Cant get the WiFi to Work
I figured it was probably that. I have read through the forums and that seemed likely to be the problem. I purchased this board on August 11th, and did not take it out of the box until last week. I project got delayed and i was not able to work on it until recently. I have been talking to my supplier(Filastruder). I am waiting for them to get a response from Think3DPrint3D, because I guess I am past the normal time for the exchange. I guess the six month warranty is only after November 14th purchases. The supplier has been very helpful and informative. I'm just a little frustrated because i have been excited to use this board on the HEVO that I have built, that ended up costing twice as much as i originally planed. At least i still have my trusty Anet A8. Ha ha ha. I do have a spare 24V ramps kit laying around, but i hope it does not come to that.
I replacement was approved. Thank you for your time and help. I would also like to thank Tim from Filastruder, for his work getting this issue resolved for me.
*Tim
ha ha ha ha. I knew that, I don't know why i wrote Jim. lol!! Probably because my father is Jim. lol!! Thank you!!!
Just got this return, it seems the ESP8266 has developed an internal fault. It gets warm, not too hot to touch but noticeably warm. Can confirm the following:
SENT: M552
READ: WiFi module is disabledSENT: M552 S1
READ: okSENT: M552
READ: WiFi module is being startedIssuing replacement.
I received the fixed or replaced board. I was able to update the firmware and connect to wifi!
I've upgraded to 1.21RC2 and I'm encountering the same issue.
Can't get the board to add the SSID- WiFi -
Network state is starting
it was working perfectly with 1.19 just before
[[language]] ttyACM1 18°> M115 SENDING:M115 FIRMWARE_NAME: RepRapFirmware for Duet WiFi and Duet Ethernet FIRMWARE_VERSION: 1.21RC2 ELECTRONICS: Duet WiFi 1.0 or 1.01 FIRMWARE_DATE: 2018-02-15 build 2 ttyACM1 18°> M552 S1 SENDING:M552 S1 Turn off the current WiFi mode before selecting a new one ttyACM1 18°> M589 SENDING:M589 M589: Failed to retrieve own SSID data
- WiFi -
Send M552 S-1 to reset the wifi module, then M552 S0. Then send M122 and check what wifi firmware version it reports in the network diagnostics.
[[language]] === Diagnostics === Used output buffers: 1 of 32 (1 max) === Platform === RepRapFirmware for Duet WiFi and Duet Ethernet version 1.21RC2 running on Duet WiFi 1.0 or 1.01
[[language]] === Network === Responder states: HTTP(0) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0) Telnet(0) HTTP sessions: 0 of 8 - WiFi - Network state is starting WiFi module is disabled Failed messages: pending 0, notready 0, noresp 0 Socket states: 0 0 0 0 0 0 0 0
Can't see the specific WifiServer version
The WiFi module is stuck on starting. Copy the new DuetWiFiServer.bin file to /sys on the SD card in a PC, then put the card back in the Duet and try installing it using M997 S1 again.
yep, sorry for the noise, it's now ok :
[[language]] ttyACM0 17°> M997 S1 SENDING:M997 S1 Trying to connect at 230400 baud: success Erasing 4096 bytes... Erasing 24576 bytes...
I should have checked the filesize when I downloaded the bin…
Thanks !
I just tried this or noticed this issue and sent M997 S1 to the board via YAt … wonder if it changes anything
Thanks !
Yes, 24576 bytes is about 10% of the correct size.
