How to get 12 volt from the duet2x
I am trying to wire up a 12V RGB on the 2x expansion board, witch is powerd by 24V
I thought you could use the 12V pin from the voltage selector, however that also puts out 24volt. is this normal or am I missing some other setting/jumper ?
If you enable the switching regulator on the DueX2 by fitting the 12V_EN jumper and you put the fan voltage selection jumper in the 12V position, then the power to the fan outputs on the DueX2 should be 12V.
