Run time hour meter
Agreed
Yup,
Something that I requested a long, long time ago. But in the great scheme of things, I understand that it's low priority and possibly better to implement via DWC rather than the main firmware? Dunno - just a guess.
Yep I'm sure its low priority. It would just be a nice feature.
Yes I agree - and for exactly the same reasons as you (maintenance schedules etc).
I would love this as well
What information should be recorded? How often should it be updated? Bear in mind that the flash memory has a limited number of writes, so updating this information continuously or very frequently is not desirable. Also, some users provide 5V standby power; for those users, should the total power on time only include time when VIN power is provided?
I'd love to be able to have the data similar to the OctoPrint History Plugin: https://plugins.octoprint.org/plugins/printhistory/
Primarily, it tracks print time and filament used on a per-job basic. This is summed together for totals.
To your specific question, David, I'd track total power-on time when VIN power is provided.John
couldn’t you stor it on the SD card instead? Solves the problem of limited write cycles…
Would it be possible to have last print time next to a file in G-Gode files section. It would be good for tuning speed and for people printing same parts over and over. Also stored somewhere on SD rather than eeprom
SD card is flash memory.. Dc42 wasn't talking about eeprom
One thing I have been considering is that when a file is printed of simulated, a comment giving the print time could be appended to that file. RRF and DWC would be able to extract that information. I'd probably make this optional, because some users might not want the Duet to modify their GCode files.
