Dual Extruders on one tool
This is a little different, but i don't see why I can't get it to work. I have a large delta similar to Little Monster, and I want add second extruder for T0 to feed the filament off of the spool ensure there is slack for the effector. I have utilized the mixing configuration, and for testing set the mix 50/50. I would like to go to 1:1 if I can get it working to maintain the correct steps/mm ratio. Here is my config below. E0 extrudes the proper amount of filament and E1 extrudes the proper amount of filament when the they are commanded idividually from the web interface. They both run in parallel when the "ALL" button is pushed. But the "MIX" button only extrudes E0. and G1 E50 F500 only extrudes E0. I'm running a Nimble for the E0 and a Mark 8 for E1. Any help would be appreciated.
Thank You,
Johnconfig.g
; Configuration file for Duet WiFi (firmware version 1.20 or newer)
; generated by RepRapFirmware Configuration Tool on Sun Mar 18 2018 22:01:25 GMT-0400 (Eastern Daylight Time); General preferences
G90 ; Send absolute coordinates…
M83 ; ...but relative extruder moves;*** The homed height is deliberately set too high in the following - you will adjust it during calibration.
;M665 R177 L397 B170 H495 ; (Original)Set delta radius, diagonal rod length, printable radius
and homed height
;M665 L398.904 R175.293 H494.630 B175.0 X0.378 Y0.458 Z0.000 ; delta radius, diagonal rod length, printable radius and homed height set by Auto-calibrate on 3/21/18
M665 L410.681 R178.611 H494.697 B175.0 X0.253 Y0.373 Z0.000 ; delta radius, diagonal rod length, printable radius and homed height set by Auto-calibrate on 3/24/18
;M666 X0 Y0 Z0 ; (Original)Put your endstop adjustments here, or let auto calibration find them
;M666 X-0.765 Y0.319 Z0.446 A0.00 B0.00 ; endstop adjustments set by Auto Calibration on 3/21/18
M666 X-1.258 Y0.473 Z0.785 A0.00 B0.00 ; endstop adjustments set by Auto Calibration on 3/24/18
M550 PSG Delta ; Set machine name
M552 S1 ; Enable network
M587 S"SafeRoom" P"XXXXXXX" I192.168.1.154 J192.168.1.254 K255.255.255.0 ; Configure access point and IP addresses. You can delete this line once connected
M586 P0 S1 ; Enable HTTP
M586 P1 S0 ; Disable FTP
M569 P0 S0 ; Drive 0 goes backwards
M569 P1 S0 ; Drive 1 goes backwards
M569 P3 S0 ; Drive 3 goes backwards
M569 P4 S1 ; Drive 3 goes forwards
M350 X16 Y16 Z16 E16:16 I1 ; Configure microstepping with interpolation
M92 X100 Y100 Z100 ; Set steps per mm
;M566 X1200 Y1200 Z1200 E1 ; STOCK maximum instantaneous speed changes (mm/min), E1 for Nimble
M566 X600 Y600 Z200 E1:400 ; SET 3/26/18 maximum instantaneous speed changes (mm/min),Nimble
M203 X18000 Y18000 Z18000 E1000:2000 ; Set maximum speeds (mm/min)
M201 X1000 Y1000 Z200 E120:200 ; Set accelerations (mm/s^2)
M906 X1000 Y1000 Z1000 E800:1000 I30 ; Set motor currents (mA) and motor idle factor in per cent
M92 E2740:96.117 ; Set Steps/mm for extruder implicitly (ext0:ext1)
M208 Z0 S1 ; Set minimum Z; Endstops
M574 X2 Y2 Z2 S1 ; Set active high endstops; Z-Probe
M558 P5 R0.4 H5 F1000 T6000 ; Set Z probe type to effector and the dive height + speeds
G31 P100 X0 Y0 Z-0.05 ; Set Z probe trigger value, offset and trigger height
M557 R162 S20 ; Define mesh grid
M305 P0 T100000 B3950 C0 R4700 ; Set thermistor + ADC parameters for heater 0
M143 H0 S130 ; Set temperature limit for heater 0 to 120C
M305 P1 T100000 B4138 C0 R4700 ; Set thermistor + ADC parameters for heater 1
M307 H0 A263.8 C694.6 D1.0 S0.90 V24.3 B0 ; Generated by AutoTune on 3/20/18 and manually added here
M307 H1 A519.5 C211.3 D4.7 S1.00 V24.2 B0 ; Generated by AutoTune on 3/20/18 and manually added here; Fans
M106 P0 S0 I0 F500 H-1 ; Set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned off
M106 P1 S1 I0 F500 H1 T45 ; Set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned on
M106 P2 S1 I0 F500 H1 T45 ; Set fan 2 value, PWM signal inversion and frequency. Thermostatic control is turned on; Tools
M563 P0 D0:1 H1 ; Define tool 0
M568 P0 S1 ; Enable mixing for tool 0
M567 P0 E0.50:0.50 : Use mixing command to drive P0 and P1 at a 1 to 1 ratio.; Automatic saving after power loss is not enabled
M501
T0 ; -
I can't see anything wrong with that, but if G1 E50 F500 only turns E0 then it looks like the M567 command has not been recognised. Try sending M567 P0 and see what ratio it reports.
Thanks for the fast reply. Here is the output.
M567 P0
Tool 0 mix ratios: 1.000:0.000That's not right. You are on to something…but I don't know what.
You have started the comment on the M567 line with a colon instead of a semicolon.
That was it!!!! I have been cutting and pasting that around for two days. Good eye! It is printing great Now! By the way, this is a great platform. I can't wait to upgrade my other printer to Duet3d!
