Auto Delta Calibration don't work fine for Firmware > 1.17e
Hi:
I have problems with the Auto Delta Calibration when upgrate the Delta printer Firmaware from 1.17e.
The beg.g file seems to be ok, and works fine for 1.17e Firware verions.
But for Firmware 1.19 the heat crash to Z tower.How can I solve this ?
I need to change samething con config.g file?Thanks for your support.
Can you be more especific ?
My printer don't remember that it is configured as Delta Printer and move as
a cartesian printer when I try to print.Thanks.
I am very sorry, I meant #3 on that wiki page, not #1.
Hi:
I have solved the problem, deleting the deployprobe.g and retractprobe.g.
Now, all works fine with DuetEtherned Firm 1.20.1RC2 (2018-01-01) and WebInterface 1.19.What is the difference with DuetEthernetFirmware and RepRapFirmware ?
RepRapFirmware if for Duet 0.6 and 0.8.5 ?I have installed the DuetEthernetFirmware on my new DuetEtherned board.
Thank you for you help.
Regards.
Yes, RepRapFirmware.bin is the build for the older Duets.
