Random overextrusion after 3+hours of printing FW 3.5.2
@charliedrums Is there any chance this could be related to temperature of your extruder or extruder motor? I wonder if after a long time your are getting "heat creep" that impacts the ability for the extruder to perform a retract, perhaps the filament is softened and so the extruder fails to grip it? You mentioned earlier that you needed to reboot for the problem to go away. Couple of tests you could try....
- Wait for the problem to happen, reboot the computer and start the print again (do not allow any time for things to cool down).
- Wait for the problem to happen, do not reboot, but allow the printer to cool down completely, then start the print again.
If in case 1 the problem does not happen for a few hours we can probably ignore heat. If in case 2 it takes a couple of hours for the problem to appear, then maybe heat is involved.
When you fitted the SZP, did you make any other changes? Is there any chance that the way the SZP is fitted that the airflow around the extruder has been reduced/changed?
@droftarts
It was not grounded but it is now. Since it takes a couple of days to get here I went and ordered a 1LC v1.3 board to see if that changes anything.I updated the bootloader on the 1LC and I have grounded the bracket and now the screws and the hemera are grounded. This time I started a print and it started over extruding right from the start. Maybe now with the updated bootloader and grounded everything, updaye everything to 3.5.2 and see what happens? I'll keep trying stuff until the new 1LC gets here. I'll keep the thread updated to my findings.
@gloomyandy
I don't think it is heat related. I do a lot of hueforge, so the way I have the pause script is to turn off the extruder and park the extruder. So at least twice of the tests have been, set the print and go to bed, when I wake up it has been paused for a couple of hours letting the extruder cool down. I proceed to bring it up to temperature remove filament, trim it, and finally purge filament before resuming the print. After this the problem persists. But I'll give ot a try.I bought a new 1lcv1.3 from filastruder so I have a couple of days before it gets here where I can keep investigating to see if I can pinpoint the problem.
Small update. While waiting for the new 1LCv1.3 to get here I decided to remake all the cable harnesses that connect to the 1LC board I got the correct crimper and crimped everything correctly with new JST-PH connectors (trying to get these perfect is not that easy). After this I tried again but same thing After a couple of hours the extruder randomly starts over extruding. So this eliminates any bad crimps or harness connections.
I also took the board off the extruder and inspected everything to see if there was any visible damage. But there was nothing that I could see. Is there any test to see if the board is busted in any way?
@charliedrums
Have you scanned the Gcode at that area?
I once had a similar issue that was doing my head in.
It turned out that in one of the settings in PrusaSlicer, I had a value entered as a percentage when it should have been an 1 based factor.
So instead of be 75% of the extrusion value, it was 75X the value.
I never figured out if I made an error, or there was a change in the software (unlikely), or if it was me caopying configs between prusa slicer and super slicer.
I think it was in overhangs.
In any case, maybe check for sudden increases in the E values for moves in that area. -
I haven't read this entire thread so I might have missed something but another option/thing to check is if the Z axis is moving properly. If the Z axis has some "stiction" or other movement related issue which prevents it from moving the full layer height, then this can seem like over extrusion. i.e. if you extrude enough filament for (say) 0.3mm layer height but the Z axis has only moved (say) 0.1mm, then this can seem like over extrusion.
@OwenD I have printed the gcode before. Probably like 30 t50 times and it has always worked. Still gave it a look but found nothing out of the ordinary.
Ok, so the new 1LC (v1.3) board came in today. I decided to start everything with a new install on a Pi5. using
image_2024-04-19-DuetPi-arm64. Once I built the image and assembled everything I updated all the boards thought putty. Interesting that when I do a toolboard diagnostics it says that the toolboard is version 1.1 not 1.3.
Now whoever I'm having a new problem. After updating everything on FW3.5.2, I go to start the print everything looks good and is heating up as it should but once heating up finishes and it starts to move to the the homing routine a couple of things happen. *Edit Before I start any print or anything I can probe and scan the bed without any problems.
Error: Expansion board 120 reconnected Error: Expansion board 121 reconnected
then the scanning z probe starts scanning the bed and in every pass I get this error.
Error: Board 120 does not have input handle 3040
and in DWC this is how the teperature is reported after this happens
I have no Idea whats going on now. All I did is change the 1LC board.
