How Do I Calibrate My Titan Extruder and Test Print?
Also, I just found out that my bed is moving backwards on the Y axis on start up, along with heating.
The only thing different about my printer before and when it was working is the 1.21 update.
1. WiFi module won't start when printer is switched on, and requires a third-party program to run M552 S1 to start.
2. Bed heats up with full power.
3. Bed moves backwards slowly on Y axis until Y stop on start up.
4. Can't Home All axis because the G-code is incomplete. -
This line in homeall.g:
G1 Z3 F200 ; Lower bed to avoid hotend dragging in bed.
needs the S2 parameter added.
Regarding the issues on startup, please post your config.g file.
;Config.g
M111 S0 ; Debugging off
G21 ; Work in millimetres
G90 ; Send absolute coordinates…
M555 P2 ; Set firmware compatibility to look like Marlin
M208 X340 Y250 Z280 S0 ; Set axis maxima; Endstops
M574 X1 Y1 Z1 S0 ; Define active low and unused microswitches
M558 P5 X0 Y0 Z1 H10 F200 T6000 ; Set Z probe type to modulated, the axes for which it is used and the probe + travel speeds
G31 X-44 Y0 Z7.03 P50 ; Set Z probe trigger value, offset and trigger height; Z-offset (Z0.9). Higher value LOWER nozzle height
; Lower value RAISE nozzle heightM557 X10:340 Y10:240 S68 ; Define mesh grid
M307 H3 A-1 C-1 D-1 ; disable heater 3, which makes it available for use to control the BLTouch
M569 P0 S1 ; Drive 0 goes forwards - X
M569 P1 S0 ; Drive 1 goes backwards - Y
M569 P2 S0 ; Drive 2 goes backwards - Z
M569 P3 S1 ; Drive 3 goes forwards - ExtruderM350 X16 Y16 Z16 E16 I1 ; Configure microstepping with interpolation 16
M92 X160 Y160 Z1600 E615 ; Set steps per mm 16M566 X600 Y420 Z12 E120 ; Set maximum instantaneous speed changes (mm/min) - (JERK)
M203 X6000 Y6000 Z500 E400 ; Set maximum speeds (mm/min)
M201 X1000 Y1000 Z1000 E250 ; Set accelerations (mm/s^2)
M204 P1000 T1000 ; Set Max acceleration for P=printing moves and T=travel moves
M906 X1600 Y1600 Z900 E1000 I30 ; Set motor currents (mA) and motor idle factor in per cent
M84 S30 ; Set idle timeout; Heaters
M143 S285 ; Set maximum heater temperature to 285CM305 P0 R4700 T100000 B3950 ; Set thermistor + ADC parameters for heater 0 - BED
M305 P1 R4700 T100000 B3950 ; Set thermistor + ADC parameters for heater 1 - HOTENDM307 H0 P96.0, I3.285, D603.9 ;Bed
M307 H1 A250 C999 D4.5 B0 S1 ;Hotend; Tools
M563 P0 D0 H1 ; Define tool 0
G10 P0 R0 S0 ; Set initial tool 0 active and standby temperatures to 0C; Network
M550 PCLU ; Set machine name
M552 P0.0.0.0 S1 ; Enable network and acquire dynamic address via DHCP; Fans
M106 P0 S0.3 I0 F500 H-1 ; Set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned off
M106 P1 S1 I0 F500 H1 T45 ; Set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned on
M106 P2 S1 I0 F500 H1 T45 ; Set fan 2 value, PWM signal inversion and frequency. Thermostatic control is turned on; Custom settings are not configured
If there's a vanilla config that comes with 1.21, maybe I should just start with that, then bring across some specific parameters for my printer.
This line:
@aarongreen said in How Do I Calibrate My Titan Extruder and Test Print?:
is completely wrong. I suggest you delete it, restart the Duet, run bed heater tuning (M303 H0 Sxxx where xxx is the highest bed temperature you normally use), then run M500 to save the new M307 parameter to config-override.g. As you do not have a M501 command at the end of config.g to run config-override.g (which is a perfectly valid choice), you will then need to copy the M307 H0 line from config-override.g into config.g.
@dc42 said in How Do I Calibrate My Titan Extruder and Test Print?:
OK, ran through that process thanks. I copied the data across and it appears to be stable.
M305 P1 R4700 T100000 B3950 ; Set thermistor + ADC parameters for heater 1 - HOTENDM307 H0 A90.0 C700.0 D10.0 S1.00 V0.0 B1 ;Bed
M307 H1 A250.0 C999.0 D4.5 S1.00 V0.0 B0
M307 H2 A340.0 C140.0 D5.5 S1.00 V0.0 B0
M307 H4 A340.0 C140.0 D5.5 S1.00 V0.0 B0
M307 H5 A340.0 C140.0 D5.5 S1.00 V0.0 B0
M307 H6 A340.0 C140.0 D5.5 S1.00 V0.0 B0
M307 H7 A340.0 C140.0 D5.5 S1.00 V0.0 B0
M307 H1 A250 C999 D4.5 B0 S1 ;Hotend -
I'm unable to test the bed heater control, as I can't home the printer.
I've checked all the connections since moving, and everything is in place, however when I home the printer just rams X with the grantry and Y with the bed. The sensors are in place as well, so I'm guessing something isn't correct in the config again?
