Duet 2 wifi AND LIS3DH
@droftarts said in Duet 2 wifi AND LIS3DH:
@luc Like I said, it's better to use:
CS / PIN 1 SPI_CS2 cavo arancione
INT1 / PIN 3 SPI_CS1 cavo verdeIf you add a temperature daughterboard in the future, you won't have to change the wiring when you plug the accelerometer in on top of the temperature daughterboard, only the configuration.
Yeah, yeah...okay, thank you.
Here I am again!
Continuing to study the settings, I arrived at the M955 setting.
From what I understand in config.g I enter:M955 P0 C “spi.cs4+spi.cs3” (change cs4 and cs3 if I use different pins)
But I also need to set the orientation (which for me will follow the axis orientation) so I add:
M955 P0 I20I am not clear if I also have to add the S and R paramenters so it becomes:
M955 P0 I20 S5000 R10 ? -
@luc no need to mess with S and R so don't include them
@jay_s_uk Okay, thank you.
So do I just use M955 P0 I20 or not even that which seems to me that by default it considers it oriented according to the axis direction of the sensor? -
@luc you'll probably need to adjust the I value once you get it installed and work out which way its pointing
Connected as per the description above. The acelerometer led is on green.
Entered the following string in config.g:
M955 P0 C “spi.cs4+spi.cs3”I try to send M955 and get the following message:
Error: M955: missing parameter 'P'
I read the guidea and for the connection type it seems to me that P0 is correct. What am I doing wrong?
Despite the error in my previous post I tried to see if it worked and it did....did the first test.
I attach the image and I would like to know from you who are experts what you think. I got an idea nma would like your opinion. Thank you -
@luc That is the hardware wiring part of M955. You must also tell Duet the communication settings.
;M955 P0 C"spi.cs4+spi.cs3";LIS3DH ;M955 P0 I25 S1344 R10 ; S1344 is 1344Hz sample rate. R10 is 10 bit resolution for LIS3DH.
You can enter all of the parameters on one line if you like.
Make sure to check your orientation for the I parameter and insert the appropriate two numbers.
@tas said in Duet 2 wifi AND LIS3DH:
Thank you for your response.
I added M955 P0 I20 S1344 R10 but if I send m955 I always get: Error: M955: missing parameter 'P' -
@luc You have to send M955 P0. Sorry early in the day for me! There are defaults for the other settings which is why it works for you.
@luc Also I should have removed the semicolons in front of each line before posting the code. I now use another acclerometer.
@tas
OK...It's ok. Now with m955 po no longer gives error and responds with parametersmany thanks
@luc said in Duet 2 wifi AND LIS3DH:
M955 P0 C “spi.cs4+spi.cs3”Make sure you are using straight quote marks, not curly quote marks, ie the above should be
Error: M955: missing parameter 'P'What firmware version are you using? Send M122 and post the response.
All ok, thank you too!The first test performed is what I insierite a few posts above.
Can you give me your opinion on the result?
Is there a document to read that explains how to interpret the values?
I am using duet 2 wifi e firmware 3.5.4.
And this is my M122:
4/04/2025, 15:09:29: m122: === Diagnostics ===
RepRapFirmware for Duet 2 WiFi/Ethernet version 3.5.4 (2024-11-24 10:43:42) running on Duet WiFi 1.02 or later + DueX2
Board ID: 08DJM-9178L-L4MSJ-6J1DL-3S46R-TV3GP
Used output buffers: 4 of 26 (25 max)
Static ram: 23488
Dynamic ram: 75300 of which 152 recycled
Never used RAM 11420, free system stack 118 words
Tasks: NETWORK(1,ready,16.6%,217) ACCEL(6,nWait 5,0.0%,249) HEAT(3,nWait 5,0.1%,328) Move(4,nWait 5,0.0%,258) DUEX(5,nWait 5,0.0%,23) MAIN(1,running,83.3%,746) IDLE(0,ready,0.0%,29), total 100.0%
Owned mutexes:
Last reset 00:46:02 ago, cause: software
Last software reset at 2025-04-04 14:23, reason: User, Gcodes spinning, available RAM 11364, slot 0
Error status: 0x00
Aux0 errors 0,0,0
MCU temperature: min 19.1, current 19.6, max 19.8
Supply voltage: min 12.3, current 12.4, max 12.5, under voltage events: 0, over voltage events: 0, power good: yes
Heap OK, handles allocated/used 99/0, heap memory allocated/used/recyclable 2048/16/16, gc cycles 0
Events: 0 queued, 0 completed
Driver 0: standstill, SG min n/a