Here are the diagnostics. of all boards.=== Diagnostics === RepRapFirmware for Duet 3 MB6HC version 3.5.2 (2024-06-11 17:13:58) running on Duet 3 MB6HC v1.01 (SBC mode) Board ID: 08DJM-956BA-NA3TN-6JTD0-3SJ6S-1V82V Used output buffers: 11 of 40 (40 max) === RTOS === Static ram: 155360 Dynamic ram: 91860 of which 3080 recycled Never used RAM 92188, free system stack 136 words Tasks: LASER(5,nWait 7,0.0%,169) SBC(2,rWait:,0.9%,801) HEAT(3,nWait 6,0.0%,323) Move(4,nWait 6,1.8%,211) CanReceiv(6,nWait 1,0.0%,794) CanSender(5,nWait 7,0.0%,334) CanClock(7,delaying,0.0%,348) TMC(4,nWait 6,9.6%,53) MAIN(2,running,87.4%,101) IDLE(0,ready,0.2%,29), total 100.0% Owned mutexes: HTTP(MAIN) === Platform === Last reset 00:23:03 ago, cause: power up Last software reset at 2024-07-01 18:02, reason: MemoryProtectionFault mmarValid daccViol, Platform spinning, available RAM 92476, slot 1 Software reset code 0x4160 HFSR 0x00000000 CFSR 0x00000082 ICSR 0x0440f804 BFAR 0x00000000 SP 0x204198e8 Task IDLE Freestk 20 ok Stack: 20419968 00000000 2041999c 20419960 a5a5a5a5 0049a485 0049a0e0 61000000 61000000 a5a5a5a5 2041999c fffc0000 20425daf 20419958 2041995c 43f8e92d 20419960 00000000 ffffffff 004999a9 43f8e92d 00000000 20419960 00000000 00000001 204199e0 4e49414d Error status: 0x04 Aux0 errors 0,0,0 MCU temperature: min 33.6, current 42.0, max 42.1 Supply voltage: min 23.7, current 24.0, max 24.1, under voltage events: 0, over voltage events: 0, power good: yes 12V rail voltage: min 12.0, current 12.1, max 12.1, under voltage events: 0 Heap OK, handles allocated/used 99/0, heap memory allocated/used/recyclable 2048/72/72, gc cycles 0 Events: 2 queued, 2 completed Driver 0: ok, SG min 0, mspos 628, reads 55863, writes 17 timeouts 0 Driver 1: ok, SG min 0, mspos 913, reads 55863, writes 17 timeouts 0 Driver 2: standstill, SG min 0, mspos 520, reads 55863, writes 17 timeouts 0 Driver 3: standstill, SG min 0, mspos 936, reads 55863, writes 17 timeouts 0 Driver 4: standstill, SG min 0, mspos 952, reads 55863, writes 17 timeouts 0 Driver 5: standstill, SG min 0, mspos 104, reads 55864, writes 17 timeouts 0 Date/time: 2024-07-01 18:25:49 Slowest loop: 77.42ms; fastest: 0.04ms === Storage === Free file entries: 20 SD card 0 not detected, interface speed: 37.5MBytes/sec SD card longest read time 0.0ms, write time 0.0ms, max retries 0 === Move === DMs created 125, segments created 27, maxWait 199391ms, bed compensation in use: mesh, height map offset 0.000, max steps late 0, min interval 0, bad calcs 0, ebfmin 0.00, ebfmax 0.00 next step interrupt due in 1 ticks, disabled Moves shaped first try 1321, on retry 722, too short 604, wrong shape 12745, maybepossible 120 === DDARing 0 === Scheduled moves 17499, completed 17443, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state 3 === DDARing 1 === Scheduled moves 0, completed 0, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1 === Heat === Bed heaters 0 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1, chamber heaters -1 -1 -1 -1, ordering errs 0 Heater 0 is on, I-accum = 0.1 === GCodes === Movement locks held by null, null HTTP* is doing "M122" in state(s) 0 0, running macro Telnet is idle in state(s) 0 File* is doing "G1 X336.225006 Y327.441986 E0.046660" in state(s) 0 USB is idle in state(s) 0 Aux is idle in state(s) 0 Trigger* is idle in state(s) 0 Queue* is idle in state(s) 0 LCD is idle in state(s) 0 SBC is idle in state(s) 0 Daemon is idle in state(s) 0 Aux2 is idle in state(s) 0 Autopause is idle in state(s) 0 File2 is idle in state(s) 0 Queue2 is idle in state(s) 0 Q0 segments left 1, axes/extruders owned 0x80000007 Code queue 0 is empty Q1 segments left 0, axes/extruders owned 0x0000000 Code queue 1 is empty === Filament sensors === check 0 clear 0 Extruder 0 sensor: no data received === CAN === Messages queued 28613, received 21465, lost 0, errs 641, boc 0 Longest wait 6ms for reply type 6024, peak Tx sync delay 250, free buffers 50 (min 48), ts 6920/6919/0 Tx timeouts 0,0,0,0,0,0 === SBC interface === Transfer state: 5, failed transfers: 0, checksum errors: 0 RX/TX seq numbers: 53966/53966 SPI underruns 0, overruns 0 State: 5, disconnects: 0, timeouts: 0 total, 0 by SBC, IAP RAM available 0x24cfc Buffer RX/TX: 3248/48-4096, open files: 0 === Duet Control Server === Duet Control Server version 3.5.2 (2024-06-12 07:12:47, 