;Config.g
M84 S30 ; Set idle timeout -
I suggest you test the homing switches, see https://duet3d.dozuki.com/Wiki/Connecting_endstop_switches#Section_Test_endstop_switches.
Geez this is complicated. I haven't changed anything, and they don't work. I don't know why I'm going over this again.
The end stop LEDs for X and Y are on, yet all the physical connections are good. I would think it's too much of a coincidence that both of them have failed at the same time, but I suppose there's a chance, and I'll have to order replacements which will take a while to arrive.
In the Machine Properties, it says X and Y are 'No' and Z is 'Yes' with:
M574 X1 Y1 Z1 S0 ; Define active low and unused microswitchesEven though X and Y are triggered, according to the LEDs on the board. Unless this means that faulty switches can't be triggered either way, and they're still showing up as not triggered, because they're 'un-trigger-able'. The Z is always triggered at the start, because it uses a BLTouch sensor, but doesn't show an LED light. The X and Y sensors both being faulty, for some reason, is the only explanation why this doesn't work.
Are you sure that your endstop switches are active low (S0 in M574)? If the endstop LEDs on the Duet go out when you trigger them, they are active high.
OK, so I've turned the power off at the wall and found the Duet finally reset the end stops. I'm not sure why it didn't reset the state of the end stops when I restarted the Duet in web control.
The end stops are simple metal sensor switches that become active when the gantry and bed pass over them at close range - the same that I've used in earlier versions. I can see their lights come on when I pass the gantry and bed over them, but during a Home All the gantry and bed keep moving thereafter, and ram the physical boundaries of the printer.
M574 X1 Y1 Z1 S0 is the current setting, but changing it to S1, for test's sake, doesn't fix it. The Home All ignores the end stops.
It sounds like your endstops locked up until you powered them off. Are you sure you are supplying them with enough supply voltage to function correctly?
I'm using the expansion bay set up with my end stops. From memory, it had something to do with the voltage. I had a look around the documentation to try and find the wiring guide for this set up but didn't see anything. I'm not sure if Duet is using this system anymore...
I also just realised, the X and Y were homing without ramming the printing, before I had to add S2 to G1 commands...
Home All would zero X and Y without a problem, but not Z. When I added S2 to the G1 commands, it started ramming the printer, so it can't be the power, or the switches.
Well, I accidentally hit the erase button trying to move the board, and now it's a paper weight at best. Love this thing.
I only have a Mac, and the current documentation says I need a Windows computer, so I that's the end of the road by the looks of it.
@aarongreen you can use a mac to re-program the board you will need to download and install samba 1.8
@dougal1957 said in How Do I Calibrate My Titan Extruder and Test Print?:
I managed to find Samba1.8.tar on the Samba archive, download it, and run it in Terminal, but I can't find any process on here on how to utilise it in Terminal. I've never done this before.
There is also a download of Bossa 1.8 available for Mac.
I got a hold of Bossa 1.8 and reinstalled firmware 1.20 quite easily, and I'm back to printing already, thanks guys.
I wasn't able to fix the gradually sloping X axis issue I had with the printer last time, but I'll confront that if it's still shows up.
The only other issue I had during the test printer today was multiple Z height settings for the print, which I don't remember setting.
I tried finding an existing thread for this but wasn't able to...
The printer is printing above the established Z height calibration.
I calibrated the BLTouch offset to G31 X-63 Y0 Z2.6 P50. At this setting, the nozzle sits half a paper's thickness off the bed at G1 Z0.
However, when I print anything it prints [visibly at a guess] at Z1, or 1mm off the bed. Babystepping in down, even up to 5.5mm, does nothing. It's printed successfully in the past, usually half a mill higher than Z0 for some reason, and I'm able to babystep it down just to get the print away, but this is out of control.
I've included the Cura start code I set up a while ago, but haven't really discussed it with anyone here. I'm not sure if it's part of the issue. I thought maybe it has something to do with the executing, seeing that the Duet calibration tests are good, and the print data maybe wrong...
Config.g
M82 ; Using Cura
M552 S1 ; Start WiFi Module; Endstops
G31 X-63 Y0 Z2.6 P50 ; Set Z probe trigger value, offset and trigger heightCura Custom Start Code:
;FLAVOR:RepRap
;TIME:9941
;Filament used: 4.49025m
;Layer height: 0.1
;Generated with Cura_SteamEngine 3.0.4
T0
M190 S60
M104 S210
M109 S210
M82 ; absolute extrusion mode
Start Code
M280 P0 S160
M420 Z2 ; set fade leveling at 2mm for BLTouch (OK to send for Non BLTouch)
G28 ; home all
G29 ; bed probe
M82 ; relative extrusion
G92 E0 ;zero the extruded length
G1 X0.0 Y50.0 Z10.0 F3600 ; perform wipe and prime
G1 Z0.0 F1000
G1 Z0.0 Y70.0 E9.0 F1000.0 ; prime
G1 Y100.0 E12.5 F1000.0 ; prime
G92 E0 ; zero extruder again
;end start code
M82 ; relative extrusion mode
;LAYER_COUNT:398
;LAYER:0
M107
M204 T2500
M566 X1800 Y1800
G0 F3600 X176.318 Y114.382 Z0.3
M204 P1500
M566 X1200 Y1200
;TYPE:SKIRT
G1 F1500 X176.664 Y113.853 E0.03154
... and so on...
