    Using a mirror as toolplate
    1.3k
    • fmaundefined
      fma
      Do you think it is possible to use a mirror as toolplate, with a silicone pad stick on the bottom, and a magnetic sheet stick on the top, to make a removable bed?
      I guess it is possible to glue something in the corners of the mirror to mount it on the bed structure...
      Frédéric
      MSquaredundefined 1 Reply Last reply Reply Quote 0
      • MSquaredundefined
        MSquared @fma
        @fma While I use a MIC-6 aluminum tooling plate as my heat spreader / heated bed I do use mirrors that I purchased from Home Depot as my "glass" and affix PEI/Printbite/gluestick to them as required. They seem to be reasonably flat and have been working out great for me. One negative thing I will say is that the mirror backing causes significant heat drop when compared to standard glass.
        I would be concerned about using a mirror without a heat spreader primarily due to potential warping / breakage if the glass didn't heat evenly.
        -M
          deckingman
          Have you heard of Richard Horne AKA RichRap? https://richrap.blogspot.co.uk/. A great name in te Reprap world. He's been an advocate of using mirror glass for many years.
            Yes you can use mirror, but ordinary float glass is usually just as good.
            • fmaundefined
              fma
              Ok, I'll give it a try. I have some optical mirror, very very flat, 4mm; I think it will be a good candidate.
              PS: BTW, I'm using mirrors as build plate for years, but never eared to use them as main structure, instead of aluminium. That's why I asked.
              Frédéric
                deckingman @fma
                @fma I wouldn't do that. It's very important to use a heat spreader to prevent local hot spots.
                • fmaundefined
                  fma
                  Wires on the silicone pad are 5mm from each other, which is not bad. I will put the pad on the tin side; it may help a bit...
                  Let's try ;o)
                  Frédéric
                  • fmaundefined
                    fma
                    @Ian, I will have a magnetic sheet stick on the top, and a metal sheet as removable plate; so I don't think there will have any hotspot on the print surface...
                    Frédéric
                    • Danalundefined
                      Danal
                      I'm using a 6mm thick glass tabletop, with the heater stuck directly on the bottom. No aluminum layer at all. Per IR thermometer, very even. Also heats much more quickly than I would have thought. Takes a while to cool...
                      • fmaundefined
                        fma
                        How is you glass maintained on the frame?
                        I made a quick test using silicone-based glue to stick it on MDF, and it seems to work great (I have 10mm free arround the silicone pad). Silicone glue can handle up to 200°C.
                        Frédéric