64-bit) HTTP+Executed: > Executing M122 File 0:/gcodes/Guiro 12in_0.6n_0.3mm_PLA_EXOCUBE_8h39m.gcode is selected, processing HTTP: >> Doing macro 0:/macros/Diagnostics, started by M98 P"0:/macros/Diagnostics" File: Buffered code: G1 X336.225 Y327.442 E.04666 Buffered code: G1 X336.573 Y327.959 E.05293 Buffered code: G1 X336.881 Y328.464 E.05023 Buffered code: G1 X337.357 Y329.369 E.08267 Buffered code: G1 X337.635 Y329.988 E.05459 Buffered code: G1 X337.85 Y330.524 E.04646 Buffered code: G1 X338.183 Y331.522 E.08229 Buffered code: G1 X338.49 Y332.75 E.09722 Buffered code: G1 X338.669 Y333.816 E.08108 Buffered code: G1 X338.748 Y334.521 E.05168 Buffered code: G1 X338.797 Y335.606 E.07913 Buffered code: G1 X338.763 Y336.843 E.08942 Buffered code: G1 X338.686 Y337.585 E.05172 Buffered code: G1 X338.569 Y338.329 E.0515 Buffered code: G1 X338.414 Y339.049 E.04953 Buffered code: G1 X338.163 Y339.93 E.06047 Buffered code: G1 X337.864 Y340.77 E.05791 Buffered code: G1 X337.827 Y340.861 E.00612 Buffered codes: 864 bytes total Code buffer space: 3200 Configured SPI speed: 8000000Hz, TfrRdy pin glitches: 0 Full transfers per second: 38.34, max time between full transfers: 64.4ms, max pin wait times: 34.9ms/3.8ms Codes per second: 12.04 Maximum length of RX/TX data transfers: 8176/1140
1LC
Diagnostics for board 121: Duet TOOL1LC rev 1.1 or later firmware version 3.5.2 (2024-06-10 13:24:04) Bootloader ID: SAMC21 bootloader version 2.8 (2023-07-25) All averaging filters OK Never used RAM 3832, free system stack 71 words Tasks: Move(3,nWait 7,0.2%,90) HEAT(2,nWait 6,0.1%,126) CanAsync(5,nWait 4,0.0%,52) CanRecv(3,nWait 1,0.1%,70) CanClock(5,nWait 1,0.0%,58) ACCEL(3,nWait 6,0.0%,52) TMC(2,nWait 6,3.7%,52) MAIN(1,running,91.3%,412) IDLE(0,ready,0.0%,26) AIN(2,delaying,4.5%,112), total 100.0% Owned mutexes: Last reset 00:18:59 ago, cause: power up Last software reset data not available Driver 0: pos 0, 80.0 steps/mm, ok, SG min 0, read errors 0, write errors 0, ifcnt 55, reads 21490, writes 0, timeouts 0, DMA errors 0, CC errors 0, steps req 0 done 660061 Moves scheduled 15214, completed 15210, in progress 1, hiccups 0, segs 26, step errors 0, maxLate 0 maxPrep 210, maxOverdue 0, maxInc 0, mcErrs 0, gcmErrs 0, ebfmin 0.00 max 1.00 Peak sync jitter 1/6, peak Rx sync delay 245, resyncs 0/0, no timer interrupt scheduled VIN voltage: min 11.9, current 24.6, max 24.6 MCU temperature: min 36.0C, current 38.5C, max 38.8C Last sensors broadcast 0x00000000 found 0 137 ticks ago, 0 ordering errs, loop time 0 CAN messages queued 6671, send timeouts 0, received 20102, lost 0, errs 0, boc 0, free buffers 18, min 17, error reg 0 dup 0, oos 0/0/0/0, bm 0, wbm 0, rxMotionDelay 369, adv 36213/74673 Accelerometer: LIS3DH, status: 00 I2C bus errors 0, naks 0, contentions 0, other errors 0
Zprobe
M122 B120 Diagnostics for board 120: Duet SZP firmware version 3.5.2 (2024-06-10 13:23:26) Bootloader ID: SAMC21 bootloader version 2.10 (2023-11-16) All averaging filters OK Never used RAM 14188, free system stack 110 words Tasks: HEAT(2,nWait 6,0.1%,132) CanAsync(5,nWait 4,0.0%,54) CanRecv(3,nWait 1,0.0%,70) CanClock(5,nWait 1,0.0%,58) ACCEL(3,nWait 6,0.0%,52) MAIN(1,running,64.7%,430) IDLE(0,ready,0.0%,26) AIN(2,nWait 4,35.1%,72), total 100.0% Owned mutexes: I2C(AIN) Last reset 00:19:13 ago, cause: power up Last software reset at 2024-03-12 06:08, reason: StackOverflow, available RAM 14136, slot 0 Software reset code 0x0100 ICSR 0x0041a00e SP 0x20007f34 Task ACCE Freestk 5138 ok Stack: 20002e70 20002ea4 00014913 200029a4 20002ac0 20002998 000139f1 20002ac0 fffffffd 0000002a 00000000 20007f8c 00000000 20007f8c 00014677 00000000 200010a4 20001028 00013eb7 20001028 200010a4 00000032 454c4449 00019000 00012683 200011c0 200011c0 Peak sync jitter 1/6, peak Rx sync delay 216, resyncs 0/0, no timer interrupt scheduled VIN voltage: min 4.4, current 5.0, max 5.0 MCU temperature: min 27.5C, current 30.1C, max 30.2C Last sensors broadcast 0x00000000 found 0 165 ticks ago, 0 ordering errs, loop time 0 CAN messages queued 5518, send timeouts 0, received 11275, lost 0, errs 0, boc 0, free buffers 18, min 18, error reg 0 Accelerometer: LIS2DW, status: 00 Inductive sensor: raw value 39288477, frequency 3.66MHz, current setting 13, ok I2C bus errors 0, naks 3, contentions 0, other errors 0
any help would be greatly appreciated.
