New beta firmware 1.20.1RC2 and DuetWiFiServer 1.20+1
Hi David, as I said, I'm not familiar with the RRF code so these may be dumb questions but in this code snippet, why are you multiplying totalDistance by dv and not fabsf(dv) and why do that multiply at all? Isn't dv a distance also?
const float averageExtrusionSpeed = (dda.totalDistance * dv * DDA::stepClockRate)/dda.clocksNeeded;
Variable dv is the proportion of totalDistance that applies to the current drive, that's why totalDistance is multiplied by it. It shouldn't matter whether we multiply by dv or fabsf(dv) because nonlinear extrusion is only applied to extruding moves, for which dv is positive.
Understood - thanks.
May I ask what development IDE you are using, Arduino or Atmel Studio (or other)? -
May I ask what development IDE you are using, Arduino or Atmel Studio (or other)?We use Eclipse, see the BuildInstructions.md file in github.
Arduino is great for getting novices into programming microcontrollers, but truly awful for large scale firmware development. Atmel Studio is OK and I use it for the IR sensor and filament sensor firmware, but it offends those who think that only open source tools should be used or who want to develop under Linux.
I use VisualMicro - Its an add-on to Visual Studio that enables to program and upload code for Arduino.
I found it a very good environment for programming. -
I'm familiar with it. I just can't come to terms with Atmel Studio. Professionally I use a derivative of Eclipse; Atollic True Studio which is hard to beat feature-wise.
Hi David, I think I have discovered why I am seeing underextrusion when I use M592 on my Kossel XL fitted with a flex3drive extruder. With A and B set to 0, the x/y motion and the extruder activity start/stop at the same time (as close as I can tell by eye/ear). When I set non-zero values (e.g A=0.015 and B=0.0012) I notice that the extruder stops before the x/y movement stops. The faster the feedrate, the more obvious the gap becomes.
Here's the relevant config lines:
[[language]] M350 I1 X16 Y16 Z16 E16 ; all axes use x16 microstepping with interpolation (steps/mm will get adjusted automatically) M92 X160 Y160 Z160 ; Set axis steps/mm (20 tooth pulleys, 0.9deg/step motors) M906 X1000 Y1000 Z1000 E1000 I60 ; Set motor currents (mA) M201 X3000 Y3000 Z3000 E400 ; Accelerations (mm/s^2) M203 X18000 Y18000 Z18000 E1200 ; Maximum speeds (mm/min) M566 X300 Y300 Z300 E10 ; Maximum instant speed changes M92 E4320 ; Set extruder steps per mm (flex3drive)
There was a report earlier about DWC "layer X of Y" showing the wrong numbers for dual extrusion prints. I have a similar issue with the start (only) of a single layer print. At the end of this message, I'll include a link to the gcode file being referenced, but let me describe what is going on:
When the print starts (waiting for tools to heat), the DWC shows layer 0 of 111.
When the print moves to the part of the gcode that displays a message "Purging and Wiping T1", the DWC shows layer 2 of 111. This part of my startup code does two Z movements before moving on to the real print.
When the print moves on the build plate and actually starts printing the first layer (identified in the gcode with the comment "; layer 1, Z = 0.162"), DWC still shows "layer 2 of 111" and the head position Z is correctly noted as 0.16
When the print moves to the next layer (identified in the gcode with the comment "; layer 2, Z = 0.342"), DWC still shows "layer 2 of 111", and the head position Z is correctly noted as 0.34
Finally, when the print moves to the next layer (identified in the gcode with the comment "; layer 3, Z = 0.522"), DWC finally catches up showing "layer 3 of 111."
My WAG is that my startup gcode that does the "purge and wipe" is confusing the duet because of multiple Z moves up and down. However, if that's the case, I don't understand how it "catches up" at layer 3. If my guess is correct, is there something I can include in my gcode to let the duet know that "here is where the actual print starts, so reset the layer to 1"?
gcode file: https://drive.google.com/file/d/1MWXt1cxYU0ZMMG2RMMgH25-8_ynrjyHl/view?usp=sharing
Thanks
Gary -
Thanks, I look into it.
I found the problem. I'll get a new 1.20.1RC out soon with a fix.
A new 1.20.1RC would be most welcome!
Any chance of a new RC? I am keen to try out the fixed M592.
I am working through bug reports at the moment, trying to get some fixes implemented before I release it. However, there is a pre-release Duet Wifi build at https://www.dropbox.com/s/8pvnkzaf0hqxf7x/DuetWiFiFirmware.bin?dl=0.
Thanks, I'm trying it now…
Appears to work as expected, testing PETG at 240C, 0.4mm v6, flex3drive extruder. Preliminary results indicate A=0.05, B=0.004 work well up to 3.5mm/S. From 4mm/S upwards, compensation not really effective which doesn't surprise me as I've never been able to reliably get much more than approx 6 mm^3/S out of the v6. Will continue to test but it's looking good so far.
Thanks for the feedback. I have not tested whether increasing the spring tension on my Titan affects the amount of nonlinearity.
The flex3drive extruder doesn't appear to have any means of adjusting the "grip" - hasn't been a problem so far except for some TPU like stuff I have which is only 1.55 dia and so I have to add some packing to the over-centre lever otherwise the filament slips. The extruder works OK but it's a shame that it doesn't have any means of adjusting for filament diameters that aren't close to 1.75.
Done some prints with M592 active and they look very good. I believe the quality in terms of extrusion amounts has been improved. Here's a couple of images…
Discovered an interesting side effect of the non-linear extrusion - now that it doesn't underextrude (so much) at the higher extrusion rates, I found that a print using TPU like filament failed because the extrusion rate on a skin layer increased sufficiently to reach the throughput limit of the extruder/hotend combo. So a gcode file that had printed OK before, now doesn't print well. The solution was to reslice the part with a reduction in the speed at which the skin was being printed so that the throughput limit was no longer being reached.
