFSR 0x00000000, ICSR 0x0041f000, BFAR 0xe000ed38, SP 0xffffffff
< 20:00:39: Error status: 0
< 20:00:39: Free file entries: 10
< 20:00:39: SD card 0 detected, inteWiFi:
< 20:00:39: rface speed: 20.0MBytes/sec
< 20:00:39: SD card longest block write time: 0.0ms
< 20:00:39: MCU temperature: min 34.1, WiFi: avail: 4
< 20:00:39: current 34.3, max 38.8
< 20:00:39: Supply voltage: min 0.2, current 0.4, max 12.9, under voltage events: 1, over voltage events: 0
< 20:00:39: Driver 0: standstill, SG min/max not availWiFi: used: 0
< 20:00:39: able
< 20:00:39: Driver 1: standstill, SG min/max not available
< 20:00:39: Driver 2: standstill, SG min/max not available
< 20:00:39: Driver 3: standstill, SG min/maWiFi: max: 0
< 20:00:39: x not available
< 20:00:39: Driver 4: standstill, SG min/max not available
< 20:00:39: Date/time: 2018-05-09 20:00:35
< 20:00:39: Slowest main loop (seconds): 0.0WiFi: err: 0
< 20:00:39: 12307; fastest: 0.000065
< 20:00:39: === Move ===
< 20:00:39: Hiccups: 0, StepErrors: 0, LaErrors: 0, FreeDm: 240, MinFreeDm 236, MaxWait: 2696479971ms, Underruns: 0, 0
< 20:00:39: Scheduled moves: 9, completed moves: 9
< 20:00:39: Bed compensation in use: none
< 20:00:39: Bed probe heights: 0.000 0.000 0.000 0.000 0.000
< 20:00:39: === Heat ===
< 20:00:39: Bed heaters = 0 -1 -1 -1, chamberHeaters = -1 -1
< 20:00:39: === GCodes ===
< 20:00:39: Segments left: 0
< 20:00:39: Stack records: 2 allocated, 0 in use
< 20:00:39: Movement lock held by null
< 20:00:39: http is idle in state(s) 0
< 20:00:39: telnet is idle in state(s) 0
< 20:00:39: file is idle in state(s) 0
< 20:00:39: serial is ready with "M122 " in state(s) 0
< 20:00:39: aux is idle in state(s) 0
< 20:00:39: daemon is idle in state(s) 0
< 20:00:39: queue is idle in state(s) 0
< 20:00:39: autopause is idle in state(s) 0
< 20:00:39: Code queue is empty.
< 20:00:39: === Network ===
< 20:00:39: Responder states: HTTP(0) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0) Telnet(0)
< 20:00:39: HTTP sessions: 0 of 8
< 20:00:39: - WiFi -
< 20:00:39: Network state is running
< 20:00:39: WiFi module is connected to access point
< 20:00:39: Failed messages: pending 0, notready 0, noresp 0
< 20:00:39: WiFi firmware version 1.21
< 20:00:39: WiFi MAC address 60:01:94:34:38:80
< 20:00:39: WiFi Vcc 3.32, reset reason Turned on by main processor
< 20:00:39: WiFi flash size 4194304, free heap 15912
< 20:00:39: WiFi IP address 192.168.1.76
< 20:00:39: WiFi signal strength -62dBm, reconnections 0, sleep mode modem
< 20:00:39: Socket states: 0 0 0 0 0 0 0 0
< 20:00:39: === Expansion === -
ok i try test the DWC on Google Chrome and is Connect to the board but when i click on the settings the DWC disconnect and give me the error SyntaxError: Unexpected token a in JSON at position 216
First print was successful 2. print in Progress.
The new Firmware works fine for. -
@printtome3d said in Firmware 2.0RC1 and 1.21.1RC1 released:
Thanks. Please send M408 S2 and then M408 S3 from USB, and post the responses here.
Thanks i have put the old DWC and the board work fine, them i have update the DWC to the new 1.21.1 and now works very well this firmware is the better Version of all i have print with the two Duet WiFi and the result is very good. thank for all
@dc42 said in Firmware 2.0RC1 and 1.21.1RC1 released:
I am running 1.21 and using Duet Wifi 1.0 or 1.01. I upload the Duet2CombinedFirmware.bin through the DWC Settings/General/Upload files. It would upload the file and ask me if "You have just uploaded a firmware file. Would you like to update your Duet now?" I press "Yes" to proceed with the update. It goes through the process with the green bar till completion. However, the version stay the same as shown below. I performed this upgrade with the released 1.21 DWC and also the RC1 version shown below with the same results.
I think this may affect the people still using the original or 1.01 hardware but not the later versions. It would be great if someone else with the same hardware can confirm if this is a bug.
Firmware Electronics: Duet WiFi 1.0 or 1.01
Firmware Version: 1.21 (2018-03-21)
WiFi Server Version: 1.21
Web Interface Version: 1.21.1-RC1Edit: I retried the process by renaming the file as "DuetWifiFirmware.bin" and it worked. It would not work when it was named as "Duet2CombinedFirmware.bin" when I uploaded it. The file in the system editor is now named "Duet2CombinedFirmware.bin". It looks like the DWC or the firmware was looking for that original file name and rejected the update if its not the right filename. The system now shows 2.0(RTOS)RC1 on the software information page.
Firmware Version: 2.0(RTOS)RC1 (2018-05-02b1)
Web Interface Version: 1.21.1-RC1 -
Just updated to the latest 2.0 RC and had a print just stop with no error or message 6 hours into a print. Print looked excellent and came back to it and it was just stopped with print head still over the print like it just stopped in the middle of a layer. The bed and nozzle were not at temp still either. I'll have to lookup the and to pull log and see if it shines any light on what happened.
Edit: I retried the process by renaming the file as "DuetWifiFirmware.bin" and it worked. It would not work when it was named as "Duet2CombinedFirmware.bin" when I uploaded it. The file in the system editor is now named "Duet2CombinedFirmware.bin". It looks like the DWC or the firmware was looking for that original file name and rejected the update if its not the right filename. The system now shows 2.0(RTOS)RC1 on the software information page.It might just mean that you have a very old version of iap4e.bin on the SD card. Try uploading the latest one through DWC.
@rmriggin said in Firmware 2.0RC1 and 1.21.1RC1 released:
I'm sorry to hear that you had a crash. It's possible that you hit the bug reported by @BMMal in the second post in this thread. Please can you run M122 and post the software reset data from that report.
iap4e.bin
I still had the original iap4e.bin file from 6/11/2016. I didn't realize I had to update that until I looked at the bottom of the 1.21 which mentions the iap4e.bin should be revised also. Thanks.
