No movement with any command
@droftarts yes the driver is getting power, and i posted the config.g
@zecreton said in No movement with any command:
Please post the whole config as text/code, not as a picture. You can copy it from DWC and paste it in your reply.
And is the 5V to PUL+ connected? And have you tried disconnecting the ENA wires?
@droftarts idk why but i can't access dwc anymore even tho i haven't touched anything, i get this error: Error: M552: On-board firmware cannot process network-related commands when using an attached Single Board Computer␊
@zecreton yes the PUL+ was connected
Do you have a raspberry pi connected now?
@Phaedrux no
@zecreton You get this message when there's no SD card in the Duet, and it assumes that it is connected to a Raspberry Pi in SBC mode. I guess you're connected over USB? Send M122 to check if the SD card is recognised.
Check SD card and reading it: https://docs.duet3d.com/en/User_manual/RepRapFirmware/SD_card#troubleshooting-sd-card-issues
@droftarts the sd card was not correctly in the slot idk why, but now im getting an ip adress of 0.0.0.0 and even with the ethernet cable disconnected, it says it is enabled
Please copy and paste the text of your config.g into a post here.
@Phaedrux i can't access dwc
Remove the SD card from the Duet and use your computer to read the config.g file.
@Phaedrux oops sorry i forgot that
@Phaedrux ; Configuration file for RepRapFirmware on Duet 3 Main Board 6XD
; generated by RepRapFirmware Configuration Tool v3.5.3 on Tue Jun 25 2024 21:16:10 GMT-0400 (Eastern Daylight Time); General
G90 ; absolute coordinates
M83 ; relative extruder moves
M550 P"Duet 3" ; set hostname; Network
M551 P"Raphaelbreton2008" ; set machine password
M552 P0.0.0.0 S1 ; configure Ethernet adapter
M586 P0 S1 ; configure HTTP; Motor Idle Current Reduction
M906 I30 ; set motor current idle factor
M84 S30 ; set motor current idle timeout; External Drivers
M569 P0.0 S1 R0 T5:5:10:0 ; driver 0.0 goes forwards and requires an active-low enable signal (X axis)
M569 P0.1 S1 R0 T5:5:10:0 ; driver 0.1 goes forwards and requires an active-low enable signal (Y axis)
M569 P0.2 S1 R0 T5:5:10:0 ; driver 0.2 goes forwards and requires an active-low enable signal (Z axis); Axes
M584 X0.0 Y0.1 Z0.2 ; set axis mapping
M350 X16 Y16 Z16 I0 ; configure microstepping without interpolation
M92 X80 Y80 Z400 ; configure steps per mm
M208 X0:1200 Y0:200 Z0:200 ; set minimum and maximum axis limits
M566 X900 Y900 Z12 ; set maximum instantaneous speed changes (mm/min)
M203 X6000 Y6000 Z180 ; set maximum speeds (mm/min)
M201 X500 Y500 Z20 ; set accelerations (mm/s^2); Kinematics
M669 K0 ; configure Cartesian kinematics; Endstops
M574 X1 P"io0.in" S1 ; configure X axis endstop
M574 Y1 P"io1.in" S1 ; configure Y axis endstop
M574 Z1 P"io2.in" S1 ; configure Z axis endstop -
Are you able to connect to the Duet via USB cable and use terminal software like YAT to send commands to it?
described here: https://docs.duet3d.com/en/How_to_guides/Getting_connected/Getting_connected_to_your_Duet#h-2-connect-your-duet-via-usb
@Phaedrux yes
What happens if you follow along with the rest of that "Getting connected" guide?
@Phaedrux i doesn't work bc when i send M552 S1 P0.0.0.0, it answers with just ok, and when i send M552, i can see that it gave 0.0.0.0 as an ip address
How do you have the Duet connected to your network?
Does the network cable you have going to the Duet work if you try to connect it to a computer?
@Phaedrux it is plugged with a ethernet cable in the router
@Phaedrux said in No movement with any command:
