Height maps with large Z offsets
A few users have reported getting G29 height maps that show a large overall Z offset. Until today, the only cause of this that I was aware of was using an endstop switch to do Z homing, where the Z height after homing wasn't quite what the firmware was told in the homing file or the M208 settings.
Today I had an instance of a Z-displaced height map on one of my printers that uses the Z probe for homing, after I temporarily changed the bed surface to one that gave a different trigger height. The error persisted after multiple G29 attempts.
The way I resolved it was:
- send
G92 S2G29 S2 to clear the height map - home Z
- run G29. This generated a sensible height map.
Sending
G92 S2G29 S2 before homing Z was critical to avoid perpetuating the error in the new height map. I can see now that when the printer is Z-homed using the Z probe, the height map should be re-normalised to the new Z probe trigger point. I will implement this in the next firmware version. - send
Nice, I thought I was going mad…I doesn't hapens always but yes I saw the heightmap influencing the homing and then the first G29 poit would already be off
I feel like I might have ran into a similar issue. My printer uses bltouch and I use it for homing and mesh leveling. My heightmap was giving me a ~0.7mm difference yet I’m using a perfectly flat mic6 aluminum plate.
If I probe at 10,10 then lift nozzle 5mm and move to 10,280 (where it’s supposed to be 0.7mm lower) And lower the nozzle at 0, i get the same distance from the bed at both point.
- send G92 S2 to clear the height map
Sending G92 S2 before homing Z was critical
Sorry David just checking something…
G92 = Set position - no S parameter in current G code documentation pages
G29 S2 = detailed Z probe, S2 = clear height mapDid you mean the G29 S2 ? Or is my own dyslexia confusing me?
Also how does [the one you meant] compare to M561 = Set Identity Transformthanks
You are right, it was a typo. Should be G29 S2.
