    Duet Wifi Webserver not responding
    80
    10.0k
    • Nuvagundefined
      Nuvag
      Had repeatedly another issue: Wifi won't enable after powering up the duet wifi (blue light on the wifi module stays off), a powercycle fixed this. Sadly did not execute a M122.
      I just remembered a fan (at the base) burned out a few weeks ago right after powering up the duet (luckily i immediatly noticed it and turned the power off before something worse could happen). As the fan was quite hot after just a few seconds i suspect it produced a short. Could this have damaged the wifi function?
      Currently im using no fan at the base as i had no spare part at hand.
      Must have been very unlucky with the fans, as all three fans supplied with my T3DP3D Kossel XL failed within one year.
        A burned-out fan might damage the associated fan mosfet, but it should not affect the wifi module.
        • Nuvagundefined
          Nuvag
          I remembered there are additional debug modes, enabled networking and wifi debug and got:
          >>> M122
          SENDING:M122
          Used output buffers: 5 of 32 (31 max)
          RepRapFirmware for Duet WiFi version 1.20 running on Duet WiFi 1.0
          Board ID: 08DAM-999TL-MQ4SD-6J1F4-3SN6J-KN9RW
          Static ram used: 15448
          Dynamic ram used: 99088
          Recycled dynamic ram:WiFi: recv:
           152
          Stack ram used: 3576 current, 8592 maximum
          Never used ram: 7792
          Last reset 00:24:57 ago, cause: power up
          Last software reset at 2018-01-27 11:42, reason: User, spinning module GCodes, available RAM 7792 bytes (slot 2)
          Software reset code 0x0003 HFSR 0WiFi: xmit: 0
          x00000000, CFSR 0x00000000, ICSR 0x044WiFi: recv: 0
          1f000, BFAR 0xe000ed38, SP 0xffffffff
          Error status: 0
          [ERROR] Error status: 0
          Free file entries: 10
          SD card longest block write time: 0.0ms
          MCU temperature: min 43.5, current 43.7, max 44.7
          WiFi: fw: 0
          Supply voltage: min 24.1, current 24.2, max 24.4, under voltage events: 0, oWiFi: drop: 0
          ver voltage events: 0
          Driver 3: standstWiFi: chkerr: 0
          Date/time: 2018-01-30 17:06:47
          CaWiFi: lenerr: 0
          che data hit count 4294967295
          Slowest main loop (seconds): 0.155984; fastest: 0.000110
          MaxReps: 0, StepErrors: 0, FreeDm: 240, MinFreWiFi: memerr: 0
          eDm 240, MaxWait: 0ms, Underruns: 0, 0
          Bed compensation in use: none
          Bed probe heights: 0.000 0.000 0.0WiFi: rterr: 0
          00 0.000 0.000
          Heater 0 is on, I-accum = 0.0
          Heater WiFi: proterr: 0
          1 is on, I-accum = 0.4
          Segments left: 0
          Movement lock held by null
          http is idle in state(s) 0
          telnet is idle in state(s) 0WiFi: opterr: 0
          file is idle in state(s) 0
          serial is ready with "M122" in state(s) 0
          aux is idle WiFi: err: 0
          in state(s) 0
          daemon is idle in state(s) 0
          queue is idle in state(s) 0
          Code queue is empty.
          Network state is running
          Failed messages: pWiFi: cachehit: 0
          ending 0, notready 0, noresp 0
          WiFi firmware veWiFi:
          rsion 1.20
          WiFi MAC address 5c:cf:7f:2c:28:22
          WiFi Vcc 3.40, reset reason Turned on by main processor
          WiFi flash size 4194304, free heap 16248
          WiFi IP address 192.168.178.15
          WiFi signal strength -58dBm, reconnections 0, sleep mode modem
          HTTP sessioWiFi: xmit: 7
          ns: 1 ofWiFi: recv: 7
           8
          Socket states:  0 0 0 0 0 0 0 0
          Responder states: HTTP(0) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0)
          WiFi: fw: 0
          WiFi: drop: 64
          WiFi: chkerr: 0
          WiFi: lenerr: 0
          WiFi: memerr: 0
          WiFi: rterr: 0
          WiFi: proterr: 64
          WiFi: opterr: 0
          WiFi: err: 0
          WiFi: cachehit: 4853
          WiFi:
          WiFi: xmit: 4883
          WiFi: recv: 7382
          WiFi: fw: 0
          WiFi: drop: 417
          WiFi: chkerr: 0
          WiFi: lenerr: 0
          WiFi: memerr: 0
          WiFi: rterr: 0
          WiFi: proterr: 0
          WiFi: opterr: 0
          WiFi: err: 0
          WiFi: cachehit: 0
          WiFi:
          WiFi: xmit: 22
          WiFi: recv: 12
          WiFi: drop: 0
          WiFi: chkerr: 0
          WiFi: lenerr: 0
          WiFi: memerr: 0
          WiFi: proterr: 0
          WiFi: rx_v1: 0
          WiFi: rx_group: 0
          WiFi: rx_general: 12
          WiFi: rx_report: 0
          WiFi: tx_join: 4
          WiFi: tx_leave: 2
          WiFi: tx_report: 16
          WiFi:
          WiFi: xmit: 0
          Was again able to ping the duet but the webpage wont load. protokoll errors and drop increase when trying to load the webpage.
