G2/G3 Arc Movements
What the wiki actually means is that it was first introduced in firmware version 1.17beta. I believe it is solid, but it has been exercised a lot less than the code for straight moves.
Ok thanks for the clarification.
Btw until the latest RC firmware, there was no axis limit checking during arc moves, only for the end point.
Following up: I'm still on 1.20, but using the python code referenced above, I've been successfully playing around with the arc moves. Seem to work just fine, can result in significantly smaller gcode files as expected. Thanks again.
I tried milling a rather simple 3D shape (half a sphere, 6mm radius) using a GCode file produced by CamBam from an STL file, with 1800mm/min feedrate. I ended up trying for the rest of the day to figure out what is wrong with WorkBee as it made really terrible noises and kept loosing steps on X axis.
Only late at night I rewired GRBL and tried the same file (well, re-generated for GRBL) and all OK. So it is a problem with the G2/G3 algorithm when there are a lot of small arcs. I rechecked with Duet3D reducing the feedrate to half and then it also worked.
I did another try with a differently generated GCode, based on controlled slope contour milling. That produces a lot smaller file, with fewer larger arcs. That is working as expected with Duet3D as well.
Maybe unrelated problem - for G2/G3 I had to force CamBam to always include X and Y coordinates. Situations when one of the coordinates didn't change, and there are plenty of when doing high-speed machining, were ending with error messages. In the end, having a coordinate value to be reused should skip the conversion from text (GCode info) to floating point, thus reducing the CPU usage a little bit.
P.S. All these have been tested with firmware 1.21.
Thanks for your report. I can change G2/G3 so that X and/or Y need not be specified.
When you had the problem with small arcs, did you try increasing the X and Y maximum speed change values in M566?
M566 has 900 for X, Y and U and 60 for Z.
The machine is pretty heavy, with the spindle weighing 1.7kg. The whole "effector" is over 4kg with the whole Z-axis mechanics, 86mm long NEMA 23 stepper, drag chain etc. The complete X axis should be way over 10kg. The WorkBee vibrates when doing high speed machining, thus I would avoid increasing accelerations and speed change values beyond the current settings.
On the other hand, the GCode file produced from STL had sudden changes between climb and conventional milling (in my situation that translates to milling CW vs CCW around the material) while the "good" GCode has only climb milling commands. Being a rather small piece, it is impossible to tell if the "bumps" happen when changing direction or at different position in the file. I will try to set M566 values to much lower because of the weight of the machine.
As for the missing X or Y, the NIST standard specifies that at least one of X or Y must be present and, also, at least one of I or J must be present. Missing coordinate is interpreted as the same coordinate value and missing I or J is interpreted as 0. Of course, going to more flexibility, like allowing missing both X and Y to have a full circle with a known center, should be OK. Also, G2/G3 missing both I and J could be simply ignored but that would be just one wasted line of GCode!
The above comment for G2/G3 is true when working in XY plane, like the RepRap firmware works right now! But that will be another discussion.
It is even worse… trying to do a 2400mm/min machining is again showing lost steps. Everything points to a maximum number of steps per second during G2/G3 below that limit. Going to try at 1800mm/min that seemed to work.
Again, for reference, WorkBee CNC with 400 steps/mm at 16 microstepping.
Did the test… at 1800mm/min the same file worked like a charm!
What steps/mm and microstepping does your Duet powered machine use?
400steps/mm with 16 microsteps. I also did the math - 1800mm/min -> 30mm/sec -> 12000steps/sec.
After trying to machine some small Aluminum parts, I had problems even at 1200mm/min. In the end, after doing a lot of tests and studying the problem, the CAM processor is the main culprit. I use a lot of trochoidal milling as it produces much better results on a not-so-rigid machine. The CAM software produces some sudden direction changes in specific situations, so specific that many times they do not happen at all.
I have found a pattern that easily reproduces the problem. In the end it was the maximum jerk being too high! 900mm/min instantaneous speed change for an 10kg gantry is anything but normal. Maximum feedrate of the WorkBee is 2500mm/min!