Ok so I narrowed down the tool Expansion board 121 reconnected error to the harness connection between the scanning z probe and the tool board harness. I mystically did not plug it in all the way. Having plugged it in correctly I started a new test print with the new 1LC board but still I’m having the same over extrusion problem at random times. Sometimes is at the start of the print, sometimes is at layer 5, sometimes its 3+ hours into the print.
So I decided to go back to the basics I disconnected the scanning z probe and the filament sensor and updated the config.g file to comment out the scanning z probe and the filament sensor. So the only things that are plugged in to the 1LC are the extruder & cooling fan, the extruder heater, thermistor, motor, vin power and the can connection. With this configuration I started a test print to see if I keep getting the over extrusion issue. Hopefully I have a successful print on this one I really don’t want to ditch duet for Klipper and a Chinese board.
Here are my diagnostics:
MB6HC=== Diagnostics === RepRapFirmware for Duet 3 MB6HC version 3.5.2 (2024-06-11 17:13:58) running on Duet 3 MB6HC v1.01 (SBC mode) Board ID: 08DJM-956BA-NA3TN-6JTD0-3SJ6S-1V82V Used output buffers: 11 of 40 (29 max) === RTOS === Static ram: 155360 Dynamic ram: 89888 of which 5072 recycled Never used RAM 92192, free system stack 136 words Tasks: SBC(2,rWait:,0.9%,821) HEAT(3,nWait 6,0.0%,323) Move(4,nWait 6,1.9%,211) CanReceiv(6,nWait 1,0.0%,794) CanSender(5,nWait 7,0.0%,327) CanClock(7,delaying,0.0%,348) TMC(4,nWait 6,9.7%,53) MAIN(2,running,87.1%,101) IDLE(0,ready,0.3%,29), total 100.0% Owned mutexes: HTTP(MAIN) === Platform === Last reset 00:19:02 ago, cause: software Last software reset at 2024-07-01 22:29, reason: User, Gcodes spinning, available RAM 95744, slot 0 Software reset code 0x6003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0043c000 BFAR 0x00000000 SP 0x00000000 Task SBC Freestk 0 n/a Error status: 0x00 Aux0 errors 0,0,0 MCU temperature: min 37.2, current 42.1, max 42.2 Supply voltage: min 23.8, current 24.0, max 24.1, under voltage events: 0, over voltage events: 0, power good: yes 12V rail voltage: min 12.0, current 12.1, max 12.1, under voltage events: 0 Heap OK, handles allocated/used 99/0, heap memory allocated/used/recyclable 2048/48/48, gc cycles 0 Events: 1 queued, 1 completed Driver 0: ok, SG min 0, mspos 366, reads 41818, writes 17 timeouts 0 Driver 1: ok, SG min 0, mspos 1010, reads 41818, writes 17 timeouts 0 Driver 2: ok, SG min 0, mspos 277, reads 41818, writes 17 timeouts 0 Driver 3: ok, SG min 0, mspos 59, reads 41818, writes 17 timeouts 0 Driver 4: ok, SG min 0, mspos 859, reads 41818, writes 17 timeouts 0 Driver 5: ok, SG min 0, mspos 229, reads 41818, writes 17 timeouts 0 Date/time: 2024-07-01 22:48:14 Slowest loop: 1369.34ms; fastest: 0.05ms === Storage === Free file entries: 20 SD card 0 not detected, interface speed: 37.5MBytes/sec SD card longest read time 0.0ms, write time 0.0ms, max retries 0 === Move === DMs created 125, segments created 26, maxWait 99861ms, bed compensation in use: mesh, height map offset 0.000, max steps late 0, min interval 0, bad calcs 0, ebfmin 0.00, ebfmax 0.00 next step interrupt due in 383 ticks, disabled Moves shaped first try 1182, on retry 654, too short 544, wrong shape 10891, maybepossible 117 === DDARing 0 === Scheduled moves 15092, completed 15032, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state 3 === DDARing 1 === Scheduled moves 0, completed 0, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1 === Heat === Bed heaters 0 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1, chamber heaters -1 -1 -1 -1, ordering errs 0 Heater 0 is on, I-accum = 0.2 Heater 1 is on, I-accum = 0.0 === GCodes === Movement locks held by null, null HTTP* is doing "M122" in state(s) 0 0, running macro Telnet is idle in state(s) 0 File* is doing "G1 X329.549988 Y341.337006 E0.083270" in state(s) 0 USB is idle in state(s) 0 Aux is idle in state(s) 0 Trigger* is idle in state(s) 0 Queue* is idle in state(s) 0 LCD is idle in state(s) 0 SBC is idle in state(s) 0 Daemon is idle in state(s) 0 Aux2 is idle in state(s) 0 Autopause is idle in state(s) 0 File2 is idle in state(s) 0 Queue2 is idle in state(s) 0 Q0 segments left 1, axes/extruders owned 0x80000007 