            Please try the following:
            1. With network debug enabled and with the WiFi in that state (i.e. M122 or M552 says it is connected and you can ping it but not connect to it from a browser), send M586 P0 S0 from USB, followed by M586 P0 S1 to disable then enable HTTP. Watch out for any network debug messages when you do that.
            2. Try installing DuetWiFiServer 1.21RC1 from https://github.com/dc42/RepRapFirmware/tree/dev/EdgeRelease. It should work OK with main firmware 1.20.
            • Nuvagundefined
              Nuvag
              Will try this the next time.
              Until then maybe this helps:
              I had the debug enabled when loosing the connection in the web interface ('Communication Error'):
              New conn on socket 1 for local port 80
              Found responder
              Received 411 bytes
              Found responder
              Received 411 bytes
              Found responder
              Received 411 bytes
              Found responder
              Received 411 bytes
              Found responder
              Received 411 bytes
              Found responder
              Received 411 bytes
              Found responder
              Received 411 bytes
              Found responder
              Received 411 bytes
              Found responder
              Received 411 bytes
              New conn on socket 2 for local port 80
              Found responder
              Received 475 bytes
              New conn on socket 3 for local port 80
              Found responder
              Received 475 bytes
              Found responder
              Received 475 bytes
              Found responder
              Received 475 bytes
              Found responder
              Received 475 bytes
              New conn on socket 4 for local port 80
              Found responder
              Received 475 bytes
              New conn on socket 5 for local port 80
              Found responder
              Received 475 bytes
              Found responder
              Received 475 bytes
              Found responder
              Received 475 bytes
              Found responder
              Received 475 bytes
              Found responder
              Received 475 bytes
              Found responder
              Received 475 bytes
              Found responder
              Received 475 bytes
              Found responder
              Received 475 bytes
              Found responder
              Received 475 bytes
              Found responder
              Received 475 bytes
              Found responder
              Received 475 bytes
              Found responder
              Received 475 bytes
              New conn on socket 6 for local port 80
              Found responder
              Received 475 bytes
              Found responder
              Received 475 bytes
              New conn on socket 7 for local port 80
              Found responder
              Received 475 bytes
              Found responder
              Received 475 bytes
              Found responder
              Received 475 bytes
              Class Network spinning
              For a very long time it uses socket 0 (not included in the log above), than for a long time using socket 1 and finally in quick succession other sockets. Additionally the number of bytes increase from 411 to 475.
              As reloading the webinterface got it connected again, i could not try your instructions. (now its using socket 6 and size is back to 411 bytes)
                If pressing the Connect button doesn't work but reloading the web interface does, that suggests the browser tab may have locked up, probably because of an unhandled exception. If the Connect button is completely unresponsive, try pressing control-shift-J to open the debugging console, and see whether any Javascript exceptions have been reported.
                • Nuvagundefined
                  Nuvag
                  Sorry for the confusing order of my reports, as the problems aren't reproducable at will it have tom report them as they appear.
                  Just now i had again the problem of not fully loading web interface.
                  Restarting HTTP did not work and produced no additional messages.
                  Here are the different errors i got from the developer tools in my browser when repeatedly loading the page: (Sorry for the german message text)
                  Error: Invalid dimensions for plot, width = 1647, height = 0
                  dwc.js:3:35051
                  HTTP404: NICHT GEFUNDEN: Der Server hat keine Übereinstimmungen für den angeforderten URI (Uniform Resource Identifier) gefunden.
                  (XHR)GET - http://192.168.178.15/rr_download?name=0:/sys/oem.json
                  Laden fehlgeschlagen für das
                    Thanks, I'll ask chrishamm to take a look (he wrote DWC and is German himself).
                    The "oem.json not found" is normal, that's an optional file.
                    The "could not load the script" is odd. Are any further details given about the nature of that error?
                    • Nuvagundefined
                      Nuvag
                      No, got no further details. But it noticed sometimes it takes >30 seconds to load http://192.168.178.15/js/dwc.js in an own browser tab, so i suspect its a timeout. After restarting wifi the loadtime is consistantly around 1 second.
                      This javascript is very large, above 1MB (300 KB zipped) and not cached in the browser. This could probably be optimized, but should not be the root cause. But if memory is in short supply and the gzip version is created on the fly this could be a problem(?)
                      webinterface just lost connection again, this time if found an "Unexpected state change on socket X":
                      Found responder
                      Received 488 bytes
                      Found responder
                      Received 475 bytes
                      Client disconnected on socket 6
                      Found responder
                      Received 475 bytes
                      Found responder
                      Received 488 bytes
                      Found responder
                      Received 475 bytes
                      Unexpected state change on socket 7
                      Found responder
                      Received 488 bytes
                      Found responder
                      Received 475 bytes
                      Found responder
                      Received 488 bytes
                      Found responder
                      Received 488 bytes
                        What make and model is your router?
                        • parovoZZundefined
                          parovoZZ
                          Hi!
