Your browser does not seem to support JavaScript. As a result, your viewing experience will be diminished, and you have been placed in read-only mode.
Please download a browser that supports JavaScript, or enable it if it's disabled (i.e. NoScript).
HELLO I HAVE A CONSULTATION, IF I CONNECT THE PT100 THERMISTOR, I WILL NOT FUNCTION CORRECTLY THE CONTROL PANEL 7i SD ?, How can I make the SD of the LCD panel work since I have to load the .gcode files
Are you saying that the PT100 doesn't function when the PanelDue ribbon cable is connected?