Driver 1: standstill, SG min n/a
Driver 2: standstill, SG min n/a
Driver 3: standstill, SG min n/a
Driver 4: standstill, SG min n/a
Driver 5: standstill, SG min n/a
Driver 6: standstill, SG min n/a
Driver 7:
Driver 8:
Driver 9:
Driver 10:
Driver 11:
Date/time: 2025-04-04 15:09:27
Slowest loop: 6.95ms; fastest: 0.19ms
=== Storage ===
Free file entries: 10
SD card longest read time 0.5ms, write time 0.0ms, max retries 0
DMs created 83, segments created 11, maxWait 0ms, bed compensation in use: none, height map offset 0.000, max steps late 0, min interval 0, bad calcs 0, ebfmin 0.00, ebfmax 0.00
no step interrupt scheduled
Moves shaped first try 0, on retry 0, too short 0, wrong shape 0, maybepossible 0
=== DDARing 0 ===
Scheduled moves 38, completed 38, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1
Heater 1 is on, I-accum = 0.0
Movement locks held by null
HTTP is idle in state(s) 0
Telnet is idle in state(s) 0
File is idle in state(s) 0
USB is idle in state(s) 0
Aux is idle in state(s) 0
Trigger is idle in state(s) 0
Queue is idle in state(s) 0
LCD is idle in state(s) 0
Daemon is idle in state(s) 0
Q0 segments left 0
Code queue 0 is empty
=== DueX ===
Read count 0, 0.00 reads/min
=== Network ===
Slowest loop: 20.99ms; fastest: 0.07ms
Responder states: HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0)
HTTP sessions: 1 of 8
=== WiFi ===
Interface state: active
Module is connected to access point
Failed messages: pending 0, notrdy 0, noresp 0
Firmware version 2.2.0
MAC address b4:e6:2d:60:b9:99
Module reset reason: Turned on by main processor, Vcc 3.32, flash size 4194304, free heap 39192
WiFi IP address 192.168.0.40
Signal strength -43dBm, channel 1, mode 802.11n, reconnections 0
Clock register 00002002
Socket states: 0 0 0 0 0 0 0 0 -
https://docs.duet3d.com/en/User_manual/Tuning/Input_shaping_plugin#determining-ringing-frequencies
Your graph is showing a peak at around 74Hz, but this is after the ZVD shaper has been applied. It's also important to look at the 'Amplitude' scale, as this shows there is only a very small amount of ringing. I'd run it a few times, try different shapers, and get a sense for what is changing with the different shapers. Then do a test print, ideally one with IS off, and one with it on, to see if it is making the improvement you hoped for.
It's not really possible from just one image to suggest exactly what settings are best, especially seeing the results after a shaper is applied. Seeing the raw results should show where the largest issue is. I'm also not the best person to ask, as I don't actually have that much experience with tuning input shaping!
@droftarts
That 74Hz spike was there before without applying any shaper.
I think that spike is because of a very slight play (which I discovered a few days ago) that the linear X-axis drive. I think it affects both X and Y. In fact I have to disassemble and try to change the balls. After that I can compare and see if that spike was due to that and whether to uncommpare.
It is an xy core and apart from that nasty 7aHz spike it seems to me that there is no excessive vibration/resonance also because the Amplitude is at most 0.010 for a part but mostly within 0.005.The paper you linked me I had studied, po thought there was some with more graphs and different examples.
You are so kind, thank you again!
@luc did you have any fans running when you did the measurements? If so then the 74Hz spike may have been vibration from a fan. 74Hz is 4440 rpm.
@dc42 said in Duet 2 wifi AND LIS3DH:
No, fans off. I did the standard test as it is set up by default. I know I have a very small play on the X-axis linear guide (it is a XY core). But I am not sure if the 74Hz is caused by the guide or all by the guide. Tomorrow I will try to tie a weight on my head to see if it changes. If you have any ideas for some tests I would be happy to do them. Thanks for your interest.
@luc the movement of the belt over the toothed pulleys can also cause vibration. To check this, repeat the input shaping test moves at a different speed and see whether the frequency changes. Alternatively, un-check the box to take readings over the whole move and see if the peak goes away.