Code queue 0 is empty Q1 segments left 0, axes/extruders owned 0x0000000 Code queue 1 is empty === CAN === Messages queued 24111, received 22784, lost 0, errs 1, boc 0 Longest wait 2ms for reply type 6026, peak Tx sync delay 323, free buffers 50 (min 49), ts 5711/5710/0 Tx timeouts 0,0,0,0,0,0 === SBC interface === Transfer state: 5, failed transfers: 0, checksum errors: 0 RX/TX seq numbers: 45007/45007 SPI underruns 0, overruns 0 State: 5, disconnects: 0, timeouts: 0 total, 0 by SBC, IAP RAM available 0x24cfc Buffer RX/TX: 3264/752-4080, open files: 0 === Duet Control Server === Duet Control Server version 3.5.2 (2024-06-12 07:12:47, 64-bit) HTTP+Executed: > Executing M122 File 0:/gcodes/Guiro 12in_3.4.6Test_0.6n_0.3mm_PLA_EXOCUBE_8h39m.gcode is selected, processing HTTP: >> Doing macro 0:/macros/Diagnostics, started by M98 P"0:/macros/Diagnostics" File: Buffered code: G1 X329.55 Y341.337 E.08327 Buffered code: G1 X328.919 Y341.965 E.06177 Buffered code: G1 X328.509 Y342.594 E.0521 Buffered code: G1 X328.222 Y343.222 E.04791 Buffered code: G1 X328.016 Y343.85 E.04586 Buffered code: G1 X327.906 Y344.479 E.04431 Buffered code: G1 X327.95 Y344.793 E.022 Buffered code: G1 X328.205 Y345.107 E.02807 Buffered code: G1 X329.428 Y345.735 E.0954 Buffered code: G1 X330.45 Y346.364 E.08327 Buffered code: G1 X330.63 Y346.543 E.01761 Buffered code: G1 X331.455 Y346.422 E.05786 Buffered code: G1 X331.908 Y346.306 E.03245 Buffered code: G1 X332.359 Y346.157 E.03296 Buffered code: G1 X333.06 Y345.853 E.05302 Buffered code: G1 X333.762 Y345.466 E.05562 Buffered code: G1 X334.184 Y345.184 E.03522 Buffered code: G1 X334.598 Y344.867 E.03618 Buffered code: G1 X335.255 Y344.267 E.06174 Buffered code: G1 X334.577 Y343.85 E.05523 Buffered code: G1 X333.945 Y343.222 E.06182 Buffered code: G1 X333.536 Y342.594 E.052 Buffered code: G1 X333.249 Y341.965 E.04797 Buffered code: G1 X333.042 Y341.337 E.04588 Buffered code: G1 X332.933 Y340.708 E.0443 Buffered code: G1 X332.976 Y340.394 E.02199 Buffered code: G1 X333.232 Y340.08 E.02811 Buffered code: G1 X334.455 Y339.452 E.0954 Buffered code: G1 X335.476 Y338.823 E.08321 Buffered code: G1 X336.108 Y338.195 E.06182 Buffered code: G1 X336.518 Y337.567 E.05204 Buffered code: G1 X336.805 Y336.938 E.04797 Buffered codes: 1536 bytes total Code buffer space: 2512 Configured SPI speed: 8000000Hz, TfrRdy pin glitches: 0 Full transfers per second: 39.60, max time between full transfers: 50.4ms, max pin wait times: 35.8ms/5.4ms Codes per second: 13.53 Maximum length of RX/TX data transfers: 4436/1124
1LC
Diagnostics for board 121: Duet TOOL1LC rev 1.1 or later firmware version 3.5.2 (2024-06-10 13:24:04) Bootloader ID: SAMC21 bootloader version 2.8 (2023-07-25) All averaging filters OK Never used RAM 3372, free system stack 71 words Tasks: Move(3,nWait 7,0.2%,90) HEAT(2,nWait 6,0.3%,98) CanAsync(5,nWait 4,0.0%,52) CanRecv(3,nWait 1,0.1%,70) CanClock(5,nWait 1,0.0%,58) ACCEL(3,nWait 6,0.0%,52) TMC(2,nWait 6,3.7%,52) MAIN(1,running,90.8%,314) IDLE(0,ready,0.0%,26) AIN(2,delaying,4.8%,112), total 100.0% Owned mutexes: Last reset 00:19:06 ago, cause: software Last software reset data not available Driver 0: pos 0, 405.0 steps/mm, standstill, SG min 0, read errors 0, write errors 1, ifcnt 26, reads 48051, writes 13, timeouts 0, DMA errors 0, CC errors 0, steps req 0 done 850185 Moves scheduled 13946, completed 13943, in progress 1, hiccups 27, segs 26, step errors 0, maxLate 0 maxPrep 335, maxOverdue 102, maxInc 37, mcErrs 0, gcmErrs 0, ebfmin 0.00 max 1.00 Peak sync jitter 0/5, peak Rx sync delay 228, resyncs 0/0, no timer interrupt scheduled VIN voltage: min 19.7, current 23.7, max 24.6 MCU temperature: min 34.6C, current 45.0C, max 46.0C Last sensors broadcast 0x00000002 found 1 205 ticks ago, 0 ordering errs, loop time 0 CAN messages queued 22882, send timeouts 0, received 24273, lost 0, errs 0, boc 0, free buffers 18, min 18, error reg 0 dup 0, oos 0/0/0/0, bm 0, wbm 0, rxMotionDelay 403, adv 36312/74663 Accelerometer: LIS3DH, status: 00 I2C bus errors 0, naks 3, contentions 0, other errors 0
Ok this time it was 1h 1m 28s when the over extrusion started. Any Ideas of what I could try next? Would making a new RJ11 cable from the tool distribution board help? Or re cabling the whole thing? At this point I’ll try anything.
