IR Height Sensor
@br7408 ISTR that there is a chance for false triggers at high distances due to stray reflections. I dont remember what the workaround/mitigation was.
@oliof It has this issue with any surface.
@br7408 it may be a faulty probe, a similar case of this was handled under warranty (ref https://forum.duet3d.com/topic/30051/ir-probe-faulty-triggers-well-before-the-actual-trigger-point/22). One for @Phaedrux I guess.
HMMM. Strangely it seemed to fix itself somehow. I wonder if the EBB 42 woke up stupid or something.
@br7408 it didnt endeavor the threat of replacemebt I guess.
I take that back.
I went to calibrate the probe and I am getting errors, because it is not triggering properly. How do I initiate obtaining a replacement?
Here you can see it is initially triggering way low, and then nothing, and then triggering again high. Getting 2 red blinks on startup, as it should.
Specifically: "No trigger on probe after full movement" error in Klipper. Both other IR sensors in the other two identical machines work just fine.
@br7408 said in IR Height Sensor:
It certainly looks to be a bit flaky. I think it should be replaced.
Is a Duet3D IR probe? Is it less than two years old? Where did you buy it from?
Here's the terms of the warranty: https://www.duet3d.com/page/warranty-policyIan
@droftarts Yes, it is Duet. Bought it through filastruder April 22nd 2023.
@br7408 Please send an email to warranty@duet3d.com and CC your reseller. Include a link to this forum thread and the details of your original purchase. You'll receive a reply with a form to fill out.
@droftarts Thank you.
