Laser filament monitor frame errors with 3.6rc1 but not 3.6beta4
I am getting high numbers of frame errors with a laser filament monitor under 3.6rc1 on my delta with standalone duet2wifi
06/03/2025, 15:42:03 m122 === Diagnostics === RepRapFirmware for Duet 2 WiFi/Ethernet version 3.6.0-rc.1 (2025-02-28 14:56:47) running on Duet WiFi 1.0 or 1.01 Board ID: 08DAM-999TL-MQ4SD-6J9FD-3SJ6J-K593W Used output buffers: 1 of 26 (21 max) === RTOS === Static ram: 24016 Dynamic ram: 68004 of which 12 recycled Never used RAM 17908, free system stack 108 words Tasks: NETWORK(1,ready,17.3%,195) LASER(5,nWait 6,1.4%,214) HEAT(3,nWait 5,0.1%,328) Move(4,nWait 5,4.2%,263) MAIN(1,running,77.1%,836) IDLE(0,ready,0.1%,29), total 100.0% Owned mutexes: === Platform === Last reset 01:44:08 ago, cause: software Last software reset at 2025-02-28 19:38, reason: User, Gcodes spinning, available RAM 25988, slot 2 Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x00400000 BFAR 0xe000ed38 SP 0x00000000 Task MAIN Freestk 0 n/a === Storage === Free file entries: 10 SD card 0 detected, interface speed: 20.0MBytes/sec SD card longest read time 10.2ms, write time 0.0ms, max retries 0 === Move === Segments created 419, maxWait 655163ms, bed comp in use: none, height map offset 0.000, hiccups added 0/69 (2.20ms), max steps late 1, ebfmin 0.00, ebfmax 0.00 Pos req/act/dcf: 104132.00/104132/0.00 104132.00/104132/-0.00 104132.00/104132/0.00 No step interrupt scheduled Driver 0: standstill, SG min 0 Driver 1: standstill, SG min 0 Driver 2: standstill, SG min 0 Driver 3: standstill, SG min 0 Driver 4: standstill, SG min 0 Driver 5: Driver 6: Driver 7: Driver 8: Driver 9: Driver 10: Driver 11: === DDARing 0 === Scheduled moves 607467, completed 607467, LaErrors 0, Underruns [0, 0, 0] Segments left 0 Code queue is empty === Heat === Bed heaters 0 -1 -1 -1, chamber heaters -1 -1 -1 -1, ordering errs 0 === GCodes === Movement locks held by null HTTP is idle in state(s) 0 Telnet is idle in state(s) 0 File is idle in state(s) 0 USB is idle in state(s) 0 Aux is idle in state(s) 0 Trigger is idle in state(s) 0 Queue is idle in state(s) 0 LCD is idle in state(s) 0 Daemon is idle in state(s) 0 Autopause is idle in state(s) 0 === Filament sensors === Driver 11: pos 0.00, brightness 20, shutter 131, errs: frame 31209 parity 0 ovrun 0 pol 0 ovdue 0 === Network === Slowest loop: 204.68ms; fastest: 0.07ms Responder states: HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0) HTTP sessions: 2 of 8 === WiFi === Interface state: active Module is connected to access point Failed messages: pending 0, notrdy 0, noresp 0 Firmware version 2.2.1 Module reset reason: Turned on by main processor, Vcc 3.38, flash size 4194304, free heap 39404 MAC address 5c:cf:7f:2c:24:6b IP address 192.168.1.16 Signal strength -50dBm, channel 8, mode 802.11n, reconnections 0 Clock register 00002002 Socket states: 0 0 0 0 0 0 0 0
the same print with 3.6beta4 does not show this effect
