Question about Sammy-C21 board
@fcwilt FYI, depending on your needs, the compiled 'standard' Sammy firmware is located in the RRF releases page - you might not need to compile your own version!
@omtek said in Question about Sammy-C21 board:
Duet3Expansion 3.5-dev
CANlib 3.5-dev
RRFLibraries 3.5-dev
CoreN2G 3.5-dev
FreeRTOS 3.5-dev
Qfplib-M0-full 3.5-devIf you are starting a new project i would base it off the 3.6-dev
Thanks for the info.
I am running firmware 3.4.6 on my two Mini 5+ boards.
Will the 3.6 you mentioned work with the boards despite them being at 3.4.6?
@fcwilt all the firmware builds need to be the same version. If you don't want to update to 3.6beta yet then you will need to build the version that's the same as you want to run on the mainboard.
@fcwilt
To me it sounds like you have to buy a cow to get a liter of milk. -
@DIY-O-Sphere said in Question about Sammy-C21 board:
@fcwilt
To me it sounds like you have to buy a cow to get a liter of milk.??? I have no idea what that means ???
@fcwilt
It means that the effort is quite high.
It's a poor performance that the latest firmware is no longer provided.
Until now I thought the Sammy-C21 is a cool option, but not any more.... -
@fcwilt
Until now I thought the Sammy-C21 is a cool option, but not any more....You must be mistaken, the latest compiled firmware for the Sammy-C21 is 100% up to date with 3.6.0 Beta 3 here: https://github.com/Duet3D/RepRapFirmware/releases , and you can see the 3.6-dev branch here: https://github.com/Duet3D/Duet3Expansion/tree/3.6-dev
I've recently worked on a Sammy-C21 project and the firmware is up to date and available.
@DIY-O-Sphere the dev work would be if the example firmware for the sammyc21 did not provide the required IO for example, not to bring it up to the latest version
@sebkritikel
Thanks for the clarification. And for the correct reference.
If you go to the sammy-c21 documentation. The dev branch is linked and as far as I can see it ends with 3.4.2.
Maybe i'm too stupid to use github. -
@DIY-O-Sphere please can you post the page you mean I will update the docs
@T3P3Tony
https://docs.duet3d.com/en/Duet3D_hardware/Duet_3_family/Using_the_Sammy-C21_development_board_with_Duet_3#duet3d-firmware-source-code-for-sammyc21
Sorry I have overseen that the section is for the source code.But still can't get it to see the right release.
Shouldn't it show 3.5.4 and switch when you select a different version in the branch pulldown?
Or is it just because the zip file for the version is missing?I would suggest putting the section Loading firmware at the end. And i think it needs a bit of a rework
I am still confused as to why the firmware has to be adapted. The table shows many ports that can be used as input.
The original request was here
As far as i can see, standard io's can do the job.
What am I missing here? -
What am I missing here?Can at least answer this! As an example, some folks have modified the source to allow the Sammy-C21 to drive 2x external drivers. The 'example' source (or standard release) is set up to only drive a single external driver. For the 2x external driver version, this has been used by some as part of the ERCF multi-filament system, as seen here: https://forum.duet3d.com/topic/27573/canned-ercf-board-v1-0-beta2/24
@DIY-O-Sphere the releases are now released as part of the main RepRapFirmware repository. E.g.:
https://github.com/Duet3D/RepRapFirmware/releases/download/3.6.0-beta.3/Duet3Firmware_SAMMYC21.bin
You can select the source branch in GitHub for the expansion project, here is 3.5-dev:
You are correct that the default firmware has lots of IO enabled so if that's enough for @fcwilt then they won't need to modify it. If however they need more, they can.
@T3P3Tony said in Question about Sammy-C21 board:
T3P3Tony
administrators
8 Feb 2025, 20:51@DIY-O-Sphere the releases are now released as part of the main RepRapFirmware repository. E.g.:
With the hint of @sebkritikel I got that.....would be nice to add that to the documentation....
Hallelujah....
As part of my quest to figure out how to use the Eclipse IDE to create custom Sammy code I keep encountering things that lead to questions.
In the github sections for Duet3BootLoader and Duet3Expansion there are a couple of lines for which I need guidance.
This is the first line: Modify your PATH environment variable to include the 'bin' folder of the GNU ARM Eclipse istallation.
I added this :
C:\Program Files\GNU ARM Eclipse\Build Tools\2.6-201507152002\bin
Is that correct?
This was already present:
C:\Program Files (x86)\GNU Arm Embedded Toolchain\10 2021.10\bin
Is it also correct?
This is the second line: Run "which rm" and "which make" to make sure that rm and make will be fetched from that folder.
On my computer running Windows 11 "which" is not recognized.
What is it supposed to do? Where is it supposed to be found?
undefined T3P3Tony moved this topic from Duet Hardware and wiring
@fcwilt moved to firmware dev category. This is outside of my knowledge!
@fcwilt Before you go too far down the rathole of building firmware and bootloaders, are you sure you actually need to build either of them? From other comments in this thread (and your previous one), it would seem that the standard build for the Sammy-C21 board may do all that you need. If you only want a set of firmware that allows the Sammy to do whatever it is you need, then please provide details of the functions you require and hopefully we can help work out if you need to modify/build the firmware or not.
Of course if you want to build the firmware/bootloader "just because" then ignore this message and carry on (good luck!).
I think the standard firmware will work fine.
I would just like to understand how to do it. I did embedded process controller programs years ago, but back then the development environment consisted of an text editor and a compiler. The Eclipse IDE seems to have many more moving parts.
