WiFi issues with 3.5.4
@droftarts said in WiFi issues with 3.5.4:
@fcwilt Try it with the 3.6.0-beta.4. Or revert everything to 3.4.6.
I know how to upgrade.
How do I revert if that is what I have to do?
@fcwilt same way
@jay_s_uk said in WiFi issues with 3.5.4:
@fcwilt same way
So I upload the old version files and it will ask if I want to install?
@fcwilt Reverting is easier, because you just upload the 3.4.6 release zip file. But 3.6 isn't too far away from being released, and it would be good to get your feedback if anything is broken for you before we release!
And people that have had WiFi issues have found the latest 3.6 beta (along with the other suggestions) fixes them.
Glad to help.
In the past I have avoided the betas and rcs as I did not realize it was possible to go back to an older version.
Knowing that I will give the beta a go.
I went to the site to download the beta files but I don't see the ZIP file of all of the Duet 3 files I am used to using.
So I guess I need some of the files list.
Which ones?
@fcwilt assuming you’re running standalone, the ones whose name matches your board(s), so probably Duet3Firmware_Mini5plus.uf2, and DuetWebControl-SD.zip. Upload them as-is.
@fcwilt no, as that’s the version that’s distributed with 3.6.0-beta.4
Well I updated to 3.6.0 BETA 4 and the WiFi connection failed even sooner than it did under 3.5.4.
The features of 3.6 sound interesting but not at the expense of no WiFi connection.
I was able to revert to 3.4.6 so that is good for now.