Diagnostics:
MB6HC=== Diagnostics === RepRapFirmware for Duet 3 MB6HC version 3.5.2 (2024-06-11 17:13:58) running on Duet 3 MB6HC v1.01 (SBC mode) Board ID: 08DJM-956BA-NA3TN-6JTD0-3SJ6S-1V82V Used output buffers: 1 of 40 (29 max) === RTOS === Static ram: 155360 Dynamic ram: 89912 of which 5048 recycled Never used RAM 92192, free system stack 136 words Tasks: SBC(2,nWait 7,0.9%,821) HEAT(3,nWait 6,0.0%,323) Move(4,nWait 6,2.5%,211) CanReceiv(6,nWait 1,0.0%,794) CanSender(5,nWait 7,0.0%,327) CanClock(7,delaying,0.0%,346) TMC(4,nWait 6,9.7%,53) MAIN(2,running,86.7%,101) IDLE(0,ready,0.0%,29), total 100.0% Owned mutexes: HTTP(MAIN) === Platform === Last reset 01:00:13 ago, cause: software Last software reset at 2024-07-01 22:29, reason: User, Gcodes spinning, available RAM 95744, slot 0 Software reset code 0x6003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0043c000 BFAR 0x00000000 SP 0x00000000 Task SBC Freestk 0 n/a Error status: 0x00 Aux0 errors 0,0,0 MCU temperature: min 41.9, current 44.6, max 44.7 Supply voltage: min 23.7, current 23.9, max 24.0, under voltage events: 0, over voltage events: 0, power good: yes 12V rail voltage: min 12.0, current 12.1, max 12.1, under voltage events: 0 Heap OK, handles allocated/used 99/0, heap memory allocated/used/recyclable 2048/48/48, gc cycles 0 Events: 1 queued, 1 completed Driver 0: ok, SG min 0, mspos 444, reads 10183, writes 0 timeouts 0 Driver 1: ok, SG min 0, mspos 867, reads 10184, writes 0 timeouts 0 Driver 2: ok, SG min 0, mspos 508, reads 10184, writes 0 timeouts 0 Driver 3: ok, SG min 0, mspos 852, reads 10184, writes 0 timeouts 0 Driver 4: ok, SG min 0, mspos 628, reads 10184, writes 0 timeouts 0 Driver 5: ok, SG min 0, mspos 460, reads 10184, writes 0 timeouts 0 Date/time: 2024-07-01 23:29:26 Slowest loop: 31.88ms; fastest: 0.05ms === Storage === Free file entries: 20 SD card 0 not detected, interface speed: 37.5MBytes/sec SD card longest read time 0.0ms, write time 0.0ms, max retries 0 === Move === DMs created 125, segments created 26, maxWait 991ms, bed compensation in use: mesh, height map offset 0.000, max steps late 0, min interval 0, bad calcs 0, ebfmin 0.00, ebfmax 0.00 next step interrupt due in 166 ticks, disabled Moves shaped first try 2755, on retry 1709, too short 1471, wrong shape 35430, maybepossible 500 === DDARing 0 === Scheduled moves 61679, completed 61619, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state 3 === DDARing 1 === Scheduled moves 0, completed 0, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1 === Heat === Bed heaters 0 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1, chamber heaters -1 -1 -1 -1, ordering errs 0 Heater 0 is on, I-accum = 0.1 Heater 1 is on, I-accum = 0.0 === GCodes === Movement locks held by null, null HTTP* is doing "M122" in state(s) 0 0, running macro Telnet is idle in state(s) 0 File* is doing "G1 X337.981995 Y325.506012 E0.063910" in state(s) 0 USB is idle in state(s) 0 Aux is idle in state(s) 0 Trigger* is idle in state(s) 0 Queue* is idle in state(s) 0 LCD is idle in state(s) 0 SBC is idle in state(s) 0 Daemon is idle in state(s) 0 Aux2 is idle in state(s) 0 Autopause is idle in state(s) 0 File2 is idle in state(s) 0 Queue2 is idle in state(s) 0 Q0 segments left 1, axes/extruders owned 0x80000007 Code queue 0 is empty Q1 segments left 0, axes/extruders owned 0x0000000 Code queue 1 is empty === CAN === Messages queued 65895, received 49465, lost 0, errs 0, boc 0 Longest wait 6ms for reply type 6024, peak Tx sync delay 254, free buffers 50 (min 48), ts 12359/12359/0 Tx timeouts 0,0,0,0,0,0 === SBC interface === Transfer state: 5, failed transfers: 0, checksum errors: 0 RX/TX seq numbers: 11409/11409 SPI underruns 0, overruns 0 State: 5, disconnects: 0, timeouts: 0 total, 0 by SBC, IAP RAM available 0x24cfc Buffer RX/TX: 1920/3424-0, open files: 0 === Duet Control Server === Duet Control Server version 3.5.2 (2024-06-12 07:12:47, 64-bit) HTTP+Executed: > Executing M122 File 0:/gcodes/Guiro 12in_3.4.6Test_0.6n_0.3mm_PLA_EXOCUBE_8h39m.gcode is selected, processing HTTP: >> Doing macro 0:/macros/Diagnostics, started by M98 