Delta G32 results reporting
Hi
I’m used to David’s Escher online delta calibration tool for my older delta. Now that this routine is implemented in the duet firmware, its of course much easier to use. However after finishing the autocal routine after sending G32, i just get two numbers as report (before and after).
Is there a way how to get a report containing the other values that are calculated? Endstop offsets, delta radius, angle corrections…?
Thanks!
Send M665 and M666 without parameters to display those values.
great, thanks!
