I don't understand why this is happening
Hi
Thanks. I will try that. I think I need to put the I1 back into M558. I suspect I should rewire the end stop for the Z Probe -
Sorry but I can't help there but if you would like to do the cal semi automatically you could change the probe type to P0 run the autodial routine and follow the on screen prompts
Have you tested the Z probe? See https://duet3d.com/wiki/Test_the_Z_probe.
By default, the metal switch tab is pressed against the little red switch button. The button is pushed in. The light on the board is off
When the nozzle contacts the bed, I hear the click and the light comes on and the metal tab along with the little red button switch are released.
The wiring is to the two outside terminals on the switch.
M558 P1 H10 F120 T2400 I1
When it probes, it reports that it is already triggered.
If I remove the I1 from the end of the M558 Line, the message is that the probe was not triggered, and the probe crashes the bed.
Should I move 1 wire to the center pin from the outside pin and would it matter which wire I moved?
You should be using P4 if you are using the E0 Stop connector for your Z probe.
Increase the X, Y and Z numbers in your G1 S1 X305 Y305 Z305 bed.g file to 400+ to keep from having to double tap the home button when the effector is on the build plate and close to the edge.
Don't forget to add M501 to the end of your config.g to use the settings you save in config-override.
Use M558 P4 as number40fan says, and remove the I1.
Ok
I removed the I1 from the M558. The nozzle drops down to about 10mm above the bed, and moves to all of the expected locations. It does not move down to contact the bed. I get a message for every probe point that was to be used indicating that the Z probe was already triggered.The value reported for the Z probe is 1000
Did you try it with the I1? With DWC open, change the I1 setting and reboot. Then while watching the Z Probe reading the in the top right hand corner, see if it sits at 0 when the Z probe is not touched and goes up when touched (with your hand).
With the I1 back in, the probe value is 0
If I touch the hot end to trigger the probe, the value changes to 1000
That is the correct behaviour. What problem (if any) are you having now?
Wow!!!
Fantastic!!!!!! Auto Delta Calibration just completed a perfect cycle. Hot end dropped to about 10mm above be, and then gently touched down at 10 specific points, clicked the switch and moved on!!!
Thanks so much for the support and the help.
Now I can try to calibrate the extruder which is either putting out too much filament, or my layer height settings are off, or…....