P"0:/macros/Diagnostics" File: Buffered code: G1 X337.982 Y325.506 E.06391 Buffered code: G1 X338.172 Y326.122 E.04473 Buffered code: G1 X338.373 Y326.988 E.06169 Buffered code: G1 X338.475 Y327.605 E.04339 Buffered code: G1 X338.532 Y328.208 E.04203 Buffered code: G1 X338.576 Y329.165 E.06648 Buffered code: G1 X338.54 Y329.812 E.04496 Buffered code: G1 X338.477 Y330.421 E.04248 Buffered code: G1 X338.404 Y330.875 E.03191 Buffered code: G1 X338.17 Y331.76 E.06352 Buffered code: G1 X337.971 Y332.224 E.03503 Buffered code: G1 X337.819 Y332.486 E.02102 Buffered code: G1 X337.248 Y333.118 E.0591 Buffered code: G1 X336.888 Y333.48 E.03543 Buffered code: G1 X336.109 Y334.03 E.06617 Buffered code: G1 X335.767 Y334.23 E.02749 Buffered code: G1 X335.59 Y333.679 F15000 Buffered code: G1 F1500 Buffered code: G1 X334.92 Y333.853 E.04803 Buffered code: G1 X334.282 Y333.984 E.04519 Buffered code: G1 X333.634 Y334.091 E.04557 Buffered code: G1 X332.588 Y334.206 E.07302 Buffered code: G1 X331.473 Y334.279 E.07753 Buffered code: G1 X328.705 Y334.286 E.19207 Buffered code: G1 X327.414 Y334.206 E.08975 Buffered code: G1 X326.38 Y334.093 E.07218 Buffered code: G1 X325.719 Y333.984 E.04649 Buffered code: G1 X324.531 Y333.728 E.08433 Buffered code: G1 X324.202 Y333.548 E.02602 Buffered code: G1 X323.572 Y333.103 E.05352 Buffered code: G1 X322.915 Y332.457 E.06394 Buffered codes: 1472 bytes total Code buffer space: 1920 Configured SPI speed: 8000000Hz, TfrRdy pin glitches: 0 Full transfers per second: 39.44, max time between full transfers: 54.9ms, max pin wait times: 54.5ms/4.6ms Codes per second: 19.17 Maximum length of RX/TX data transfers: 4436/1124
1LC
Diagnostics for board 121: Duet TOOL1LC rev 1.1 or later firmware version 3.5.2 (2024-06-10 13:24:04) Bootloader ID: SAMC21 bootloader version 2.8 (2023-07-25) All averaging filters OK Never used RAM 3372, free system stack 71 words Tasks: Move(3,nWait 7,0.3%,88) HEAT(2,nWait 6,0.3%,90) CanAsync(5,nWait 4,0.0%,52) CanRecv(3,nWait 1,0.1%,70) CanClock(5,nWait 1,0.0%,58) ACCEL(3,nWait 6,0.0%,52) TMC(2,nWait 6,3.7%,52) MAIN(1,running,90.7%,314) IDLE(0,ready,0.0%,26) AIN(2,delaying,4.9%,112), total 100.0% Owned mutexes: Last reset 01:00:15 ago, cause: software Last software reset data not available Driver 0: pos 0, 405.0 steps/mm, ok, SG min 0, read errors 0, write errors 2, ifcnt 168, reads 27122, writes 16826, timeouts 4, DMA errors 0, CC errors 16827, failedOp 0x71, steps req 0 done 2205650 Moves scheduled 57511, completed 57507, in progress 1, hiccups 80, segs 26, step errors 0, maxLate 0 maxPrep 354, maxOverdue 106, maxInc 52, mcErrs 0, gcmErrs 0, ebfmin 0.00 max 1.00 Peak sync jitter 0/6, peak Rx sync delay 252, resyncs 0/0, no timer interrupt scheduled VIN voltage: min 11.6, current 24.2, max 24.5 MCU temperature: min 34.6C, current 45.2C, max 46.0C Last sensors broadcast 0x00000002 found 1 143 ticks ago, 0 ordering errs, loop time 0 CAN messages queued 49415, send timeouts 0, received 65795, lost 0, errs 0, boc 0, free buffers 18, min 18, error reg 0 dup 0, oos 0/0/0/0, bm 0, wbm 0, rxMotionDelay 398, adv 36262/74666 Accelerometer: LIS3DH, status: 00 I2C bus errors 0, naks 0, contentions 0, other errors 0
@charliedrums Looking at this logically, any print move looks like this. G1 Xnn Ynn Enn. Which means move a certain distance in X and/or Y while extruding a certain amount of filament. What you are saying is that at random times, when printing a gcode that you have printed many times before, that Enn becomes something greater. I.e, the fimant moving through the extruder randomly moves further or faster than it should do. There are many reasons why it might move less (partial blockage, temperature too low, motor or wring issue, missed steps, etc), but none that I can think of that would make the filament move further than it should. So the only logical conclusion is that something else is happening which gives the appearance of over extrusion when in fact it isn't. My best guess, as I've stated before, is that your Z axis isn't moving the full layer height.
