Solved G30 Causing G28 can not be called in homing file error
NOT SURE WHERE TO POST THIS SO I THOUGHT I WOULD START HERE. SORRY IF IT SHOULD BE IN A DIFFERENT CHAT!
My machine is a Voron 2.4r2.
Board: Duet 3 Mini 5+ (Mini5plus) with the 2 port expansion board
Firmware: RepRap Firmware for Duet 3 Mini 5+ 3.4.6 (2023-07-21)
Duet WiFi Server Version: 1.27
The Situation
When I issue a homeall.g command using DWC HomeAll Button. X and Y home as they should while Z homes but issues the error message below. The homing files are attached as is my config.g. As I am using a klicky probe I have written macros to check to see if the probe is attached before the execution of the most moves. During maintenance I seem to frequently leave it attached and that creates issues chasing it down when it gets knocked off.
The Issue
When I include G30 in the homing file I get the error message below. When I don't include the G30, Z moves to position to home, but does not home. I assume G30 is calling G28 which is why the firmware complains about it but then ignores it and does the homing anyway. I would like to find a way to make this home without getting the error. Is that possible?
4/2/2024, 4:08:46 PM M292
Error: G28 may not be used within a homing file
Probe already attached
Attach Probe Successfulconfig.g.txt
HomeAll Incuding X Y Z Files.txtNot a huge issue but I suspect there is a simple solution.
Thanks
@JADoglio Are those your actual homing macros? What is producing the output "Attach Probe Successful"? Do you still get that error message if you remove (or comment out) the M291 command from your homez?
@JADoglio please also post your deployprobe.g and retractprobe.g files, if you have those.
David, thanks for the reply. Here is the file you asked forgloomy,
The command to test for probe attachment is in the file. When I remove it, I get the same error
if sensors.probes[0].value[0] == 0 ; if sensor value is 0 do this, 0 = probe attached
echo "Probe already attached"Thanks all
@JADoglio What does the code in this file do:
M98 P"Home if needed.g" -
It is a macro that is called at the start of a print. If the machine is already homed, it will not home again even though there is a G28 in the start g code file for the printer.
if !move.axes[0].homed || !move.axes[1].homed || !move.axes[2].homed ; if homed don't home again
G28 ; if not, continue homing -
@JADoglio You are calling that file at the start of your deployprobe.g file, this is probably what is causing that message about G28 as your call to G30 will be triggering a call to deployprobe.g which is calling Home if needed.g which will see that Z is not currently homed and will then try to run M28...
This is what you said is in your deployprobe.g file:
deployprobe.g in sys folder M98 P"Home if needed.g" if sensors.probes[0].value[0] == 0 ; if sensor is value ia 0 do this, 0 = probe attached echo "Probe already attached" if sensors.probes[0].value[0] == 1000 ; if sensor is 1000 do this, 1000 = probe detached G1 X53 F20000 ; X position of klicky dock G1 Y340 F20000:120 ; Y position of klicky dock G1 Y345 F600 M400 G1 Y175 F12000 ; slide out of dock return to bed Y center G1 X175 F12000 Z10 ; slide out of dock return to bed X center M400 ; wait for moves to finish if sensors.probes[0].value[0] == 1000 ;Check to see if probe is attached 1000 = not attached G1 X175 Y175 F10000 abort "Attach probe FAILED!" else echo "Attach Probe Successfull"
@gloomyandy Thanks. That was the source of the issue. I figured out how to get around it. I appreciate the help. Regards, Jim