06/03/2025, 13:54:14 m122 === Diagnostics === RepRapFirmware for Duet 2 WiFi/Ethernet version 3.6.0-beta.4 (2025-02-11 09:50:40) running on Duet WiFi 1.0 or 1.01 Board ID: 08DAM-999TL-MQ4SD-6J9FD-3SJ6J-K593W Used output buffers: 1 of 26 (19 max) === RTOS === Static ram: 24016 Dynamic ram: 68468 of which 12 recycled Never used RAM 17300, free system stack 108 words Tasks: NETWORK(1,ready,15.2%,181) LASER(5,nWait 6,1.3%,214) HEAT(3,nWait 5,0.1%,292) Move(4,nWait 5,3.8%,239) MAIN(1,running,79.5%,745) IDLE(0,ready,0.0%,29), total 100.0% Owned mutexes: === Platform === Last reset 01:53:31 ago, cause: software Last software reset at 2025-02-28 19:38, reason: User, Gcodes spinning, available RAM 25988, slot 2 Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x00400000 BFAR 0xe000ed38 SP 0x00000000 Task MAIN Freestk 0 n/a === Storage === Free file entries: 9 SD card 0 detected, interface speed: 20.0MBytes/sec SD card longest read time 9.9ms, write time 4.2ms, max retries 0 === Move === Segments created 425, maxWait 1215359ms, bed comp in use: none, height map offset 0.000, hiccups added 0/123 (4.02ms), max steps late 1, ebfmin 0.00, ebfmax 0.00 Pos req/act/dcf: 104132.00/104132/0.00 104132.00/104132/-0.00 104132.00/104132/0.00 No step interrupt scheduled Driver 0: standstill, SG min 0 Driver 1: standstill, SG min 0 Driver 2: standstill, SG min 0 Driver 3: standstill, SG min 0 Driver 4: standstill, SG min 0 Driver 5: Driver 6: Driver 7: Driver 8: Driver 9: Driver 10: Driver 11: === DDARing 0 === Scheduled moves 607474, completed 607474, LaErrors 0, Underruns [0, 0, 0] Segments left 0 Code queue is empty === Heat === Bed heaters 0 -1 -1 -1, chamber heaters -1 -1 -1 -1, ordering errs 0 Heater 0 is on, I-accum = 0.3 === GCodes === Movement locks held by null HTTP is idle in state(s) 0 Telnet is idle in state(s) 0 File is doing "G4 S90" in state(s) 0 USB is idle in state(s) 0 Aux is idle in state(s) 0 Trigger is idle in state(s) 0 Queue is idle in state(s) 0 LCD is idle in state(s) 0 Daemon is idle in state(s) 0 Autopause is idle in state(s) 0 === Filament sensors === Driver 11: pos 0.00, brightness 27, shutter 102, errs: frame 0 parity 0 ovrun 0 pol 1 ovdue 0 === Network === Slowest loop: 52.48ms; fastest: 0.07ms Responder states: HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0) HTTP sessions: 2 of 8 === WiFi === Interface state: active Module is connected to access point Failed messages: pending 0, notrdy 0, noresp 0 Firmware version 2.2.1 Module reset reason: Turned on by main processor, Vcc 3.38, flash size 4194304, free heap 36000 MAC address 5c:cf:7f:2c:24:6b IP address 192.168.1.16 Signal strength -47dBm, channel 8, mode 802.11n, reconnections 0 Clock register 00002002 Socket states: 0 0 0 0 0 0 0 0
I see 1-2 thousand frame errors if I do an M122 after switching on and homing the printer, but before doing any printing..
@Adrian52 thanks for reporting this. I suspect that it is caused by enabling debouncing of inputs on Duet 2 and Duet 3 6HC and 6XD in rc1. I'll disable debouncing on filament monitor inputs in the next build.
@dc42 Thank you. I dont know if its relevant, but on my old fuseless duet2wifi, I followed your suggestion of several years ago to use the lcd input for the laser filament monitor:
M591 D0 P5 C"connlcd.encb" R01:300 E10 L0.65 S1 A0
It has been working very reliably since then. -
@Adrian52 please try the firmware at https://www.dropbox.com/scl/fo/0xdvvzgqfrs5abyk75ss8/AL3i6s7z9UacEGYsxiR7pXw?rlkey=xpm61w2jlyqlawwjzy4zsq2lt&dl=0. Use it with caution because I don't have a Duet 2 machine to test it on. I have disabled debouncing on filament monitor inputs in this build.
