Firmware 1.20 released
Tried the last FW you sent. Unfortunately, the problem remains (when using DHCP).
FWIW, I have an ASUS RT-N66U Router. Works like a charm with all my other devices. Here's the Duet info:[[language]] (21:06:41.110) M122 (21:06:41.267) === Diagnostics === (21:06:41.267) Used output buffers: 1 of 32 (1 max) (21:06:41.267) === Platform === (21:06:41.267) RepRapFirmware for Duet version 1.21RC0+1 running on Duet 0.6 (21:06:41.267) Static ram used: 44836 (21:06:41.267) Dynamic ram used: 40764 (21:06:41.267) Recycled dynamic ram: 416 (21:06:41.267) Stack ram used: 3520 current, 4316 maximum (21:06:41.267) Never used ram: 7972 (21:06:41.267) Last reset 00:00:33 ago, cause: software (21:06:41.267) Last software reset time unknown, reason: Stuck in spin loop, spinning module Network, available RAM 8032 bytes (slot 3) (21:06:41.267) Software reset code 0x2041 HFSR 0x00000000, CFSR 0x00000000, ICSR 0x0440f80f, BFAR 0xe000ed38, SP 0x20087e64 (21:06:41.267) Stack: 000c10d7 00000001 fffffff9 00000001 20087ebc 20070fe8 00000001 20087ebc 000a76e3 000a7fb4 21000000 2007a9ac 0000012c 00000123 00000000 2007376c 200737a8 2007a938 00000127 2007aea8 000000f0 be5a1f3c 01c8a8c0 2007376c (21:06:41.267) Error status: 0 (21:06:41.267) Free file entries: 10 (21:06:41.267) SD card 0 detected, interface speed: 21.0MBytes/sec (21:06:41.267) SD card longest block write time: 0.0ms (21:06:41.267) MCU temperature: min 24.0, current 25.8, max 26.1 (21:06:41.267) Date/time: 1970-01-01 00:00:00 (21:06:41.267) Slowest main loop (seconds): 0.000401; fastest: 0.000101 (21:06:41.267) === Move === (21:06:41.267) MaxReps: 0, StepErrors: 0, LaErrors: 0, FreeDm: 100, MinFreeDm 100, MaxWait: 0ms, Underruns: 0, 0 (21:06:41.267) Scheduled moves: 0, completed moves: 0 (21:06:41.267) Bed compensation in use: mesh (21:06:41.267) Bed probe heights: 0.000 0.000 0.000 0.000 0.000 (21:06:41.267) === Heat === (21:06:41.267) Bed heaters = 0, chamberHeaters = -1 -1 (21:06:41.267) Heater 1 is on, I-accum = 0.0 (21:06:41.267) === GCodes === (21:06:41.267) Segments left: 0 (21:06:41.267) Stack records: 2 allocated, 0 in use (21:06:41.267) Movement lock held by null (21:06:41.267) http is idle in state(s) 0 (21:06:41.267) telnet is idle in state(s) 0 (21:06:41.267) file is idle in state(s) 0 (21:06:41.267) serial is ready with "M122" in state(s) 0 (21:06:41.267) aux is idle in state(s) 0 (21:06:41.267) daemon is idle in state(s) 0 (21:06:41.267) queue is idle in state(s) 0 (21:06:41.267) autopause is idle in state(s) 0 (21:06:41.267) Code queue is empty. (21:06:41.267) === Network === (21:06:41.267) Free connections: 16 of 16 (21:06:41.267) Free transactions: 24 of 24 (21:06:41.267) Locked: 0, state: 2, listening: 0x0, 0x0, 0x0 (21:06:41.267)
Have you given up on this? I have no problems to live with the quirk as it is an old legacy board and does not disrupt operation when the workaround has been applied. Although, maybe this should be documented in a FAQ or in the WIKI.
/Thom
Are there any plans to enable network drive functionality on the duet? I ask because it would make scripting functionality a lot simpler, I'm planning to make an attachment to allow a USB dial indicator to write a CSV mesh levelling file by just dragging it across the bed without lifting.
/Thom
Please can you run the 1.21RC1 release and get another M122 report when the problems happen again, as I no longer have the symbol files and assembly listing for that temporary release so I can't relate the software reset data to the code.
We have no plans to do this with the current Duets. There probably isn't enough memory to run a protocol like CIFS or NFS, and the protocols that provide a block-level interface over the network can't handle local reads/writes at the same time. But the next generation Duets will eventually be able to provide this.
Meanwhile there are HTTP and FTP commands available to manipulate files on the SD card via the network.
Ok, thanks for the quick response David, just a convenience thing, I'll have to dig back in my memory banks for http and ftp manipulation.
/Thom
I already did. It's here in this thread, in the 11'th post:
https://www.duet3d.com/forum/thread.php?id=4195 -
Thanks, I've made a note to look at that report.
I have a proposal for you David. I'll send my 0.6 Duet to you (I'll cover the freight cost myself). I'll swap it for any other Duet type board you might have in your bins, as long as it works.
/Thom
It's by no means clear that the problem is with the Duet.
I'm not saying it does, although there are some circumstantial evidence pointing in that direction (1.19 worked fine /w DHCP). I was thinking more in terms of giving you a chance to examine the actual board in your lab. It's up to you if you think that doing so has any value or not, I can live with the fixed IP address in order to benefit from the new features in the latest FW releases.
/Thom
