Error: Short-to-ground on drivers 1
Something isn't right with this:
but when I try to move Y stepper with X driver it displays short-to-ground on driver 1
Driver 1 is the Y driver.
Negative, wording is correct despite being a bit ambiguous, I'll try to rephrase.
As CoreXY doesn't have true X and Y axes it has alpha and beta motors working together, which I've seen being addressed as X (left) and Y (right) motors and I have adopted it. What you have quoted is to be read as follows - when I have Y stepper (right stepper/beta motor) connected to X driver on the Duet Wifi and I move the X axis via the web interface I get error short-to-ground on driver 1.
See 3) of my update as I go into bit more detail there.
If attempting to move the motor connected to the Y motor output causes that error message to appear, that indicates that driver 1 (Y driver) has a shorted mosfet or that there is a short in the external wiring. If it produces that message even with no motor connected to the Y motor output, then it's the driver that is faulty.
Thanks for your input!
Currently, I have the Z and X motors connected to their respective drivers i.e. Y driver is free. When I move Z axis no error appears. When I move X axis the error in driver 1 appears. When I move Y axis the carriage does move although just a short distance and quite slowly. If I'm understanding correctly what you have written, driver 1 (Y) is faulty.
That is unfortunate but I'd rather think forward. I was wondering how can I remap the driver from E1 (which is free since I'm using a single extruder) to move the Y axis. I'm looking at the gcode but I must say its harder for me than I thought.
Yes, to can use M584 X0 Y4 Z2 E3 in config.g to do that. But you are entitled to have your Duet repaired or replaced under warranty, assuming you have had it for less than 6 months.
Thanks for spelling it out for me, I appreciate your time.
I only wanted to ask if I have to add some gcode to "deactivate" driver 1 (Y) or just add the remapping gcode, connect to the proper driver and go about my merry ways? Also, what should I make of the low voltage error I received earlier? I do have many more questions but I believe I should make use of the search feature.Also, thank you for bringing that up. I'd rather have a properly functioning board but I wanted to continue with finalizing my config. I did contact RepRapWorld so we'll see that will happen but yes I've had it for less than six months.
The output MOSFETs won't be enabled on driver 1 if it is never used.
The M584 command must come earlier in config.g than the M906 command, also earlier than the M350 command if you have one.
Thanks for clarifying. I did add that in my ;Drives and I can move all axes without any errors.
I appreciate your help. I'm happy the support of the boards lives up to the expectations. Well done, to you, dc42, sir.
Now, as everything moves correctly I wanted to have my axes home in the correct direction. I flipped Z and it worked as expected. However, when I try to flip Y (drive 4) it goes south somewhere. I added M569 P4 S0 ; Drive 4 goes backwards but in that case when I move X from the interface Y moves in the wrong direction and when I move Y in the interface X moves in the right direction. If I add M569 P4 S1 the interface moves the correct axis and X moves in the right direction and Y moves in the wrong direction.
M584 X0 Y4 Z2 E3 ;remap drive Y to drive E1
M569 P4 S0 ; Drive 4 goes backwards -
It sounds to me that your printer currently has a left-hand coordinate system. To change it to a right-hand coordinate system, swap over the X and Y motor connections or swap X and Y in the M584 command, then use M569 to get the correct directions.
By a lucky mistake I just read that RRF uses a right-hand origin. Where can I get more info why this is the case and wouldn't it result in mirrored prints?
All 3D printing assumes a right-hand coordinate system - which means that looking from above, the +Y direction is rotated 90 degrees anticlockwise from the +X direction.
On a CoreXY printer, the usual choice is that looking at the front of the printer, +X is to the right and +Y is away from you.
I think we both are talking about an origin of front/left like here - http://www.makerslide-machines.com/old-web-site/res/z-in-same-time.jpg, do correct me if that's not the case.
I had issues with it but after going out for a walk I now have it working properly with the following, if anybody ever needs it:
M584 X0 Y4 Z2 E3 ;remap driver Y to driver E1
M569 P2 S0 ; Drive 2 goes forwards
M569 P4 S1 ; Drive 3 goes forwards -
This post is deleted!
