[3.6.0-rc.2] Z-probe hits bed and U not moving running Mesh
@tcamguil said in [3.6.0-rc.2] Z-probe hits bed and U not moving running Mesh:
On the other hand do you have an idea about what could be causing the toolboard to fail to detect the status change of the klicky thus attempting to push it through the bed?
I'd guess it's looking for a response from the wrong probe. Are you using G29 with a K parameter? Also check that any deployprobe#.g, retractprobe#.g and tool change macros (tpre#.g, tpost#.g and tfree#.g) are all numbered appropriately for the correct tool and probe. If you leave off the number (the #), that macro will be running for ALL probes/tools.
For the heightmaps, @dc42 is looking into this. However, to me it looks like the order of the axes are incorrect when doing a mesh bed on the tool with U mapped to X, because it is listing the Y axis before U, when it should be U first. Can you post your full config.g, so I can see how you've set up your tools?
I also think the mesh is being applied correctly (though not in the correct order), ie a mesh that has been made on the XY axes affects the XY axes but not U, and a mesh made on the UY axes affects the X when U is mapped to it, and UY axes. You generally wouldn't command a U axis move during a job, so this seems sensible.
@droftarts
After hours of trying to debug this issue here are the three files left on my printer
@droftarts said in [3.6.0-rc.2] Z-probe hits bed and U not moving running Mesh:
G29 is using K1. I don't use / don't like using the deployprobe/retractprobe pair as it has a tendency to pickup/drop the probe too frequently when running a full machine calibration. tfree-tpre-tpost macros are all correctly numbered
For the heightmap I suppose the machine is configuring the mesh in the order of the axes in the firmware (ie: XYZUVWABC...) so it will select Y then U when calibrating, I may be wrong here but it seems logical to me maybe the firmware is selecting Y as both the first axis and the default Y axis (I could not quite understand how the mesh is working under the hood).
That is also my point of view I think the Heightmap is correctly applied, Both toolheads were applying the compensation while the XY heightmap was active.
The fact that the Heightmap is rotated when displayed on the DWC is an old issue as is the points being meshed and saved in the "wrong" order. It was for me just a quirk of the Firmware (the spacing has to be declared backwards Y then U). -
@tcamguil please try the 3.6.0-rc.2+1firmware from https://www.dropbox.com/scl/fo/kj7gwwzxg5lhe26twph5z/AAdwkPCTYi6bcogLmIIIup4?rlkey=8oo6z5il7wzk2u5b7qpykf3qv&dl=0. Let us know if you are able to generate the correct heightmap for the U/Y tool.
The good news is the points seems to be taken in the "right" order now.
But the toolhead connected to the U motor needs to be active while the mesh is running for the U axis to move.
Which was not needed for RRF3.6.0-rc1 and before.
The points are being recorded in the right order in the heightmap file.But the Klicky triggering was not detected again about midway through the second mesh calibration breaking it.
@tcamguil as a workaround to the U motor not moving unless the toolhead is active, try executing a short G1 U move before probing.
I can't think of any reason why the klicky triggering would not be detected other than a wiring issue, e.g. a bad crimp connection that causes a bad connection at some UY locations but not others.
@tcamguil I believe I have fixed the issue of the U axis not moving. Please try the 3.6.0-rc.2+2 firmware at https://www.dropbox.com/scl/fo/nlkfneaas1osgtdw37s17/AIS_H0KSAKCmfYSjSRTSOAE?rlkey=ad4omnq36zkdz3wl8i7kthqqt&dl=0.
@dc42, it is working now. Thank you for the quick update.
I guess it could be a bad connection.But why does it happens at random points on the buildplate. And why can't I reproduce the issue on RRF 3.6.0-RC.1 or before. Could it be an issue with the debouncer ?
I switched to a NO sensor and the issue is now flipped the error is now "Error: G29: Probe already triggered before probing move started". and the Z-probe status is stuck in the triggered state until I trigger/un trigger it manually.
@tcamguil regarding the Klicky probe not triggering, please try the updated 3.6 tool board firmware at https://www.dropbox.com/scl/fo/vyin5beexljdndp3c00ln/AE6qWXcANSDo40ffsEaRZI4?rlkey=5kc28a1jbr7hu4l90w5shovh1&dl=0.
@dc42 thank you very much.
I was able to run multiple consecutive meshes an increasing probing speeds without issues.
I think this solves the last of my issues. -
@tcamguil thanks for confirming this.
undefined dc42 has marked this topic as solved