                          Same problem. Try connect … connect ... connect ... F5 ... nothing.
                          I connect via USB. I make Disable Wi-Fi / Enable Wi-Fi. After that it works 1 hour ... 2 ... 3 hours ... Ping is always stable (2-100 ms).
                          1.20 firmware.
                          • Nuvagundefined
                            Nuvag
                            I'm using a Fritz!Box 7490.
                            Just now lost connection again (webinterface won't load at all, but ping is successful) and tried your instruction but with no usefull output during deactivating/activating http and couldn't connect after that.
                            >>> M552
                            SENDING:M552
                            WiFi module is connected to access point ewl-internet.ch_40357, IP address 192.168.178.15
                            >>> M586 P0 S0
                            SENDING:M586 P0 S0
                            HTTP is disabled
                            >>> M586 P0 S1
                            SENDING:M586 P0 S1
                            HTTP is enabled on port 80
                            I tried rebooting the Fritz!Box and duet wifi will timeout while trying to reconnect (as booting the router takes about a minute). I reactivated wifi with M552 S1 but webinterface will still not load. Diable/Enable HTTP did again not help. (ping does work)
                            Disabling and reenabling Wifi (M552 S0 M552 S1) did bring the webinterface back.
                            So M552 S0 seems to "unblock" the webinterface.
                            Did not yet update the webserver to 1.21, will do next.
                            • Nuvagundefined
                              Nuvag
                              Tonight i printed a model and closed the webinterface windwo in the brower.
                              This morning i couldn't connect to the webinterface (but ping still ok), so its probably not the polling from the webinterface thats causing the issue.
                              The log only contains about a hundret entries "Class Network spinning", no error messages.
                                When you are unable to connect but able to ping, if you run M552 without parameters, does it report that the Duet is connected to your network, or not?
                                • Nuvagundefined
                                  Nuvag
                                  Yes, i actually included that part in my last message because i thought you would ask that 🙂
                                  >>> M552
                                  SENDING:M552
                                  • Nuvagundefined
                                    Nuvag
                                    Updated Webserver to 1.21.RC1 and immediatly having an instable connection, debug log:
                                    WiFi: fGLUE: fragmented pbuf (932!=1514)!
                                    WiFi: GLUE: fragmented pbuf (932!=1514)!
                                    When reloading the page:
                                    Unexpected state change on socket 0
                                    Can't send anymore
                                    New conn on socket 0 for local port 80
                                    HTTP connection accepted
                                    Found responder
                                    Found responder
                                    Received 330 bytes
                                    Sending reply, file = yes
                                    HTTP req, command words { GET / HTTP/1.1 }, parameters { }
                                    Received 339 bytes
                                    HTTP req, command words { GET /css/dwc.css HTTP/1.1 }, parameters { }
                                    Found responder
                                    Received 357 bytes
                                    HTTP req, command words { GET /js/dwc.js HTTP/1.1 }, parameters { }
                                    WiFi: GLUE: fragmented pbuf (788!=1514)!
                                    Still having the same issue with http://192.168.178.15/js/dwc.js
                                    When the connection is stable there are no messages with 'WiFi: GLUE: fragmented pbuf <…>', so this might be the cause of the problem.
                                    Edit:
                                    Additionally there is a problem with the html in line 1708:
                                    should be
                                    • Nuvagundefined
                                      Nuvag
                                      Webinterface was online 6 hours without a problem then failed again.
                                      I used Wireshark to capture the network traffic, maybe this can help fpr further analysis.
                                      This happened in the moment the connection was lost:
                                      https://www.dropbox.com/sh/r9zkw9id482i9z0/AAA-x0NTtIISPxijZnqTiZj0a/Wireshark_DuetWifi.PNG?dl=0
                                      This was from Microsoft Edge Browser. So my PC sent an reset and from then on all requests to the duet wifi return a reset. This continues until the ajax retry limit is reached (i set it to 50 retries).
                                      I found other occurences earlier where my PC closed the connection but a new one could be established without problems.
                                      Then tried to open the webinterface in a different browser (Firefox) and got:
                                      https://www.dropbox.com/sh/r9zkw9id482i9z0/AADPnonPL1ApvNZzF8qBnV-Va/Wireshark_DuetWifi_2.PNG?dl=0
                                      I suspect for some reason all available sockets from the wifi module in the duet to the internal modules get blocked and won't be unblocked until restarting the wifi. This would explain why the wifi connection works in general (can ping and open tcp connection) but it fails when trying to get the status report.
                                        Thanks, I suspected that these problems might be caused by a lack of sockets. Which version of DuetWiFiServer are you using?
                                        • Nuvagundefined
                                          Nuvag
                                          Firmware Name:
                                          Firmware Electronics:
                                          Duet WiFi 1.0
                                          Firmware Version:
                                          1.20 (2017-12-23)
                                          WiFi Server Version:
                                          1.21RC1
                                          Web Interface Version:
                                          1.20
                                          • parovoZZundefined
                                            parovoZZ
                                            Hi!
                                            Is it possible to make a program reset of the Wi-Fi module on an external button? For example, execute a script:
                                            M552 S-1;
                                            M552 S1;