@dc42 Thank you - that seems to have fixed it. Here is an M122 if you want to check anything. Did not notice anything untoward during this print.
07/03/2025, 13:51:42 m122 === Diagnostics === RepRapFirmware for Duet 2 WiFi/Ethernet version 3.6.0-rc.1+1 (2025-03-07 09:35:55) running on Duet WiFi 1.0 or 1.01 Board ID: 08DAM-999TL-MQ4SD-6J9FD-3SJ6J-K593W Used output buffers: 1 of 26 (19 max) === RTOS === Static ram: 24016 Dynamic ram: 68004 of which 12 recycled Never used RAM 9244, free system stack 108 words Tasks: NETWORK(1,ready,17.5%,181) LASER(5,nWait 6,1.5%,214) HEAT(3,nWait 5,0.1%,313) Move(4,nWait 5,5.7%,243) MAIN(1,running,75.1%,836) IDLE(0,ready,0.1%,29), total 100.0% Owned mutexes: === Platform === Last reset 00:45:51 ago, cause: software Last software reset at 2025-02-28 19:38, reason: User, Gcodes spinning, available RAM 25988, slot 2 Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x00400000 BFAR 0xe000ed38 SP 0x00000000 Task MAIN Freestk 0 n/a === Storage === Free file entries: 10 SD card 0 detected, interface speed: 20.0MBytes/sec SD card longest read time 12.6ms, write time 7.4ms, max retries 0 === Move === Segments created 780, maxWait 121347ms, bed comp in use: none, height map offset 0.000, hiccups added 0/45 (1.43ms), max steps late 1, ebfmin 0.00, ebfmax 0.00 Pos req/act/dcf: 104132.00/104132/0.00 104132.00/104132/-0.00 104132.00/104132/0.00 No step interrupt scheduled Driver 0: standstill, SG min 0 Driver 1: standstill, SG min 0 Driver 2: standstill, SG min 0 Driver 3: standstill, SG min 0 Driver 4: standstill, SG min 0 Driver 5: Driver 6: Driver 7: Driver 8: Driver 9: Driver 10: Driver 11: === DDARing 0 === Scheduled moves 327303, completed 327303, LaErrors 0, Underruns [0, 0, 0] Segments left 0 Code queue is empty === Heat === Bed heaters 0 -1 -1 -1, chamber heaters -1 -1 -1 -1, ordering errs 0 === GCodes === Movement locks held by null HTTP is idle in state(s) 0 Telnet is idle in state(s) 0 File is idle in state(s) 0 USB is idle in state(s) 0 Aux is idle in state(s) 0 Trigger is idle in state(s) 0 Queue is idle in state(s) 0 LCD is idle in state(s) 0 Daemon is idle in state(s) 0 Autopause is idle in state(s) 0 === Filament sensors === Driver 11: pos 0.00, brightness 15, shutter 85, errs: frame 0 parity 0 ovrun 0 pol 0 ovdue 0 === Network === Slowest loop: 201.64ms; fastest: 0.07ms Responder states: HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0) HTTP sessions: 2 of 8 === WiFi === Interface state: active Module is connected to access point Failed messages: pending 0, notrdy 0, noresp 0 Firmware version 2.2.1 Module reset reason: Turned on by main processor, Vcc 3.38, flash size 4194304, free heap 35964 MAC address 5c:cf:7f:2c:24:6b IP address 192.168.1.16 Signal strength -50dBm, channel 8, mode 802.11n, reconnections 0 Clock register 00002002 Socket states: 0 0 0 0 0 0 0 0
@Adrian52 thanks for confirming that.
undefined dc42 marked this topic as a question
undefined dc42 has marked this topic as solved
