Special characters in UI
The fonts used in PanelDue currently have Unicode code points 0x00 to 0xFF. Some of the characters you want are a little higher than that. So the first thing you need to do is extend the font range to include the extra characters. It looks to me that you need to go up to 0x17F.
After that, it should just be a case of ensuring that all the text strings are encoded in UTF8 format. If you are getting rectangles everywhere then I suspect the editor you are using isn't saving the file in UTF8 format.
HTH David
I also have encoding issue:
I use russian file names (Cyrillic characters абвгдеёжз…) and in case i upload file directly from slic3r, in duet encoding is messed...
exporting same .gcode file from slic3r to PC file system works well
David, is it something that can be fixed in duet3D? i can email you file for test… thanks!
Also, if file name has brackets ---> USB штекер (испр.).gcode
duetWiFi is not able to find it after direct send from s3r.... -
How are you uploading the file directly from slic3r? If you are using a plugin, perhaps that plugin doesn't handle UTF8-encoded filenames.
HTH David
For starters I checked files for encoding, fixed that and reflash. Some characters worked. Nice
Second I tried to expand font array, but it is limited by uint8_t which has max value 255. Now I have to dig a litle deeper and use uint16_t. -
It looks to me that the following changes are needed:
- members firstChar and lastChar of struct FontDescriptor need to be changed from uint8_t to uint16_t
- parameter to writeNative needs to be changed to uint16_t
- in UTFT::writeNative, translation should only be attempted if the character is <= 0xFF (but I don't think the translation mechanism is needed any more)
- a few changes are also needed to UTFT::write.
I will make these changes in the next beta of PanelDueFirmware.
Slic3r supports uploading to the Duet natively, it's in Printer Settings -> Print server upload. I'm not sure when the support was added but I'm using it for quite a while now.
i upload directly from slic3r. there is a special option for duet in printer settings. no plug-ins at all… see below
Looking forward to that
I have made those changes, tested them, and committed them to github. I will make further unrelated changes before I do a release.
Great. I've now tested build and getting ready generated font characters (GLCD Font Creator not cooperating as I expected, needs a little bit tuning) and translations. I'll hopefully finish it soon.
Ok, now it's working. I've created pull request on github repo. Characters are generated and tested.
Interesting issue was, that GLCD Font Creator can't create characters after 0xFF. So I had to setup lcd-image-converter with some postprocessing scripts to get it done. But now it's perfect
Testing screen:
file system is still an issue with unicode file names. 1.21 RC3
Can you give an example? I keep some files with UTF8 characters in them on my SD card, and they are still displayed correctly, with the following limitations:
- PanelDueFirmware prior to 1.20RC3 only displays characters up to U+0x00FF
- PanelDueFirmware 1.20RC3 (which I expect to release later today) on a 5" or 7" panel displays characters up to U+0x017F
- PanelDueFirmware 1.20RC3 on a 4.3" panel doesn't display characters U+0x0100 to U_0x017F correctly because the font table is wrong