I would have guessed the same but I have checked all 4 Z motors and their harnesses. Here is what leads me to determine it is over extrusion. First once the issue begins, I remove the print from under the extruder and let it print in air for a while and visibly one can tell the more amount of plastic is being forces through the nozzle.
Second, I am using the Orthus Filament Monitor. The orthus has a light that flashes intermittently when filament is running through it. The faster the blink of the light the faster the filament if passing through the sensor, when the problem begins the light flashes faster as in filament is passing faster trough the sensor/extruder. I can move the printer to the max height(365mm) and home without any problems.
I’m going one thing at a time right now I eliminated the z scanning probe and the filament sensor. Still happening. This time around I re did the harness that powers the tool distribution board (two cables 24v Vin ground) and am currently running the print to see if the problem continues after this, I’ll re do the RJ11 cable. Then continue from there.
@charliedrums If you are certain that it is genuine over extrusion after some seemingly random period of time, then the only explanation I can think of is that somehow, something is changing the G1 Xnn Ynn Enn commands that exist in the gcode file to something like G1 Xnn Ynn E(some other value that is always higher). I note that you are using a SBC. Is there any chance that you could run stand alone mode and print directly form an SD card?
@charliedrums One other suggestion - try a print without input shaping. I can't offhand think why it should make a difference but who knows?
@deckingman
Yes, I can I don’t see why not. The only reason I have SBC is so I could get WIFI. Looking through the documentation I see that I can connect to the board directly with an ethernet cable. Next thing Ill do is that go Direct an eliminate the SBC and see. Thanks for the idea. -
@charliedrums said in Random overextrusion after 3+hours of printing FW 3.5.2:
Good that you're keeping an open mind.
Having printed the code before may not prove anything.
For example in my case the Gcode extrusion values were far above the capabilities of the extruder, but I wasn't getting skipped steps because my maximum extruder speed values were limiting it to achievable amounts (albeit way over extruded).
If in the interim you had for example increased your max extruder speeds then a problem that wasn't obvious before may now appear.
Loading the code into Prusa Slicer and viewing it by volumetric flow rate would show up any odd areas most likely a lot more than just scanning the code by eye.Have you tried swapping the drivers around that the extruder is on?
That should rule out a hardware fault on the board at least.EDIT: Just saw that you're using a tool board and have swapped it.
Just noticed a similar post also using a toolboard
https://forum.duet3d.com/topic/35869/overextrusion-out-of-nowhere
One for @DC42 I think -
@charliedrums One other thing to try, I think you said that once it gets into this "over extrusion mode" then it stays in it even when starting a new print? If that is the case can you try checking the extruder calibration when in this state see: https://docs.duet3d.com/en/How_to_guides/Calibration#h-3-calibrating-extruder-e-steps-per-mm and then do a reboot and perform the same task again and see if there is any difference.
undefined Phaedrux moved this topic from General Discussion
After many weeks of testing, I figured out the problem. I started re-wiring every cable to eliminate any problem with the harnesses. Once I got to the power from the Mainboard 6HC to the tool distribution board. I measured the power from this cable with a multimeter and everything was reading normal. For some reason once I rewired this harness everything seems to be working now.
I’ve done dozens of 20–50-hour prints with no problem so far. Updating this post in case someone is having the same issue. Check the power from the main board to the tool distribution board.
undefined chrishamm has marked this topic as solved
@charliedrums I'm glad you solved it! Thanks for the update.
